| Re: semperit skippy
[Re: Kennethsf]
#103733 04/13/07 04:11 PM 04/13/07 04:11 PM |
Posts: 1,246 Orlando, FL | Dunno about the cat .... but I'm pretty sure I saw the pontoons on the front of a late model Cadillac somewhere in Texas!
USA 777
| | | Re: semperit skippy
[Re: Kennethsf]
#103739 04/13/07 07:33 PM 04/13/07 07:33 PM |
Posts: 4,119 Northfield Mn | Considering the sea state in the picture it looks a little scary to me.
| | | Re: semperit skippy
[Re: Kennethsf]
#103749 09/25/07 06:08 AM 09/25/07 06:08 AM |
Posts: 9,582 North-West Europe | hmmm I must admit it is build very smart and could be an example for the F12 iniative over here on the forum.
Noted, thanks. Looking at the pics more closely I see it has exactly the same rod rigging that was proposed for the F12's. What is you opinion on that. Does it work well, is it well enough away from to drew to not be a nuisance ? Wouter
| | | Re: semperit skippy
[Re: Wouter]
#103750 09/25/07 09:55 AM 09/25/07 09:55 AM |
Joined: Jun 2005 Posts: 133 The Netherlands Kennethsf OP
Posts: 133 The Netherlands | hmmm I must admit it is build very smart and could be an example for the F12 iniative over here on the forum.
Noted, thanks. Looking at the pics more closely I see it has exactly the same rod rigging that was proposed for the F12's. What is you opinion on that. Does it work well, is it well enough away from to drew to not be a nuisance ? Wouter Wouter, the rods work quite well, they are not in the way of crew, actualy they guide the lines of the jib and provide a handle /something to hold on to, which is nice for the kids please notice that there is a wire from the base of the rods to 2/3 of the mast, this is to prevent the mast from bending to much to lee side The front jib "wire" is solid and provites support as well, both for the mast and for preventing the bows to bend. The jib itself slides in just like the mainsail on a "normal" cat. BTW you are more then welcome to have a look at the cat. we can not be that far away from each other. For our foreign friends: The Netherlands is 150 x 225 miles | | | Re: semperit skippy
[Re: Kennethsf]
#103751 09/25/07 11:46 AM 09/25/07 11:46 AM |
Posts: 9,582 North-West Europe | BTW you are more then welcome to have a look at the cat. we can not be that far away from each other.
Well, I may just do that. See your private catsailor mailbox. Wouter
14,899
guests, and 622
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online15,551 9 minutes ago | | |
