roller furlers not being used #101173
03/21/07 09:49 AM
03/21/07 09:49 AM
binga Offline OP
binga  Offline OP
I have a f16 taipan and I am looking for a roller furler for it. Is it true that f18 are no longer using furlers if so would it work on a taipan 4.9. Thanks Andrew
Re: roller furlers not being used [Re: binga] #101174
03/21/07 10:36 AM
03/21/07 10:36 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
It is not that they are not being used. It is that the rules will not require them to be used. The problem is that if we have a jib that is set up for a roller furler we will probably keep the furler until we replace the jib. I am sure there is someone that is itching to be the first on the block to change. That is usually me, but I have a new jib that works on the furler. I need a spinnaker and main but those would not help you much.
Later,
Dan
Re: roller furlers not being used [Re: Dan_Delave] #101175
03/21/07 12:14 PM
03/21/07 12:14 PM
binga Offline OP
binga  Offline OP
Thanks for the reply. Would you or anyone suggest a specific furler to use on a taipan 4.9? Andrew
Re: roller furlers not being used [Re: binga] #101176
03/22/07 11:49 AM
03/22/07 11:49 AM
Dan_Delave Offline
Dan_Delave  Offline
Any of them are fine, all of them work. I feel the one on the Hobie Tiger works a bit better than the one on the Nacra F18, but it is a bit larger.
