| Mast Straightening #108048 05/22/07 09:29 PM 05/22/07 09:29 PM |
Joined: May 2006 Posts: 59 Orange County, CA, USA JJD OP
Posts: 59 Orange County, CA, USA | I have had a bizzare accident with my Blade and need the collective advice of the group. On a recent Saturday outing to the Long Beach, CA beach cat launching area named Claremont, There was one cat set up on the beach, mine, and about 50 kite boarders. I was debating whether to risk singlehanding my boat in the brisk winds and as I watched in horror, an out-of-control kite sailor came up the beach and in passing my sailess but rigged Blade, caught the tip of the mast with his kite line, and casized the boat on the beach. There was nothing to slow the mast down except the sand. At first we didn't notice any damage so just put the boat away. This last weekend I verified that the mast is bent slightly to starboard just at or below the diamonds and also has a several degree twist to starboard at the tip. Questions for the group are: Anbody been successful taking this kind of bend and twist out of a mast? I'll try to get pictures of the condition later. Did you do it with the diamonds on or off? I'm contemplating a couple of levers with attached clamps shaped to fit the contour of the mast section. One guy pulls the other holds steady to remove the twist. For the bend, just apply adequate pressure in opposition to the bend and... So what do you think? John | | | Re: Mast Straightening
[Re: Rolf_Nilsen]
#108054 05/23/07 08:19 AM 05/23/07 08:19 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | Oh yeah, definitely, if it becomes harder it also becomes more brittle. That's my understanding anyway, I could be wrong.
I don't believe it is anything to worry about though, ie. it won't become so brittle that dropping it or hitting it with a hammer will smash it.
It also depends on how much it has been bent. From the description given, it doesn't sound too bad. If you can see any "stretch marks" in the material near the bend, it may be too far gone. | | | Re: Mast Straightening
[Re: warbird]
#108060 05/24/07 02:14 AM 05/24/07 02:14 AM |
Posts: 951 Brisbane, Queensland, Australi... | Anyone know how to get a dent out of a superwing?? : ) You may need a superman... <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> You'd be happy to see the kiwis get through to the finals of the LV Cup. Do you reckon they can go all the way? It appeared their heavy weather (if 15 knots is considered heavy) performance in the last race was exceptional. | | | Re: Mast Straightening
[Re: warbird]
#108061 05/24/07 10:28 AM 05/24/07 10:28 AM |
I removed a dent on a Prindle 18 mast by placing a small hydraulic plunger inside the mast and pump up the oil pressure. I had borrowed this hydraulic plunger from a car body repair shop. Most time was spend on making special shaped elements that would distribute the load evenly over.
It can be done, and it was done.
347
guests, and 198
