| Re: two part or one polyurethane paint???
[Re: tomthouse]
#109077 06/04/07 12:42 PM 06/04/07 12:42 PM |
Posts: 146 Crofton, MD | I would strongly recommend a two part finish. It is considerably harder and more resistant to chemicals, etc... I also noticed that the one part would wear much faster off the bottoms of the hulls from sliding cat tracks than the 2 part does. I would look at Interlux Perfection or I've also heard good things about the system 3 two part poly's. If you are going to go through all the trouble of sanding and prepping the surface, why skimp on the paint to be used? Perfection is about twice as much as the one part poly but I think the end result would be well worth it. Awl-Grip is also very good, but is a bit more difficult to use and about twice the price of perfection. Also, if you are going to spray, you need to make sure you have the right equipment and safety precautions (forced air respirator, etc...). Good Luck!
[Re: tomthouse]
#109079 06/04/07 05:50 PM 06/04/07 05:50 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | What condition is the original paint in? Is the color consistent, no damage and just needs to be shined up? Or does it have nicks, scratches or is it in need of repair in places?
Awlgrip, Imron are two Polyurethanes I'm familar with and they are excellent as one stage or one part paints. Two stage normally means a base coat (color) and a top coat (Clear). Now if your boat is like the first part of my question(just needs to be shined up) then you could sand the boat with like 600 grit and have it clearcoated with Imron. Like new finish. Or if you want to do a little fairing and repairs refinish it with one stage awlgrip or Imron.
Find someone in your area that deals with or uses these paints and ask them. Many Automotive paint suppliers carry Imron. Look for one that has Dupont products. Ask them who uses it in the area and go talk to them. Don't confuse Poly-urethanes with urethanes. Two very different animals.
[Re: catman]
#109080 06/04/07 08:18 PM 06/04/07 08:18 PM |
Posts: 805 Gainesville, FL 32607 USA | One-part anything is not a linked polymer- just dissolved solids. Simple example--Is there any one part epoxy? No.
4,625
guests, and 960
