| Production Blade F16 Prices #109856 06/19/07 03:00 AM 06/19/07 03:00 AM |
Posts: 7 | I just got a rough price estimate from Formula Catamarans for a Blade F16, "sail away". They said I was looking at around $24,000 (Australian Dollars). This seemed a little high to me, considering I can buy new A-Class, carbon fibre nomex hulls, with a carbon fibre mast, carbon foils etc. for $25,000.
Also Vector Sail Works has there Blade F16 at US$12,900 excluding import duty, and shipping it would be around $15,000 (Australian Dollars) so why does the Australian one have nearly a $10,000 premium? I can buy a new car for $10,000 granted it wouldn't be a good one! But you get my point.
Anyone know something I don't? | | | Re: Production Blade F16 Prices
[Re: taipanfc]
#109860 06/19/07 06:59 AM 06/19/07 06:59 AM |
Posts: 9,582 North-West Europe | Initial price goal for the Viper on the Australian market was 19.500 AUS$ I believe.
It will have to be shown in the next couple of months wether AHPC can achieve this goal.
[Re: chris11726]
#109861 06/19/07 08:09 AM 06/19/07 08:09 AM |
Posts: 1,479 Thailand |
Not sure how the Americans can do for so much less but for sure it's going to be difficult for the Aussies to break into the US market with Vector Sail Works in the picture.... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
[Re: chris11726]
#109862 06/19/07 08:48 AM 06/19/07 08:48 AM | Anonymous
| Anonymous
Unregistered | Also Vector Sail Works has there Blade F16 at US$12,900 excluding import duty, and shipping it would be around $15,000 (Australian Dollars) Not to disagree with your main point, but assuming you would have to pay 10% GST and with the AUD at less than 0.85USD, you're up for at least A$16.7k before you add shipping. With shipping, it's probably somewhere close to Wouter's suggested number for the Viper, but still a long way south of A24k. Mark. | | | Re: Production Blade F16 Prices
[Re: chris11726]
#109863 06/19/07 12:46 PM 06/19/07 12:46 PM |
Aus$ 24.000 is a high amount. I hope this is a typo or some conversative quote as it would directly translate into 15094 Euro's. (incl 10% Aussie taxes apparently)
The US build Blades are available overhere at 14.165 Euro's, fully fitted and ready to sail incl. 19% taxes and pick up at Zandvoort, The Netherlands.
Stealths upon pick up in the UK are 14.264 Euro's including taxes and a carbon mast. (This is the RACE version, so you'll want for nothing).
[Re: chris11726]
#109864 06/20/07 12:04 AM 06/20/07 12:04 AM |
Joined: Mar 2005 Posts: 322 South Australia Marcus F16
Posts: 322 South Australia | Chris,
As i mentioned to you the pricing was only an estimate & far from complete.
Currently a standard F16 will include.
1. Kevlar hulls made in Aus of the highest quality 2. Carbon reinforced foils & carbon stocks 3. Harken fit out 4. Purpose made beams, not round tubes & mast sections for beams 5. Dieform rigging. 6. Minimum weight.(around 103-106kgs complete) 7. Spectra & dyneema halyards & controls
From memory the Tiapan 4.9 was selling for a little under 20K last year & if you add some of the above items you will get closer to the 23-24K AUS mark.
When pricing for this boat is complete a full list of included item will be available on our web site.
Regards
Marcus Towell Formula Catamarans
Marcus Towell
[Re: chris11726]
#109866 06/20/07 04:04 AM 06/20/07 04:04 AM |
Posts: 9,582 North-West Europe | Theres more boat in an A Class (its longer) and there considerably light.
This is not really the case, is it ? The number of sails (add jib and spinnaker) and fittings (cleats for jib, spinnaker, snuffer, etc) are more for the F16. This additional hardware does add up in cost. Especially with the popular new line materials like D12 and Swiftcord. Cordage has never been this expensive. Also there is more volume enclosed in the F16 hulls as well more laminate, despite the fact that the hulls are shorter. Now the 75 kg A-cat is very light, but so too is the 107 kg F16 when you realize that it must withstand the bridle loads of a tight single forestay (jib) and a crew of two with the sheets and control lines cranked on hard (squaretop main). I would venture to say that with respect to hulls there isn't that much difference in required skill and quality level between an A-cat and F16. That F16 is highly loaded up. I broke 2 Taipan 4.9 mainsail halyard shackles in a row (2 weeks apart) and now I'm sailing with a Taipan 5.7 halyard shackle and that one is holding. The A-cat agent with a 30 history in A-cats was clearly surprised when I broke two of these so quickly after one another, and nothing else. Clearly the shackles weren't up to the F16 loads. This when they have proven to be sufficient for the standard Taipan. Imagine what this means for the loads on the hulls. Still, I agree with you that the price difference between a 25.000 AUD modern A-cat and 24.000 AUD for a modern F16 with an alu mast is of concern. But I think we need to wait a little longer till the Aussie Blade production has settled a little. The first boat build in a series (pilot) is always more expensive in cost. Afterall, AHPC's Capricorn F18 is 26.000 AUD. Meaning that the more high tech F16 is still 2000 AUD cheaper then that. Just for comparison a standard sloop (no spi) Taipan 4.9 in Aus is currently priced at 20.650 Aud. If this is to be upgraded to the level of the Aussie Blade F16 then you have to add : Kevlar hulls : 550 Carbon boards/stocks : 44 + 448 = 492 Spinnaker kit (+snuffer) : 2023 Conversion to selftacker : unknown but could well be zero as the hardware is about as expensive. Therefor Taipan 4.9 + spi with comparable level of upgrades = 23715 AUD This is very close to the (initial) 24.000 AUD quote for the Aussie Blade. Wouter
[Re: Codblow]
#109868 06/20/07 04:22 AM 06/20/07 04:22 AM |
Good point.
