| Re: LOCH NESS MONSTER RACE IS ON
[Re: scooby_simon]
#101723 09/04/07 04:34 AM 09/04/07 04:34 AM |
You guys are mistaken scepsis with being a vinegar pisser.
Development and science are much helped by scepsis; of course as long as it doesn't become the dominant factor.
I'm sceptical about this design. The centre pod idea is nice but already tried and proven by those cats on like Geneva. The poleless spinnaker tack support (by a pair of bridles) isn't new either, the Swell Shadow for example has proven this setup to work. All carbon is nothing new either, see my earlier listing. The remainder of the rig is very standard, so too the hull shape and Marstrom rudders and rudderstocks for example. The platform is still two hulls, two beams and a trampoline.
So basically, what exactly is being developped here that hasn't already been succesfully developped by others ? One could almost say that they are trying to reinvent the wheel.
I respect the fact that a group of builders are going through the trouble of creating a new boat, but that in itself does not equal development.
Additionally, the boat is made larger then most other cats and therefor is very likely to be faster then the others. You don't need to be a top boat designer to figure this out. As such I'm personally not yet impressed by this design.
Alot more interesting would have been to use the same specs as the Tornado and then design it such that it beats the Tornado by a significant margin. Then we all as catamaran enthousiasts can learn something. Learn what new design features improve performance. Right now we can learn nothing because this boat is pretty much alone in its specs.
I will admit to feeling that the designers took the easy route to a line honours winner, by placing the specs well out of the way of other dominant cat designs. As such I fear they can only loose and never win. Afterall, if this design wins then HEY, it is a larger and lighter design, what will anybody expect ? But when it looses then everybody will be all over it.
No, it would have been alot more interesting when they used these idea's under a rule framework like the F18's or the specs of the Tornado design.
So again I'm being sceptical. The difference to being a downer is of course that I can argue my stance as I have done above.
[Re: Tony_F18]
#101724 09/04/07 04:45 AM 09/04/07 04:45 AM |
Posts: 9,582 North-West Europe | Most of the rig forces will be transmitted along this centre pod. So basically the are no bridles or forestay to flex the hulls.
However, there will be no difference in flexing due to "walking the waves". As such the stiffness difference could be very marginal. Afterall the rig loads to tend to behave as a static pretensioned spring setup. As such they do not alter the stiffness of platform, they just reposition the flexing situation to a different operating point.
Example:
Hang a weight on a spring and measure its stiffness. This can also be done by measuring the oscillation frequency as that is proportional will the stiffness of the whole system.
No reposition this system to the horizontal plane so the force of gravity is taken out of the equation. Measure the stiffness again (frequency) you will find that they are the same.
Basically, adding a static force to a spring setup will not alter the stiffness of the system, it will only change the position of the weight and thus the average position of the weight when it oscillates.
Your other points are of course quite to the point. 3 and 4 mm wires and a dolphinstriker setup tend to be the lightest and cheapest solution most often. That is why dolphinstrikerless setups and unstayed or partically stayed rig have never really gotten into fashion.
The extra material needed in the hulls to take the bridle loads also doubles up as extra material to make the hulls and platform stiffer.
The conventional beach cat design is pretty well developped. Both in weight, stiffness and costs (cheap).
[Re: Wouter]
#101725 09/04/07 05:03 AM 09/04/07 05:03 AM |
Posts: 3,528 Looking for a Job, I got credi... | Wouter, Regarding this comment: Alot more interesting would have been to use the same specs as the Tornado and then design it such that it beats the Tornado by a significant margin. Then we all as catamaran enthousiasts can learn something. Learn what new design features improve performance. Right now we can learn nothing because this boat is pretty much alone in its specs. And then this boat would be directly against the Tornado; would you invest your money in trying to overthrow the Tonado. Mastrom has tried with the M20 and has not made much progress. The Olympic teams will be sailing the Tornado and then the F18 for the fleet sizes. I'd wager that this boat is aimed at people who want to go faster than a Tornado (hopefully) but with less skill. Yes, I'd agree it's nothing really new, but it may have a market and it looks like it should be fun.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: LOCH NESS MONSTER RACE IS ON
[Re: GBR6]
#101727 09/04/07 06:42 AM 09/04/07 06:42 AM |
Posts: 9,582 North-West Europe | But doesn't it depend to a certain extent on what the boat was designed for?
