| Silly question? #105783 05/04/07 08:05 AM 05/04/07 08:05 AM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C OP
Posts: 432 McCrae Y.C. Mornington Peninsu... | Hi All,
I'm in the process of pulling my timber boat apart in preparation for a paint job. (Interesting the things you find when you buy someone elses boat <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />)
The silly question is:
It seems I have to remove the track to get to the inside bolt on the beam.
The track for the traveller (Ronstan I section with ball bearing car) is fixed to the rear beam with a multitude of allen screws with what look like self locking nuts on the inside of the beam, all along its length.
I can't for the life of me see how to get the track off if the nuts are turning, and more confusingly, how do you get it back on? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Simon Taipan AUS341
| | | Re: Silly question?
[Re: Rolf_Nilsen]
#105785 05/04/07 08:23 AM 05/04/07 08:23 AM |
Posts: 432 McCrae Y.C. Mornington Peninsu... | Thanks Rolf,
I'm hoping I don't have to remove it. The problem is that I dont have room to turn either the bolt inside the beam, or the nut inside the Hull.
Hopefully another Mosquito sailor will tell me how it's done. Failing that I'll give your method ago. Should be good at it by the last bolt!
Perhaps it will all seem clearer in the morning. <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Simon Taipan AUS341
| | | Re: Silly question?
[Re: No_Turbulence]
#105788 05/04/07 08:40 PM 05/04/07 08:40 PM |
Posts: 205 Melb. Aust | Hi Simon,
The rear beam bolts on my Mossie were underneath the I beam and had a flat square stainless piece welded on them instead of a hex head. I had a bit of a time getting to the nuts on the inside, however I found that a long tube socket attached to one of those flexible shafts with the socket bar on the end of that did the trick.
It took a hell of a long time to do each one as I was lucky to get one click out of the bar each time <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />. By the time I had finished it I had no skin left on my arm where it went into the hatch hole. Looked like I'd been ringbarked! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
I have skinny arms, but found I had more room when I removed the hatch frames. Perhaps enlist one of the neighbourhood kids if your arms look like Arnies. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Mozzie 1828 ' ' Sugarloaf Sailing Club Melbourne
| | | Re: Silly question?
[Re: Trevor]
#105789 05/04/07 08:55 PM 05/04/07 08:55 PM |
Posts: 432 McCrae Y.C. Mornington Peninsu... | Thanks for the thoughts everyone.
I to have skinny arms but unfortunately for this job they are rather long! <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
On the plus side, I'm finding the challenges that repairs and improvements throw up to be nearly as enjoyable as the challenges of sailing her! "NEARLY" <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Simon Taipan AUS341
| | | Re: Silly question?
[Re: Simon C]
#105790 05/05/07 06:34 PM 05/05/07 06:34 PM |
Posts: 79 | Simon, Can you have a close look at the beams bolt to check they are Hex or Alan Key Head. If it is a hex head taking the track off will probably not help because the hole in the top of the beam will have top be to big and the beam would fail. In this case the bolt would have been held inside the beam with a spanner on a stick of some kind and tightened with the nut. On the other hand if the Bolt head is an Alan Key head just drill a 7mm Dia hole through both the track and beam and undo it that way. This is the method we use on the new boats. Peter
Peter First Try
| | | Re: Silly question?
[Re: Simon C]
#105793 05/06/07 09:12 AM 05/06/07 09:12 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Simon,
There is more info regarding replacing beams and traveller tracks on the Broken Beam thread on Page 12 of the Mozzie forum. I just can't think of how to link this thread to the other thread. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
The alternative would to use a flatter, wider traveller section than the Ronstan standard, I can't remember which brand <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> then simply drill a hole through the traveller and top face of the beam for a capscrew. I've seen this method on some of the newer Mozzies.
Peter
Mosquito 1814 Macka Mozzie
| | | Re: Silly question?
[Re: Peter_Foulsum]
#105794 05/06/07 05:45 PM 05/06/07 05:45 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | Simon,
Peter Windslyce traveller track extrusions have a channel on the underside which captures the head of the beam bolt preventing it from turning. http://www.windslyce.com/Darryn | | | Re: Silly question?
[Re: Darryn]
#105795 05/08/07 07:29 AM 05/08/07 07:29 AM |
Posts: 556 Somers, Westernport Bay, Victo... | Darryn, I've never heard of Windslyce before. It looks like they make some good gear. The track I had in mind was Harken. http://www.harken.com/charts/smboatcbtrackdim.phpSimon, You may not need to take the track off at all. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Just put a long ring spanner over the inboard bolt head from inside the beam and just undo the nut from inside the hull and lift the whole beam assembly off with the track still in place. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" /> Regards, Peter
| | | Re: Silly question?
[Re: greymatter]
#105798 05/08/07 06:25 PM 05/08/07 06:25 PM |
Posts: 502 Port Noarlunga, SA, Australia | Disadvantage of the Windslyce is the balls are not captive but that is easy to work around during removal. yes if you bought the track and car new you would of been given the tool that the car slides on, this track should be kept, so if you ever need to replace the balls in it, or just take it off the track. if you need one of these bits of track contact Discount sea mart. 9347 4744. I agree with that, tricky to do without the small piece of track it comes with. It is possible though and I have done it when away from home when I broke a ball, I would rate it a two beer job. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Darryn
2,939
guests, and 253
