| Re: 35th America's Cup
[Re: Timbo]
#280095 08/01/15 11:01 AM 08/01/15 11:01 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Here's a question for you designer wannabe's.
As we have been seeing ever since Foiling became a 'Thing', the worst thing that can happen is the dreaded nose-over, pitch pole. As I look at all the foiling boats, from the Phantom all the way up to that 70' Tri above, they all have the main lifting foils mounted at about mid hull, with a T rudder setup in the back. From watching many of these videos, it seams they always start to hobby horse in any type of big swell, and the bows dig in once in a while, often with disastrous results!
Why aren't they putting the main lifting foils further forward, instead of only at amidships? If the would put it way out front, that would stop the teeter-totter effect we see in the swells.
They could make the rear foils bigger and the front foils smaller, to evenly distribute the weight, but it seems to me it would be much more stable if they spread the foil lift to all 4 corners, rather than keeping it right in the middle of the boat and having the nose dive tendencies. Why are plane wings positioned where they are? Balance? The other thing to consider is how would it handle/steer with the foils forward. Very slow I think.
[Re: David Parker]
#280098 08/01/15 03:07 PM 08/01/15 03:07 PM |
Posts: 3,969 | Does this count? That, as they say, is not fast... Mike | | | Re: 35th America's Cup
[Re: brucat]
#280102 08/02/15 09:50 AM 08/02/15 09:50 AM |
Posts: 12,310 South Carolina | The lack of ability to watch the America's Cup is starting to affect my desire to see any of it. While $8 isn't staggering by any means, I just didn't feel like paying that to see it (partially figuring that it would be available for free moments after I shelled over the $8).
If you want me to pay a few bucks, have a feature presentation put together that compiles the racing action with an inside view from each venue and make it available by subscription at Netflix, or Amazon, etc (where I know I won't have feed reliability issues). I would probably watch the (free) racing and then pay for that to see some inside information on the action.
It's as if our own team kinda gave up on us US schmucks.
Jake Kohl | | | Re: 35th America's Cup
[Re: catman]
#280103 08/02/15 01:39 PM 08/02/15 01:39 PM |
Posts: 6,049 Sebring, Florida. | Here's a question for you designer wannabe's.
They could make the rear foils bigger and the front foils smaller, to evenly distribute the weight, but it seems to me it would be much more stable if they spread the foil lift to all 4 corners, rather than keeping it right in the middle of the boat and having the nose dive tendencies. Why are plane wings positioned where they are? Balance? The other thing to consider is how would it handle/steer with the foils forward. Very slow I think. Well, that's the problem. They have to design something that's going to 'work' in at least 3 axis', then throw in differing sea state, wind speeds, etc, every design is a compromise trying best to fulfill all those requirements. I'm sure they have lots of smart guys from Boeing and Airbus on staff telling them exactly what/where those foils should be, but I'd still like to see what would happen if they put them further forward, and then did a 'shared lift' concept with larger foils on the rudders. That may indeed slow down the turning required from the rudders though, maybe that's why we see such small foils back there, with most of the heavy lifting being done by the big L boards in the middle of the boat. Now, let's think about our A cats, and all the teeter-tottering they do when up on the foils. Have any of them tried moving their big C boards further forward to see if that helps keep them from doing a face plant? Here's the Red Bull 18's foiling: https://www.youtube.com/watch?v=cyVPBob9qvIAnd an A cat: https://www.youtube.com/watch?v=n0gXbhjUDtA
Blade F16 #777
[Re: Timbo]
#280104 08/02/15 01:50 PM 08/02/15 01:50 PM |
Posts: 12,310 South Carolina | Here's a question for you designer wannabe's.
They could make the rear foils bigger and the front foils smaller, to evenly distribute the weight, but it seems to me it would be much more stable if they spread the foil lift to all 4 corners, rather than keeping it right in the middle of the boat and having the nose dive tendencies. Why are plane wings positioned where they are? Balance? The other thing to consider is how would it handle/steer with the foils forward. Very slow I think. Well, that's the problem. They have to design something that's going to 'work' in at least 3 axis', then throw in differing sea state, wind speeds, etc, every design is a compromise trying best to fulfill all those requirements. I'm sure they have lots of smart guys from Boeing and Airbus on staff telling them exactly what/where those foils should be, but I'd still like to see what would happen if they put them further forward, and then did a 'shared lift' concept with larger foils on the rudders. That may indeed slow down the turning required from the rudders though, maybe that's why we see such small foils back there, with most of the heavy lifting being done by the big L boards in the middle of the boat. Now, let's think about our A cats, and all the teeter-tottering they do when up on the foils. Have any of them tried moving their big C boards further forward to see if that helps keep them from doing a face plant? https://www.youtube.com/watch?v=n0gXbhjUDtA they actually started that way. The problem was (didn't we have this conversation before?) that with the shared lift of the main and secondary foils, the boat was very unstable when transitioning from displacement mode to foiling mode. At some point in that transition, the boat needs to pitch up in order to get to an elevated foiling position. With forward mounted foils and rudders lifting (and no allowed trim tabs on any of the foils), the boat tended to porpoise badly and was very difficult to control. It was only until they brought the foils back closer to the center of mass of the boat that they were able to achieve a stable transition from displacement to foiling....which is the same reason airplanes have a primary lifting wing close to the CG of the aircraft.
