Upwind targets #282252
03/24/16 09:08 AM
03/24/16 09:08 AM
M
Mookie Offline OP
Mookie  Offline OP
M
Hello all,
I'm learning my new-to-me Taipan 4.9, and was wondering what kind of boat speed I should be targeting upwind in 10-15 knots true, relatively flat water. I just don't know if I'm even in the ballpark yet, so any advice will help. Also, racing on a set course, I've been coming up in the puffs, but that seems slow. Is that correct? Should I be easing instead?
Thanks
Re: Upwind targets [Re: Mookie] #282259
03/24/16 06:42 PM
03/24/16 06:42 PM
M
Mookie Offline OP
Mookie  Offline OP
M
Ok, polars maybe?
Re: Upwind targets [Re: Mookie] #282260
03/24/16 06:59 PM
03/24/16 06:59 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
No such thing as polars I'm afraid - at least none I've found.
Only comment I can offer is in the 2nd question.
Its faster to ease in the puffs. However you have to consider you and your crew's ability to do that for a full day of sailing. Truth is some combination of easing/feathering which is very dependent on a whole host of variables. However, as a general rule, assuming you're overpowered, the more you ease the faster. However, don't ease so much that you're footing too much.
Also, don't forget the cunningham. It's an incredibly effective de-powering tool. I've been told the goal is to adjust the cunningham such that your sheet adjustments are only inches (not feet) at a time. If there are lots of variations in wind strength, it might require 3-4 cunningham adjustments on an upwind leg.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Upwind targets [Re: Mookie] #282269
03/26/16 12:56 PM
03/26/16 12:56 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
Definately agree on the importance of the cunningham. If my Falcon is trimmed correctly than I don't need to ease more than one arm length in the puffs.
One up depowering the boat is even more important upwind to keep drive and not to head up each time, slowing you down.
In 2 up we play the cunningham each time we see a puff to keep forward drive.
It is huge which difference it makes compared to teams only using the main.
Speed is difficult as it will differ a lot when you foot a bit. Lining up is the best thing to do.
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: Upwind targets [Re: Mookie] #283021
07/08/16 06:39 AM
07/08/16 06:39 AM
Schnoogie84 Offline
Schnoogie84  Offline
Just thinking out loud, wouldn't heading up in a puff be 'faster' in the upwind leg, as in each puff you are gaining some height?
Re: Upwind targets [Re: Mookie] #283022
07/08/16 07:11 AM
07/08/16 07:11 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
The fast 4.9 sailors here don't have a cleat for the main and constantly work it,the downhaul is worked hard as well, heading up is not really fast IMO, do ou have the latest big head sail
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Upwind targets [Re: Schnoogie84] #283151
07/22/16 10:33 AM
07/22/16 10:33 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Nope, its all about VMG. Most monohulls don't plane upwind, so this can be true for them, but those that do (505's, 49er's, I14's, big canting keel monsters) often have two modes, a point high mode and a faster VMG, couple degree lower mode but in full tilt plane.
Often, and this is especially true for high performance beachcats equipped with the latest high-tech foils, it is faster to ease, come down a few degrees, accelerate, then you can climb on the foils back up to the previous height but with more speed. Key is not to come down too much and go reaching around the course instead of upwind. In big breeze if you run out of downhaul and diamond wire and are still easing main, dropping the traveler a few inches may help, allowing you to keep leech tension on with less pressure in the main.
Scorpion F18
0 registered members (), 656 guests, and 129 spiders.
Posts267,056
