| Re: Morning of JPOR
[Re: BobG]
#108958 06/05/07 07:27 AM 06/05/07 07:27 AM |
Posts: 3,348 | ....."400 lb boat and hold the carbon fibre please". You guys are not the problem! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Those of us on the lighter end of the scale are. If "someone" puts down anchors, will that same "someone" remove them? And, whom will that "someone" be? You were probably too busy to notice, but an A cat, lashed to its trailer, mast down was undisturbed by all the drama. It was good meeting you, thanks for all your help. I'll try to get up your way in September.
| | | Re: Morning of JPOR
[Re: fin.]
#108959 06/05/07 10:05 AM 06/05/07 10:05 AM |
Posts: 5,590 Naples, FL | Given that a tropical storm was on its way, I guess hindsight would have warranted taking the mast down or anchoring the boat.
In reality, who really sets ground anchors for EVERY regatta? I've only set them on regatta weekends that had high wind to start with (or a storm front forecast). Is it not at least probable that an evening thunderstorm (at least in FL) could produce enough wind to damage boats?
| | | Re: Morning of JPOR
[Re: BobG]
#108960 06/05/07 10:11 AM 06/05/07 10:11 AM |
Posts: 1,187 38.912, -95.37 | If somone were to put to put down a long screw anchor in between the boats could you not tie a trap line from each boat to it cutting down on the amount of screws to set also set one on the exterior side of the first and last boat. What is normal here is to set the anchors under the bridle centre....."400 lb boat and hold the carbon fibre please". Bob, Clarification please...one anchor point in between each boat (at shrouds?) AND one per boat centered under the bridle? We're contemplating what exactly to do in our asphalt, mast up storage lot, already have the 4' helical anchors, permanent placement is under discussion with as many "plans" as cat owners. Thanks, John
| | | Re: Morning of JPOR
[Re: Seeker]
#108962 06/05/07 01:57 PM 06/05/07 01:57 PM |
Posts: 5,590 Naples, FL | I think I was at that JPOR. Thanks to the various weather experts, they got us off the water about 30 minutes before the heavens opened up
I remember frantically setting up a sand anchor (the big kind) and tieing off to the striker. Not that anything would happen to my 400 pound boat (N20), but I tend to overreact sometimes.
I think someone's boat (Tiger?) actually flipped backward over the rudders...
| | | Re: Morning of JPOR
[Re: _flatlander_]
#108963 06/05/07 02:11 PM 06/05/07 02:11 PM |
Posts: 833 St. Louis, MO, | Clarification please...one anchor point in between each boat (at shrouds?) AND one per boat centered under the bridle? We're contemplating what exactly to do in our asphalt, mast up storage lot, already have the 4' helical anchors, permanent placement is under discussion with as many "plans" as cat owners.
We have mast up storage on our lake. We tie the boats down on the trailers. We tie the trailers to the ground. We have two anchors drivin in about 3 feet. The anchors are about 6-7 feet apart and in the center of the parking space. We've never had a problem with a properly tied down boat with this system. We've had plenty of really bad storms come through too. Mike Hill | | | Re: Morning of JPOR
[Re: Mike Hill]
#108964 06/05/07 02:43 PM 06/05/07 02:43 PM |
Posts: 1,187 38.912, -95.37 | We have mast up storage on our lake. We tie the boats down on the trailers. We tie the trailers to the ground. We have two anchors drivin in about 3 feet. The anchors are about 6-7 feet apart and in the center of the parking space. We've never had a problem with a properly tied down boat with this system. We've had plenty of really bad storms come through too.
Mike Hill Makes sense, that would give the option to those who want to use chocks & dolly instead of trailers. If had used Bob's suggestion would be two per boat anyway (I think). Speaking of storms, the No Frills at Lewisville had a squall come thru Sunday @ 8am. Three 20's and two 17's ended up on the other side of the lake pounded into the rocks, not to mention the flipped boats on shore, some on trailers and still hitched to vehicles. Tomorrow's forecast here is 25 knots gusting to 35, enough to make me nervous with no anchors yet. Thanks for the comments Mike <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
| | | Re: Morning of JPOR
[Re: _flatlander_]
#108965 06/05/07 03:08 PM 06/05/07 03:08 PM |
Posts: 5,590 Naples, FL | Stop by any "box store" (Home Depot, Lowes, Wal-Mart) and pick up a pair. The big ones come in a box of two for about $12 ? Mine were about 3 feet? long and had a big flat auger style end with an eye hook on the other.