Indeed it does. ... have a boat that big guys can sail without being penalised for being big (sorry but F20 just aren't competitive on handicap IMO) and b) a line honours machine. That the boat looks fantastic is a bonus.
The ills of the F20 have surprisingly little to do with crew weight. Interestingly enough these very same heavy crews are just as fast on a F18 as they were on their F20. The basic F20 design is the problem. By far most of us know the F20 only by the Nacra 20. And this design has not seen much development at all over the years, while other designs like the F18 did. For better installments to the F20 rule look for the White formula 20 (John the Vries special) and the Eagle 20 cats. But even then the F20 class specs are limiting the performance more then the crews weights. Modern F18's take large crew weights quite well. For a line honours boat, yes indeed, they are on track. I would have respected it more if it became a line honours boat through clever designing rather then brute force (larger boat) but those are just my personal feelings. Last I knew no development had happened on the foils as this is a small team project who all have day jobs and it's one thing at a time, expect more to follow.
Okay. I had figured as much, by the way. Hardly any beach cat is designed by a dedicated team. As good as all new developments have come from small private projects. That includes the Capricorn you are sailing. Basically Martin Fisher did the design and AHPC modified is at little bit here and there and took it into production. Most French F18 designs are 1 or 2 person jobs. A-cats and F16's same thing. Pretty much we are all doing it this way, so the Tek-Cat is nothing special in this sense either. And as regards questioning the designer !!!!! No, the RS600 may not be a Cat but it is one of the most popular boats in a comptitive field and had remained so since it's inception.
In the UK yeah, in the rest of the world it is "just another" dinghy with a microscopic following. In the netherlands (next to the UK) there is not even a RS600 class with races. You can't compare the RS600 and Clive to say Eigner and his Flyer A-cat. The latter broke through internationally and you can find fleets of his design on all continents, with other designers copying him. With the first named person you can't. With respect to innovative design he is no Rohan Veal or Bethwaite either. That is just the truth of the situation. Most cat classes would be envious of the RS600 regatta turnouts. I would think it safe to say that Clive Everest knows his stuff. I would add the same kind of comments for the sailmaker as well.
I never said Clive is an ignoramous, just that his history doesn't necessarily garantee a succesful cat design to come off his drawing board. With respect to RS600, it is totally non-existant in Australia, USA, NZL and it is still a very small class in continental Europe. And the RS600 is nothing like a line honours catamaran. Sorry all this is just too far fetched. But indeed there has been enough scepsis on the design now, so I will butt out now. Wouter
[Re: Tony_F18]
#101728 09/04/07 06:48 AM 09/04/07 06:48 AM |
Posts: 12,310 South Carolina | Sorry if I ask a dumb question, but how does that central pod make the boat stiffer? Wouldnt a regular dolphin-striker be cheaper, lighter, and easier when assembling? It ties the forestay directly with the mainsheet (when centered on the traveler) while sailing upwind permitting higher forestay tension and suposedly better pointing ability. With the traditional arrangement, the forestay is attached through the bridles, through the hulls, through the rear beam, and finally to the mainsheet. With the pod, forestay to pod, pod to mainsheet.
Jake Kohl | | | Re: LOCH NESS MONSTER RACE IS ON
[Re: stuartoffer]
#101731 09/04/07 07:44 AM 09/04/07 07:44 AM |
Posts: 9,582 North-West Europe | Remember nothing ventured nothing gained.
If we go back to what I understand Jim's original design brief was - ... - I would say that it looks to be in the ball park.
Indeed. (on both accounts)
1 registered members (FredL),
446
guests, and 68
