Main halyard Stealth F16 trouble #105270
04/29/07 03:22 PM
04/29/07 03:22 PM
Bjärred, Sweden
Pontus_Lofgren Offline OP
Bjärred, Sweden
I was raising my main sail the other day (for the first time) it got stuck and I had a hard time getting it either up or down. In the end the halyard was "wasted". So now I have to get a new halyard. I thought that the reason for the trouble was that the halyard ran inside the mast and that it got stuck somewhere before the block on top of the mast, but when i had a closer look at the mast top i saw that it cannot run outside the mast due to the placement of block at the top of the mast. Did I just had bad luck when the halyard got stuck? I thought that it should be quite easy to raise the main compared with my old Hobie 16.
-The main halyard should run inside the mast, correct?
-How think should it be, 4mm or less so that it does not get stuck?
-Is 20 meter sufficient?
BR
Pontus
Stealth F16 NED 535
Re: Main halyard Stealth F16 trouble [Re: Pontus_Lofgren] #105271
04/29/07 04:03 PM
04/29/07 04:03 PM
BR
Pontus
Pontas, The halyard runs down the inside of the mast track on my boat (new last year) and I assume yours is the same.
Mine is 3mm I think
20m should be enough as the mast is less than 10m high !
Edit to add "track"
Re: Main halyard Stealth F16 trouble [Re: Pontus_Lofgren] #105272
04/29/07 04:04 PM
04/29/07 04:04 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Not in the mast, in the mast track.
20m should be sufficient. That allows you a round trip to the top and back.
Is your halyard running down the mast track to a turning block at the foot? This keeps the halyard inside the track instead of getting in a bind with the bolt rope.
Re: Main halyard Stealth F16 trouble [Re: bobcat] #105273
04/29/07 04:08 PM
04/29/07 04:08 PM
Bruce, they are talking about Stealths, a tad different than our setup on the blades. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: Main halyard Stealth F16 trouble [Re: Robi] #105274
04/29/07 04:12 PM
04/29/07 04:12 PM
bobcat Offline
bobcat  Offline
Doh, reading and comprehension issues.
Re: Main halyard Stealth F16 trouble [Re: bobcat] #105275
04/29/07 04:52 PM
04/29/07 04:52 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Robi,
He said bolt ROPE! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
USA 777
Re: Main halyard Stealth F16 trouble [Re: tback] #105276
04/29/07 10:12 PM
04/29/07 10:12 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Why the need for the convoluted halyard? Seems to me like a waste of effort, money and rope... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Main halyard Stealth F16 trouble [Re: tback] #105277
04/30/07 12:31 AM
04/30/07 12:31 AM
Finland
valtteri Offline
valtteri  Offline
Finland
Robi,
Rope or line are both wrong, correct term would be "köysi" <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />.
Valtteri
Re: Main halyard Stealth F16 trouble [Re: Buccaneer] #105278
04/30/07 02:05 AM
04/30/07 02:05 AM
It's not;
It goes up the track in the mast, round a block at the top of the mast and then to the headboard of the sail.
Re: Main halyard Stealth F16 trouble [Re: scooby_simon] #105279
04/30/07 03:47 AM
04/30/07 03:47 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
I see it as an additional and totally unnecessary failure point and a total waste of effort, where effort is not needed. Otherwise it’s OK… <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Main halyard Stealth F16 trouble [Re: Buccaneer] #105280
04/30/07 01:54 PM
04/30/07 01:54 PM
[censored] ? please explain
Re: Main halyard Stealth F16 trouble [Re: scooby_simon] #105281
04/30/07 08:56 PM
04/30/07 08:56 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
The halyard assemble is not necessary and adds another layer of convolution, so from a minimalist perspective it should not be there. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Main halyard Stealth F16 trouble [Re: Buccaneer] #105282
05/01/07 01:50 AM
05/01/07 01:50 AM
But it is quicker than having to tip the boat over !
Re: Main halyard Stealth F16 trouble [Re: scooby_simon] #105283
05/01/07 05:04 AM
05/01/07 05:04 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Yes I guess so.. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
But is that your only alternative? Though it’s quite easy I’ve never needed to lay my Taipan on its side to raise the mainsail. In fact it’s faster then using the convoluted halyard set up. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Main halyard Stealth F16 trouble [Re: Buccaneer] #105284
05/01/07 05:41 AM
05/01/07 05:41 AM
I use a mainsail halyard because the sailmaker who made my sail used a normal bolt rope and you can't push that up the mast. Push up sails require a flexible plastic tube to used as bolt rope.
So for me and some other sailors it is not a question of choice but necessity.
Re: Main halyard Stealth F16 trouble [Re: Wouter] #105285
05/01/07 09:20 PM
05/01/07 09:20 PM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Sad but true... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
The halyard is to compensate for the sail manufacturers error. It’s a temporary solution to a bigger issue. <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
0 registered members (), 271 guests, and 37 spiders.