If you can get that bad boy sunk in all the way to the eye, I doubt anything will pull it out. I'd get a 1/2 broom handle to use for leverage (put in the eye) to screw the thing into the dirt.
| | | Re: Morning of JPOR
[Re: waterbug_wpb]
#108967 06/05/07 03:31 PM 06/05/07 03:31 PM |
Posts: 1,187 38.912, -95.37 | If you can get that bad boy sunk in all the way to the eye, I doubt anything will pull it out. I'd get a 1/2 broom handle to use for leverage (put in the eye) to screw the thing into the dirt. Speaking of "bad boys" we're renting one of these and tag team drilling all in one day ![[Linked Image]](http://www.tanakapowerequipment.com/Merchant2/graphics/00000001/ted_262hs.jpg) This is what the trailer rental outfits use to set their units in asphalt parking lots. Blows in a 4 foot anchor in about 5 seconds <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
| | | Re: Morning of JPOR
[Re: _flatlander_]
#108968 06/06/07 08:12 AM 06/06/07 08:12 AM |
Joined: Jan 2004 Posts: 216 Lakewood, Colorado MUST429
Posts: 216 Lakewood, Colorado | Several years ago, before we were aware of the easy to use and commercially available "sand anchors", we had a problem with boats blowing around at one of our local lakes druing weekend regatta's. One weekend in particular a mini twister went thru the fleet and several boats ended up in a pile. After that, when the days sailing was done, not only did some of the guys drop their masts, they also added 5 to 10 gallons to each hull. given that water weighs about 8# per gallon, the thinking was that 10 gallons in a hull made it highly unlikely that the wind could lift the additional weight. Then in the morning everyone pulled the hull plugs and let the safety ballast run out onto the beach. I am not advocating this as a solution instead of a sand anchor, just offering it as an idea if you are desperate for a margin of safety and do not have a sand anchor available. One other example, a couple of years later, I was trailering the boat between Laramie WY, and Medicine Bow WY, and we had a front quartering crosswind that was just brutal. My tow vehicle was rather narrow, and at one point I looked into the rear view mirror and the boat and trailer were flying a hull/wheel. Scared the bejeusus outta me, so after slowing down until everything was on the ground again, we stopped at the next gas station and added about 5 gallons per hull for the remainder of the trip. We didn't want to add too much weight for a couple of reasons one because of the slosh factor when changing speeds, two because of the load on the hulls where they were supported by the trailer, and three because of the load on the springs of the trailer itself. We also could have removed the trampoline, but, at the time, it just seemed like a lot less work to just add the water weight. Also, time was a consideration as it was late on a Sunday afternoon, we still had a long way to go, and Monday mornings came early after a weekend of racing. Anyway, just thought I would share an emergency solution that has worked in the past. It is not a perfect solution for many reasons, but it could be used in a pinch.
Stephen H-18 | | | Re: Morning of JPOR
[Re: MUST429]
#108969 06/06/07 09:39 AM 06/06/07 09:39 AM |
Posts: 5,590 Naples, FL | I screwed the sand anchors and tied my trailer/boat to them AND added about 5 gallons to each hull in preparation for hurricane Wilma. Boat/trailer didn't budge, despite 120 mph sustained (plus gusts) hitting it (we were near the eyewall).
I did orient the trailer in the estimated direction of wind, so the bows were pointed into the wind for the first 1/2 of the storm, and the sterns got it for the second (and stronger) 1/2 of the storm. I also removed the trampoline.
Thankfully, I parked it in an open lot, so there was little debris impact other than small/medium sticks and palm branches.
Having lived through that, I don't see any reason to sit through another hurricane listening to debris strike the house and screen enclosures self-destruct.
2,662
guests, and 431
