| Walk me through this #275142 09/02/14 10:56 AM 09/02/14 10:56 AM |
Joined: Dec 2001 Posts: 5,590 Naples, FL waterbug_wpb OP
Posts: 5,590 Naples, FL | Needing to pull the daggarboard out for gelcoat fairing. Questions: - Looks like some sort of adhesive between base plate and deck. Any thoughts on non-destructive removal? - recommended sealant between plate and deck when I reinstall? - when I replace the screws, should I consider bedding in thickened epoxy (assuming they're just screwed into the sandwich material)? If so, will I be able to remove them in the future? Should I wax the screws?
| | | Re: Walk me through this
[Re: mbounds]
#275151 09/02/14 03:55 PM 09/02/14 03:55 PM |
Joined: Nov 2013 Posts: 21 Quebec, Canada A. Bourgault
Posts: 21 Quebec, Canada | I would remove the screw and heat the plate gently with a propane torch until it comes off.
[Re: waterbug_wpb]
#275152 09/02/14 05:17 PM 09/02/14 05:17 PM |
Posts: 12,310 South Carolina | well...first, remove the screws and see if you can gently pry it up. You might be surprised. If not, use a 5200 remover and soak the area (it will degrade any 5200 that it comes in contact with - so keep this in mind). Let that soak a while and remove the parts. The blade under the edge might give it some incentive and might help work the remover into the joint a little if it is problematic.
Reseal it with Sikaflex UV.
Jake Kohl | | | Re: Walk me through this
[Re: Todd_Sails]
#275181 09/05/14 10:14 AM 09/05/14 10:14 AM |
Posts: 5,590 Naples, FL | that's the top of the daggarboard trunk. The mast base sits on that plate/ball
[Re: Todd_Sails]
#275211 09/08/14 08:35 AM 09/08/14 08:35 AM |
Posts: 5,590 Naples, FL | apologies. Corsair F24-2
Yeah, it's not a cat, but you twerps have a pretty good experience base in composites, foils and lightweight multihulls...
656
guests, and 129
