| Re: Depowering in gusts
[Re: claus]
#102580 04/02/07 07:28 AM 04/02/07 07:28 AM |
Posts: 12,310 South Carolina | Here's my approach;
You should never luff unless it is your last resort - luffing is slow.
In moderate conditions the first line of defense is downhaul. Once that becomes ineffective, start working the mainsheet easing no more than 12". If you have to ease more than that, start moving the traveler down until you can still control the power with the mainsheet.
Jake Kohl | | | Re: Depowering in gusts
#102581 04/02/07 07:51 AM 04/02/07 07:51 AM |
Posts: 160 | How is this coordinated skipper/crew? For example: crew both or crew downhaul, skipper mainsheet etc.? Is this type of handling typical for F18 or your personal style?
Im principally interested in what you do when the gust strikes, i.e. the 1-2 seconds of reaction to the gust in order to control the boat, not the general depowering.
[Re: claus]
#102582 04/02/07 07:59 AM 04/02/07 07:59 AM |
Posts: 3,293 Long Beach, California | Hi Claus -
I am normally crew, and I have sailed with a fair number of skippers. Generally, crew handles all control lines, with the skipper taking the main only for a few seconds during big changes. In the conditions you describe, I think your crew would probably only have to worry about main trim, as the traveller is already down and the cunnigham is at max setting.
[Re: claus]
#102585 04/02/07 08:14 AM 04/02/07 08:14 AM |
Posts: 3,293 Long Beach, California | Crew will continue to adjust cunningham as conditions pick up, but if you're getting knock-down gusts less than a minute apart, I'm betting you need that cunningham all the way down. I generally keep the traveller all the way UP until the cunningham is all the way DOWN. Mainsheet trim is the only adjustment made in-between making those finer adjustments. ps - many classes develop a cheat sheet like on page 34 of the Capricorn Owners Manual at http://www.ahpc.com.au/pdf/Capricorn%20F18%20Owners%20Manual%20v1.2.pdf
[Re: claus]
#102586 04/02/07 09:11 AM 04/02/07 09:11 AM |
Posts: 12,310 South Carolina | How is this coordinated skipper/crew? For example: crew both or crew downhaul, skipper mainsheet etc.? Is this type of handling typical for F18 or your personal style?
Im principally interested in what you do when the gust strikes, i.e. the 1-2 seconds of reaction to the gust in order to control the boat, not the general depowering. At least for me, if the gusts can be controlled with the downhaul, the skipper generally hangs on to the mainsheet and can ease it if a big gust hits. When it starts to get past the point where downhaul is cutting it, the crew starts to work the mainsheet and only occasionally readjusts the downhaul set for a good average setting. I find it very difficult to drive smoothly while I'm trying to crank on the mainsheet at the same time.
#102587 04/02/07 09:42 AM 04/02/07 09:42 AM |
Posts: 3,528 Looking for a Job, I got credi... | Usual de-powering sequence
1, Downhaul to max, once you are still overpowered 2, Move rotation from pointing at the shroud to pointing at the outboard end of the back beam, once you are over powered 3, Move the traveller out, once you are over powered 4, Let the mainsheet out
You will also need to play the mainsheet as you cannot (usually) react quickly enough with mast rotation or traveller, so in reality you set 2 and 3 as a course setting and then play the mainsheet, if you are letting too much mainsheet out, you need to revist 2 and/or 3. Also note, when playing the downhaul, this twists of the top of the sail making it flatter, you then MAY be able to sheet in harder again now to reduce drag while keeping the same power.
You may also (as you say in the initial question above) move the jib cars out etc.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Depowering in gusts
[Re: claus]
#102588 04/02/07 10:09 AM 04/02/07 10:09 AM |
I think it largely dependents on the shape of the upper halve of the mainsail. On the hobie 16 there is much sail area there and the mainsheet mainly sets the leech twist at halve height. I guess that is the reason that H16's tend to use the traveller as you say.
On my boat, an F16 with a medium squaretop, I find that we do not use the traveller unless we are under spinnaker and can't used the mainsheet itself in fear of overloading the mast top. On all other course and conditions we set the mast rotation, downhaul, outhaul and traveller to suit the average of the conditions. This means that during the gusts we need to shed power quickly and fully. The F16 is a nervous little bugger and adjusting the downhaul is often too slow. Both in depowering and in accellerating away at the end of the gust. For these reason we found that our boat responds best by having the crew work the gusts with the mainsheet. We totally forget about the jib. Pretty much this means that I go out of my way to keep she out on the trapeze. From that position we find that the crew has an excellent feel of when and where the next gust is coming. Right before the gust hits she lets out some mainsheet and continues doing proportionally with the onslaught. Then at the peak of the gusts she starts pulling the mainsheet back in, again proportionally with the strength of the gust.
We find that this keeps our boat flat and makes it accellerate during the gust often with a sharp jump ahead when done right. Absolutely thrilling when done right.
As the skipper I'm holding the downhaul and when she needs to work the sheet to much, meaning that she has to sheet out and in more then an arms length, then I readjust the downhaul or some other trim setting. We try to have the crew only sheet in and out without repositioning the grip on the sheet. She (and also I when I'm crewing) will bend our knees when that is required. You loose righting moment that way but only for a very short while and this is compensated by the accelleration just a few seconds later.
I'm not at all sure whether you can copy this method on the H16.
[Re: claus]
#102589 04/02/07 11:44 AM 04/02/07 11:44 AM |
Posts: 1,203 uk | Gust response for H16; assume that main is block to block and jib slot is open.
Crew eases main sheet Helm eases traveller crew tightens sheet back block to block once main is block to block, crew continues to pull sheet which then hauls traveller to windward so helm takes up slack hey presto - you are back where you started!
this takes a bit of practice but is great to see when it is done well.
#102592 04/02/07 05:05 PM 04/02/07 05:05 PM |
Joined: May 2006 Posts: 96 Budapest, Hungary, Europe CatSailingHu
Posts: 96 Budapest, Hungary, Europe | At least for me, if the gusts can be controlled with the downhaul... Jake, is it mean that until the gusts can be controlled with the downhaul, the crew hold the downhaul line in his hand continually (uncleated), and adjust it continually ? (Similar as just it would be the mainsheet ?) | | | Re: Depowering in gusts
[Re: CatSailingHu]
#102593 04/02/07 09:27 PM 04/02/07 09:27 PM |
Posts: 12,310 South Carolina | our downhaul arrangements don't lend themselves to that - the cleat is aligned for it to stay cleated and the line is a bit small to hang on to those loads that long...but yes, the crew (whether its me or someone else) is constantly working it in and out on a regular basis. Some boats respond to this much better than others. The I20 eats it up but I've found that the F18 only likes this in a much narrower range of wind strengths.
Jake Kohl | | |
3,295
guests, and 205