#280105 08/02/15 02:40 PM 08/02/15 02:40 PM |
Posts: 2,490 On the Water | Here's a question for you designer wannabe's.
They could make the rear foils bigger and the front foils smaller, to evenly distribute the weight, but it seems to me it would be much more stable if they spread the foil lift to all 4 corners, rather than keeping it right in the middle of the boat and having the nose dive tendencies. Why are plane wings positioned where they are? Balance? The other thing to consider is how would it handle/steer with the foils forward. Very slow I think. Well, that's the problem. They have to design something that's going to 'work' in at least 3 axis', then throw in differing sea state, wind speeds, etc, every design is a compromise trying best to fulfill all those requirements. I'm sure they have lots of smart guys from Boeing and Airbus on staff telling them exactly what/where those foils should be, but I'd still like to see what would happen if they put them further forward, and then did a 'shared lift' concept with larger foils on the rudders. That may indeed slow down the turning required from the rudders though, maybe that's why we see such small foils back there, with most of the heavy lifting being done by the big L boards in the middle of the boat. Now, let's think about our A cats, and all the teeter-tottering they do when up on the foils. Have any of them tried moving their big C boards further forward to see if that helps keep them from doing a face plant? https://www.youtube.com/watch?v=n0gXbhjUDtA they actually started that way. The problem was (didn't we have this conversation before?) that with the shared lift of the main and secondary foils, the boat was very unstable when transitioning from displacement mode to foiling mode. At some point in that transition, the boat needs to pitch up in order to get to an elevated foiling position. With forward mounted foils and rudders lifting (and no allowed trim tabs on any of the foils), the boat tended to porpoise badly and was very difficult to control. It was only until they brought the foils back closer to the center of mass of the boat that they were able to achieve a stable transition from displacement to foiling....which is the same reason airplanes have a primary lifting wing close to the CG of the aircraft. Think of the rudder foils serving to provide stability, not so much lift. Similar to the horizontal stabilizer on a plane.
Philip USA #1006 | | | Re: 35th America's Cup
#280109 08/02/15 09:05 PM 08/02/15 09:05 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | The lack of ability to watch the America's Cup is starting to affect my desire to see any of it. While $8 isn't staggering by any means, I just didn't feel like paying that to see it (partially figuring that it would be available for free moments after I shelled over the $8).
It's as if our own team kinda gave up on us US schmucks. +1. My feeling is LE had his run and is done with it. He's hoping BA wins it for merry old England. And we are not schmucks, they are.
[Re: Tony_F18]
#280117 08/03/15 09:48 AM 08/03/15 09:48 AM |
Posts: 12,310 South Carolina | Someone on SA wrote that he got the next ACWS event (Gothenburg) credited to his AC+ account as compensation for there not being any racing on Sunday in Portsmouth. I'm kind of hoping that Ainslie wins the AC, Portsmouth would be a great location for the next AC (and its only a few hours travel!). Anyone else got an email about that? That was released in the news a few days ago....Gothenburg should be free for anyone that paid to see Portsmouth (I'm guessing they aren't exactly making a fortune with the paid viewing).
[Re: Timbo]
#280119 08/03/15 11:35 AM 08/03/15 11:35 AM |
Posts: 5,590 Naples, FL | wonder how many bikes he went through to get those takes...
[Re: waterbug_wpb]
#280121 08/03/15 03:03 PM 08/03/15 03:03 PM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | wonder how many bikes he went through to get those takes... That was exactly my thought. That didn't happen on the first try.
[Re: David Parker]
#280123 08/03/15 09:50 PM 08/03/15 09:50 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | Man... from the name of the video I was hoping to see him time the tube to perfection. Oh well, still impressive. I bet that salt water played havoc on a small gas engine.
-Rob
Rob V.
Nacra 5.2
Panama City | | | Re: 35th America's Cup
[Re: Redtwin]
#280124 08/03/15 10:10 PM 08/03/15 10:10 PM |
Posts: 12,310 South Carolina | Man... from the name of the video I was hoping to see him time the tube to perfection. Oh well, still impressive. I bet that salt water played havoc on a small gas engine.
-Rob And the drive chain, sprockets, bearings...etc. And, technically speaking, it's planing - not foiling. ;-) the way they edited that lead me to believe that big wave at the end choked the engine and the wave got him.
Jake Kohl | | |
1 registered members (WorrellGal50),
641
guests, and 94
