| Re: Getting into the water faster
[Re: jwrobie]
#10478 09/13/02 09:40 PM 09/13/02 09:40 PM |
Posts: 1,911 South Florida & the Keys | about an hour +/- 10 minutes.(depending on how fast you drink a beer) You have to minimize the breakdown process, find a way to leave the rudder assembly attached while trailering, leave the standing rigging and traps attached as well. I run all the standing rigging as far forward as it will go and then secure it with bungy cord
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Getting into the water faster
[Re: jwrobie]
#10479 09/13/02 10:14 PM 09/13/02 10:14 PM |
Posts: 273 Key Largo, FL | Jonathan, with some practice, you should be able to get it down to 15 minutes. When Rick and I were racing our Hobie 18 every weekend, we took 15 minutes from trailer to fully rigged and ready to sail; and it took us 15 minutes to be ready for the road again. And there was more to do with the Hobie 18 than with your Prindle 16.
Establish a routine and follow the same routine every time -- do specific things in a specific order.
If two people are working on it, each should have their own part of rigging/de-rigging they are responsible for -- like one puts on the main and the other puts on the jib.
Figure out a quick and easy tie-down system so you are not always hogtieing everything all different ways every time.
We never took anything off for trailering (except the daggerboards, of course). The only stay that was detached was the forestay at the lower end where it attaches to the bridle.
Lots of other people like to totally strip their boat down for trailering, but we're not organized enough to keep track of all the parts and put them back on exactly the way they were before.
Mary A. Wells
[Re: MaryAWells]
#10481 09/14/02 06:28 AM 09/14/02 06:28 AM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie OP
Posts: 215 Durham, North Carolina | 15 minutes! That's even better than I had hoped for. We currently take about an hour longer setting up, less taking down, and it sure would be nice to have that time for sailing!
A couple of questions for my checklist - should I step the mast on the trailer, or take the boat off the trailer, get it on the beach, and step it there?
What is the best way to handle the side stays - should I just loosen one side a few notches, or should I do what the Hobie film suggests, undo one sidestay entirely and have someone hang onto the trap wire, then attach the sidestay and let go of the trap wire?
What ways have people figured out for keeping the rudders on the boat safely while trailering? Mine is a Prindle 16, and I have been tying the rudders to the tiller bar - it's worked so far, but I do keep checking it three times, and still find myself keeping an eye on it while moving the car. The Isotope has a hole through the thing that holds the rudder, and you can put the rudder in position and stick a clevis pin through to hold it up. I'm thinking about finding a way to modify the Prindle rudders along those lines, but I am not sure I want to drill through the castings.
Jonathan | | | Re: Getting into the water faster
[Re: jwrobie]
#10482 09/14/02 07:23 AM 09/14/02 07:23 AM |
Posts: 273 Key Largo, FL | It is easiest and fastest to step the mast while the boat is on the trailer, still tied down to the trailer, and the trailer is attached to your vehicle. Same thing for lowering the mast, make sure you tie it down to the trailer before lowering the mast.
Sidestays. You may not have to do anything with them. It depends on how loose or tight you run your rig. At worst, you would simply loosen the sidestay on one side a couple notches just to give you enough slack to undo the forestay. Whatever you, do not do what you described. You do not want to completely undo one of the sidestays and then raise or lower the mast with somebody holding one side with a trapeze wire. Not good! You have somebody pulling down and out on the trapeze wire just to support the mast on that side long enough to change the adjustment of the sidestay and get it pinned again. This is standard procedure for tightening or loosening stays. I'm sure that is what they were trying to show in the video you saw.
Securing rudders for trailering. Somebody else will have to help you with the best way to do it for the Prindle 16. I only know how to do it with the Hobies, and they use a different rudder system. Usually you want the rudders in the "up" position for trailering.
Mary A. Wells
[Re: jwrobie]
#10491 09/18/02 12:14 PM 09/18/02 12:14 PM |
Posts: 273 Key Largo, FL | As I mentioned in one of my earlier posts on this subject, some racing purists take everything off their boats for trailering. It's just a matter of wear and tear from trailering, I guess. We, on the other hand, do nothing but race, and we have never taken off our rudders for trailering, and we have never seen any adverse effects, even when we are traveling 1,300 miles to a regatta. So I wouldn't worry about it one way or the other. Don't be a purist -- be a funnist and simplist.
Mary A. Wells
[Re: jwrobie]
#10496 09/19/02 08:21 AM 09/19/02 08:21 AM |
Posts: 344 Arkansas, USA | Many racers want their equipment in top shape. Trailering wears your rudder hinge pins, rudders and transoms far more than most sailing due to the vibrations and the weight of the rudders in the "up" position-
What I do on my Prindles is remove the "hinge" bolt (1/4"), rotate the rudders so they are pointed up (about 180 degrees from the down position) and drill a new hole in the rudder head through the hinge bolt hole in the casting. No extra holes in the rudder casting, quick to put rudders from the "up" to sailing position, no need to tie/untie up and downhaul lines, load on parts reduced over that in the straight back position, rudders do not project behind boat, and looks "cool" with the rudders pointing up (friends have called it an "F 16 fighter" look).
Kirt
Kirt Simmons
Taipan #159, "A" cat US 48
2,475
guests, and 285
