| Re: Dagger board question
[Re: WindyHillF20]
#108243 05/24/07 01:17 PM 05/24/07 01:17 PM |
Posts: 4,451 West coast of Norway | Ref: http://www.dreesecode.com/other/aflprimer.pdfRead this first. Then consider that there is no free lunch <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> It is all compromises and what you want to optimize your boat for. Aspect ratio is the most important property in my opinion, but it can be a double edged sword, especially so in rough weather. When that has been said, there is a good chanche the world have moved on since your H-18 was built. I would not have modified the existing foils, but got some new ones (or buildt some) and modified the daggerboard wells to accept new boards. | | | Re: Dagger board question
[Re: WindyHillF20]
#108244 05/24/07 04:56 PM 05/24/07 04:56 PM |
Posts: 1,226 Atlanta | Tigers would lift to weather in a puff and my 18 did not I bet this was more due to the sails and rig on the Tiger and less on the daggerboards.
[Re: WindyHillF20]
#108248 05/24/07 11:55 PM 05/24/07 11:55 PM |
Joined: Feb 2004 Posts: 1,012 South Australia Darryl_Barrett
Posts: 1,012 South Australia | Although there are many things that do promote “lift” to windward (higher aspect dagger boards being just a small one of many), it has been my experience that by far the greatest gain to windward always comes from, firstly the sailers and secondly the sails, or I should say, assuming that they are cut well, the set of the sails. Most of the pointing ability of a boat is controlled by the leech of the main as it is the pressure on the leech that is trying to “push” the transom of the boat to lee ward, off the wind with the resulting effect that the bow wants to point up (particularly in the gusts as the CE of the sail tends to move backwards). One of the biggest failures that I have seen in making a boat point is when, after a tack the crew pulls on and cleats the headsail before the main has been set. This will pull a “bow” in the forestay and luff of the headsail and unless the crew doesn’t “crack” the headsail sheet and reset it after the main is set, it is impossible for that boat to point to its full potential. The criteria usually applies that if a similar boat outpoints you consistently, try a swap with the crew of that boat and see if they have the same problem with pointing on your boat as you have, before deciding that “it is the boat and not the sailers”. | | | Re: Dagger board question
[Re: ncik]
#108249 05/25/07 12:11 AM 05/25/07 12:11 AM |
Posts: 4,451 West coast of Norway | Tiger sails on a totally different mast? No wonder you have issues with keeping up. At a minimum you should have the luff curve of the mainsail re-cut to match your mast bend. If you have a composite tip, you will never match the efficiency of a Tiger rig in gusts. How well the leech stands is a major factor when going to windward in puffs, and a soft mast-tip will bend in puffs allowing the leech to fall off. I think Bill made a very good point.
The lift of a foil should be carefully balanced against the sailarea (or rig type) you have. If you have increased your sailarea and moved the center of the sails, you might benefit from working on your daggerboards. First check the condition of the boards (scratches, nicks, dents etc.). Playing with mast rake can also be a good thing. But matching the mainsail (and jib luff curve) to your rig is what I think will give the largest increase in performance. To give an example, when the Tornado class needed an performance upgrade to stay in the games, they added a new sail package to the existing platform. It made the boat much faster (not to windward tough, just more powerful), but the foils and hulls was never altered. So the Tornado still sails with really inefficient centerboards with a shape defined back in the 60s. It is still one of the fastest beachcats around due to rig development (mast+sails) and the sailors skills. | | | Re: Dagger board question
[Re: Darryl_Barrett]
#108251 05/25/07 12:44 AM 05/25/07 12:44 AM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | That's not entirely correct Darryl. The positive effect of weather helm is real but not because you point higher to windward, you can't point higher without luffing/pinching the sails.
The reason a bit of weather helm helps windward performance is because you need to correct it with your rudder, otherwise you'd continue to round up into the wind, which we know is slow.
The force you feel on the tiller while holding your boat on a steady course (preventing it from rounding up) is caused by a force on the rudder blade.
This force on the rudder blade is pushing you to windward, which is good.
If ppl can't picture it, try experimenting on shore with the skipper sitting on the boat in the usual position holding the tiller extension so that the rudder stays straight and have the crew push on the leeward rudder box.
So instead of pointing higher, you aren't slipping sideways to leeward as much, which increases your VMG.
But hangon, having pressure on the rudder is slow because it is drag. The trick is finding the right amount of weather helm so that you provide some lift force to windward to reduce leeway angle but don't increase the drag caused by the rudder being off centre too much.
It's a tricky design problem but can be done fairly easily by trial and error by adjusting the rake and testing. | | | Re: Dagger board question
[Re: WindyHillF20]
#108254 05/30/07 12:34 PM 05/30/07 12:34 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | maybe it's not that he's going up... it's that you're slipping down more. Your daggerboards are just not as efficient as the Tigers. If you are thinking about putting Tiger boards on and just want to check it out without making a commitment to glassing them in then try using some shims. Imagine if you were making a prototype boat and wanted to make sure the placement of the daggerboard trunks. You would make bigger trunks than nessesary so you could move them around some, for and back as well as rake. Use some delrin 1/4 inch sheets. The bottom one will have to be fit unside the 18's daggerboard trunk with a cutout for the new board. The top can be screwed to the top deck so it can be adjusted. This way you will be able to balance the boat without the commitment to perfect placement the first time. Later, Dan | | | Re: Dagger board question
[Re: warbird]
#108257 06/05/07 12:24 PM 06/05/07 12:24 PM |
Posts: 169 Santa Barbara CA | Try Spartite, it's an epoxy mix used for replacing wedges at the partners on keel stepped boats. Plenty strong, pourable, and can be popped off later...
621
guests, and 207
