Raising the mainsail #10359
09/11/02 03:30 PM
09/11/02 03:30 PM
Lake Charles, Louisiana, USA
dsarge Offline OP
dsarge  Offline OP
I'm having trouble getting the mainsail all the way up on hobie 16. I have tried loosening the battens. Mast is fairly straight.
Any suggestions?
Thanks
David
Re: Raising the mainsail [Re: dsarge] #10360
09/11/02 04:04 PM
09/11/02 04:04 PM
C
CrazyGoose Offline
CrazyGoose  Offline
C
Try These:
1. Check the luff track to make sure it's not blocked with bugs, nests or just good old filth.
2. Lube the luff track and luff rope with silicone spray.
3. Check the sheeves/pulleys in the mast head to make sure they rotate freely.
4. As you raise the sail:
Make sure the luff feeder is feeding the luff rope squarely in to the luff track and not binding. Have a helper feed the luff rope.
Make sure the mast isn't rotated relative to the sail. The luff track should point toward the leech of the sail or the luff rope will bind in the track.
Hoist the main. Position yourself far enough in front of the mast such that the halyard is at about a 30 degreee angle to the mast. This will allow the halyard bead (which holds the main up) to easily get past the retaining tang. After the bead is past the tang, walk toward the mast and let the main lower until the bead is in the tang. Hoisting the sail the last 12-18 inches always seems to take a pretty hefty tug.
Finish rigging and go sailing.
Re: Raising the mainsail [Re: dsarge] #10361
09/11/02 09:39 PM
09/11/02 09:39 PM
PSAILOR Offline
PSAILOR  Offline
I am sure you have already cheked, but also make sure the outhual on the boom is loose. A little lube goes a long way too. I had a problem with my prindle and the top pulleys were worn and badly grooved. I changed them and it is very easy now. The grooved pulleys kept the wire stop from going up over the top of the mast.
Good luck!
Re: Raising the mainsail [Re: dsarge] #10362
09/12/02 05:41 AM
09/12/02 05:41 AM
Australia
Jules_topcat Offline
Australia
Well i have had the same problem and what yu can try is tip the boat over and get some one to hold the sail straight and pull from the top to find the problem it helps by increasing the chance of being able to see. Lube the sail edge and the track, the batterns dont do to much but might help. Make sure your head to wind and last you might want to try using 2 peices of rope. 1 about 3mm thick conected to the main halid and connect that to a thicker peice (like th jib sheet) and pull like hell and well if all of these dont work, well you have one stubbern sail. Well have fun and sail it as offen as possible. Bye
Jules
Jules_topcat
Re: Raising the mainsail [Re: dsarge] #10363
09/12/02 09:07 AM
09/12/02 09:07 AM
Bogie Offline
Bogie  Offline
You might take a look at this thread a few weeks ago on the open forum about sticky main luffs. It's about a different boat but still has lots of good info.
http://www.catsailor.com/forums/sho...iew=collapsed&sb=5&o=&fpart=
