| Nacra Crossbar Beam Failure #8770 07/15/02 10:00 AM 07/15/02 10:00 AM |
Posts: 74 Maryland, USA |
My Nacra 5.5 SL front crossbar just failed. One end of the dolphin striker pulled out of the beam. I should say it pulled through the beam. It created a good 1.5 by 4 inch hole in the beam where the backing plate in the beam holding the dolphin striker end came right out. The rod holding the mast then pushed part way through the beam, since the dolphin striker was no longer holding it, and bent the beam, but the mast stayed up.
I assume this was a corrosion problem, but I have never heard of this happening. Has anyone else seen this? I don't know how you could easily inspect for such a thing.
Does anyone have any spare Nacra 5.5SL front crossbars lying around? I thought not.
Patrick Ragen Taipan 4.9 USA 274
| | | Re: Nacra Crossbar Beam Failure
[Re: tami]
#8773 07/16/02 09:11 AM 07/16/02 09:11 AM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | Hi, Tami,
Isn't the crossbar powdercoated or externally treated in any way?
Sail Fast,
Ed Norris
[Re: Ed Norris]
#8774 07/16/02 09:45 AM 07/16/02 09:45 AM |
Posts: 12,310 South Carolina | Clear Anodized. Most anodizing shops will have facilities to anodize the 8'6" beam (just not a mast). The process isn't too expensive and I would estimate it would cost you anywhere from $30 to $75 for the anodizing. You can get this in colors too. (I wonder why no body ever does this).
Jake Kohl | | | Re: Nacra Crossbar Beam Failure
[Re: PRagen]
#8776 08/02/02 04:33 PM 08/02/02 04:33 PM |
Posts: 217 | I have a N5.0 port hull with two crossbeams.
Take it off my hands, please!
| | | Re: 5.0 port hull - Symetrical or no??
[Re: jcasto1]
#8777 08/04/02 05:51 PM 08/04/02 05:51 PM |
Posts: 292 Long Island, NY | DID you say 5.0!!! I'm looking for a late model (mine's a 95) starboard hull - - - does anybody know if they're interchangeable??
Sail Fast,
Ed Norris
673
guests, and 163
