lacing the tramp #100805
03/17/07 04:17 AM
03/17/07 04:17 AM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
Does anyone have some pictures or drawings on how to lace a tramp on a nacra 5.2. Someone else removed the old tramp and I did not see how the lacing was installed.
Thanks airborne
nacra 5.2 #2410 live long and prosper
Re: lacing the tramp [Re: airborne] #100806
03/17/07 07:13 AM
03/17/07 07:13 AM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
With the bar or without?
-Rob V.
Rob V. Nacra 5.2 Panama City
Re: lacing the tramp [Re: Redtwin] #100807
03/17/07 08:28 PM
03/17/07 08:28 PM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
With a plastic pipe about 3/4" around.
Thanks airborne
Re: lacing the tramp [Re: airborne] #100808
03/18/07 08:34 AM
03/18/07 08:34 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
There should be an eyelet on each end of the rear crossbar. Tie a bowline to one of them, then go around the pvc pipe and back to the eyelet, then go to the the first sliding guide on the crossbar, then to the next space on the pvc pipe and back to the same sliding guide, then go to the next sliding guide and repeat the process all the way. Remember when lacing try and keep the line going in a fashion that will not cause undue friction and try and keep the sliding guides lined up with the slots in the tramp where the pvc runs through. I then use a flat bar to tighten. I place it under the rear beam between the beam and the lacing and pull up to tighten, I may do this 2 or 3 times. Remember the tramp is best tightened at the warmest time of day in the sun if possible.
Re: lacing the tramp [Re: Hullflyer1] #100809
03/20/07 10:46 PM
03/20/07 10:46 PM
dallas tx
airborne Offline OP
airborne  Offline OP
dallas tx
Wow, thanks for the great info. I guess I have some rework to do.
thanks again airborne
0 registered members (), 324 guests, and 47 spiders.
