| Re: Sail Tubes?
[Re: jmhoying]
#75226 05/15/06 06:32 PM 05/15/06 06:32 PM |
Posts: 248 Colorado | I've found the black drainage tubing like that used on highway projects and farms is the best bet. It is rigid and sturdy, and has a smooth inner liner. I got 10 feet of 18-inch diameter tubing with a cap on one end for about $100. It can hold three or four sails, my boom with blocks and line, a tiller, and rudder connecting arm. It doesn't get much cheaper than this.
H-20 #896
| | | Re: Sail Tubes?
[Re: SteveT]
#75227 05/15/06 06:54 PM 05/15/06 06:54 PM | Anonymous
| Anonymous
Unregistered | Where did you find it? Can you get it at Home Depot or Lowe's?
Doug | | | Re: Sail Tubes?
[Re: Clayton]
#75234 05/17/06 09:54 PM 05/17/06 09:54 PM |
Posts: 248 Colorado | The ADS tubes are the ticket. Get a semi-permanant cap for the front and mount it so the "bell" end is facing the back and make a removable cap for the back and you're set. Mine has been in use for four seasons with no signs of wear.
H-20 #896
| | | Re: Sail Tubes?
[Re: SteveT]
#75235 05/18/06 07:43 AM 05/18/06 07:43 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan
Posts: 2,074 Northfield,NH USA | I like to line the inside with something like astro-turf so that the bags slide in better and are up off the tube itself. Just 2 cents.
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | |
517
guests, and 100
