Could you make this thing sail? #104174
04/19/07 11:54 PM
04/19/07 11:54 PM
Norman,OK
gree2056 Offline OP
gree2056  Offline OP
Norman,OK
This is a very small catamaran that is already being made. I think it would be interesting to use as a kids intro cat.
http://backbayboatworks.com/rowmaran.html
Re: Could you make this thing sail? [Re: gree2056] #104175
04/20/07 08:04 AM
04/20/07 08:04 AM
Houston
carlbohannon Offline
Houston
I love the idea, it's light. However adding rudders, rigging, someway to keep it from going sideways, structure to keep the rigging loads from folding it up, etc, etc. It's a lot easier and probably better to use a Wave
Re: Could you make this thing sail? [Re: carlbohannon] #104176
04/20/07 08:19 AM
04/20/07 08:19 AM
I love the idea, . . .
If the oars are sectional, use one for the rudder and one for a dagger board? Add one of those tiny little "fishing rod" masts for kayaks?
Re: Could you make this thing sail? [Re: fin.] #104177
04/20/07 08:26 AM
04/20/07 08:26 AM
If you cold make the oar blades removeable, use them for rudders, use the shafts for a mast and boom, put up a small sail on rings like a Sunfish sail, you could make it sail...downwind.
Re: Could you make this thing sail? [Re: carlbohannon] #104178
04/20/07 08:31 AM
04/20/07 08:31 AM
. . .It's a lot easier and probably better to use a Wave
Carl, that would solve the problem! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> Then what would I do? This is a lot easier than yard work.
Re: Could you make this thing sail? [Re: gree2056] #104179
04/20/07 01:38 PM
04/20/07 01:38 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
It says right one the page, has a sail and mast in each hull
[b] Sail Like you have a Pair
Re: Could you make this thing sail? [Re: Banzilla] #104180
04/20/07 08:55 PM
04/20/07 08:55 PM
<img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Re: Could you make this thing sail? [Re: gree2056] #104181
04/23/07 07:02 PM
04/23/07 07:02 PM
maui
jollyrodgers Offline
maui
they obviously didn't think it had enough bouancy for a mast and took one hull from the rowmaran and added a bigger hull for the sailing version.
the other solution is to use a kite with it, and maybe a seatbelt.
0 registered members (), 485 guests, and 39 spiders.
