Multi-sport Lifejacket #100894
03/18/07 12:21 PM
03/18/07 12:21 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Anyone have any input on a Multi-sport U.S.C.G. approved vest?
I need to get a PFD that will work Surf kayaking as well as for on the Hook sports like Hobie sailing, Kiteboarding and windsurfing. So the vest needs to work with a waist and seat harness. I see adds for the Stohlquist WEDGe that has neoprene panels inside that are supposed to help grip the bod.
Any input on what to look for would be appreciated!
Scott
Re: Multi-sport Lifejacket [Re: root] #100895
03/18/07 02:09 PM
03/18/07 02:09 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Stohlquist "Drifter" works like a dream...
Trey
Re: Multi-sport Lifejacket [Re: root] #100896
03/18/07 02:20 PM
03/18/07 02:20 PM
Be sure to look at Astral buoyancy too. We've been wearing their stuff for distance racing and they're some of the best life vests I've ever owned.
http://www.astralbuoyancy.com
Re: Multi-sport Lifejacket [Re: Jake] #100897
03/18/07 02:30 PM
03/18/07 02:30 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
What features have you found that you like for on the hook sailing?
The Astral line had been mentioned to me but again lot's of choices and I was not sure if they fit the bill for on the hook waist or seat harness sailing.
Thanks for the input! Scott
Re: Multi-sport Lifejacket [Re: root] #100898
03/18/07 04:34 PM
03/18/07 04:34 PM
NC
drbinkle Offline
drbinkle  Offline
NC
I use the Stohlquist WEDGe and it works great. I've used it cat and dinghy sailing, surf kayaking, and wakeboarding without any problems. It's never in the way and allows for excellent upper body movement. I'll probably buy another one after it wears out.
Re: Multi-sport Lifejacket [Re: Jake] #100899
03/18/07 07:34 PM
03/18/07 07:34 PM
I have the Astral Newton partly based on Jake's suggestion, well, mostly based on his suggestion and it has worked very well. Unlike all the others I have worn, I forget that I am wearing it. However, it is not USCG approved. It is a "bouyancy aid"
Re: Multi-sport Lifejacket [Re: PTP] #100900
03/19/07 07:52 AM
03/19/07 07:52 AM
I didn't know that. Our Tempo vests are CG approved.
Re: Multi-sport Lifejacket [Re: Jake] #100901
03/20/07 04:44 AM
03/20/07 04:44 AM
dallas tx
airborne Offline
airborne  Offline
dallas tx
Has anyone tried this one? I am thinking about it. I only sail on lakes.
Thanks airborne pfd
nacra 5.2 #2410 live long and prosper
Re: Multi-sport Lifejacket [Re: root] #100902
03/20/07 10:21 AM
03/20/07 10:21 AM
Dunedin Causeway, FL
hobiephil Offline
hobiephil  Offline
No matter which one you get, do get it in an attention getting color. Although blue or green are pretty, you need to be seen if you are seperated from your boat.
Re: Multi-sport Lifejacket [Re: Jake] #100903
03/20/07 11:19 AM
03/20/07 11:19 AM
Jake,
I think some of the Astrals are USCG approved, the Newton isn't because it doesn't have enough pounds of bouyancy.. but you probably already figured that out <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Multi-sport Lifejacket [Re: PTP] #100904
03/20/07 06:58 PM
03/20/07 06:58 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Will Any Of The "Buoyancy Aid" jackets float a normal size person, face up and head out of the water if NOT swimming?
Re: Multi-sport Lifejacket [Re: root] #100905
03/20/07 11:06 PM
03/20/07 11:06 PM
don't know... I meant to check that with mine but was more interested in getting the boat up, etc. I do remember it not doing the standard ride up choke thing like the cheap ones do though.
Re: Multi-sport Lifejacket [Re: PTP] #100906
03/23/07 08:26 PM
03/23/07 08:26 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Thanks Everyone!
What I have found out is that even if a jacket is U.S.C.G approved it does not have to float one's face up!
So now I see why one might choose a buoyancy aid jacket!
Seems like the only jackets that have enough flotation to do this and be able to move are the inflatable type jackets.
Only problem with these for me is having the mind to pull the trigger when needed!
Re: Multi-sport Lifejacket [Re: root] #100907
03/23/07 10:32 PM
03/23/07 10:32 PM
Thanks Everyone!
Some people swear by the inflatable ones but my concern is wacking your head hard enough to get knocked out and then what good would it do you? But that being said, if you don't have one of those mega ones that float you face up then I guess it doesn't really matter.
Re: Multi-sport Lifejacket [Re: PTP] #100908
03/24/07 12:15 PM
03/24/07 12:15 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Ahhh Yep! It's a bit of a sticky wicket! Eeeeeh!
This unexpected napp thing for me is gonna be a pain for my watersports!
Seems like if I'm not wearing a May West than all someone might find is a body attached to a nice jacket!
I am hoping I can find a jacket that I can move in and still float face up!
Re: Multi-sport Lifejacket [Re: PTP] #100909
04/10/07 08:39 PM
04/10/07 08:39 PM
Lorain,Ohio
root Offline OP
root  Offline OP
Lorain,Ohio
Everyone thanks your input on PFDs!!
This forum was one of the more helpful with this type of jacket!
After much research I purchased a KoKatat SeaO2 jacket, this PFD has minimal flotation then the ability to be expanded by mouth or Co2 to 23.5lbs of flotation.
I have yet to get the jacket wet but will soon to give it the full test!
Re: Multi-sport Lifejacket [Re: root] #100910
04/10/07 10:50 PM
04/10/07 10:50 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Kokatat Msfit saved my life! I put it on then forget that it on.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Multi-sport Lifejacket [Re: Chris9] #100911
04/10/07 10:59 PM
04/10/07 10:59 PM
Personally, I wouldn't want to be busy blowing all my hot air into a life jacket while I'm in the water. I'd rather be spending all my energy getting my boat righted. Nor would I like to have to rely on Co2 cartridges to do the job for me. I hope to goodness you didn't get the self-inflater option that activates when it detects water.
Re: Multi-sport Lifejacket [Re: MauganN20] #100912
04/10/07 11:09 PM
04/10/07 11:09 PM
yeah, that would be bad news... imagine the first time you end up in the water and poof... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Multi-sport Lifejacket [Re: PTP] #100913
04/11/07 06:28 AM
04/11/07 06:28 AM
imagine the first time you get splashed by a wave slapping off the side of the hull...
Foredecks on monoslugs don't even use the auto-detecting-inflaters for this very reason. They take some splashy splashy and all of a sudden, they are the stay-puff marshmellow man.
1 registered members (JesperS), 759 guests, and 38 spiders.