But the spinnaker requires that the hounds be not too low on the mast.
In my personal situation you must be aware that the top of my mainsail is cut relative full, afterall, I got one of the very first (prototype) F16 mainsails with a large head. So it isn't perfect and I have to pull it into the right shape a little more then the newer designs.
Additionally, alot of my extra load comes from the fact that a large squaretop head requires more sheet tension to set properly. Also my boat is wider then the standard Taipan and I carry a larger mainsail. When I broke the shackles I was regulary sailing it in conditions around 20 knots of wind with some 150 to 160 kg on board.
[Re: Marcus F16]
#109870 06/20/07 05:02 AM 06/20/07 05:02 AM |
Posts: 9,582 North-West Europe | To everybody, Allow me to row against the current so to say. After having done a significant amount of experimenting with fittings myself I have personally concluded that Harken fittings are not worth the added cost. Over time I learned that the right selection of components from different suppliers is both cheaper and superior in performance. The only parts for which Harken is favoured in my opinion are the mainsheet systems and the simple all metal blocks. The latter is incidently also the cheapest mini blocks or all suppliers. I refering to the 3 digit series microblocks. As they have all metal sides these blocks tend to withstand line abrasion extremely well, much better then the modern plastic blocks. This is especially important when the line loads are skewed, like with the spi halyard/retrieval lines. And for some reason Ronstan and the others just don't have a very good mainsheet system. In the way of ratchet blocks; Ronstan smartratchets (post 2005) and Riley autoratchets are excellent and better then the Harken blocks that tend to hold less and wear out quicker. In the way of cleats , especially the ones with guide rails, I strongly prefer the Ronstan fittings. They just work better and none of them has ever failed me, the Harken ones have a less then stellar rep sheet in my book. Also for the larger (plastic) blocks I'm now exclusively using the RWO, SailSure and SailSafe blocks, there are just at the same level as the best out there but halve the cost. Same for plain metal hardware like chainplates and eyestraps etc. Shackles etc are halve Wichard and halve RWO. Also I've replaced many (micro/mini) blocks by simple inexpensive stainless steel rings (probably Wichard or RWO). These foul up less as they allow slighlty bundled up lines to pass anyway and unless there is alot of load on the line they tend to add only very little friction. I think Ronstand RF5's (180 swivel cleat) and RF57's (360 swivel cleats with a base) are the best out there. I dislike the harken versions of them alot. The harken versions use alot of (plate) metal and this tends to wear down the lines or go "cling-clong". The Ronstan versions have all plastic housings and the excellent line guides which are simply better then the Harken metal versions. I found the Harken cam cleats to often fail at the springs, resulting in a "dead" cam. Additionally I really dislike with a passion the harken recirculating ball traveller systems. They always get stuck with sand and salt. The same for the spinlock cleats. Ronstan has the same "enhanced expression of disapproval" but also the 19 mm I-tracks with stainless steel wheeled traveller cars with stainless steel ball barings. I use this both for my mainsheet traveller and the selftacker rail. I love both to bits and I NEVER EVER use water to clean them out, this is just not necessary as they always work even when they had been totally submerged in sand and salt. They are also the most smooth running traveller systems I have ever encountered. For F16 mainsheet traveller system be sure to use the 6 wheeled traveller car as that one will hold up to any load you can put on it. Interestingly enough the 19 mm I-track system is also the most inexpensive traveller system available. The best and the cheapest ! For cordage I swear by the Marlow high grade 3 and 4 mm dyneema (500 kg and 750 kg breaking load). I used these for everything except the mainsheet and downhaul system. For the latter two (and only the portion that I hold in my hands) I use swiftcord. These dyneema lines are also rather inexpensive compared to D12 and other fashionable lines. I dislike spectra and kevlar lines with a passion as they have always failed on the least opportune moments. Dyneema has always pulled me though. I'm hanging of these 3 mm 500 kg dyneema line as traplines for about 7 years now and no mishap yet. Also these dyneema lines are easily stitched which is a good alternative to splicing the lines. All these things safe time, effort and money. I hope this help some people. Wouter
[Re: taipanfc]
#109871 06/20/07 05:10 AM 06/20/07 05:10 AM |
Posts: 9,582 North-West Europe | How did you get that price for a Taipan when they don't make them at all? Must be the last quoted price from mid '06 as I haven't heard that they restarted production.
Correct. Incidently the AHPC website still links to the Taipan 4.9 PDF file that contains the pricing. The date of this pricing is Oktober 2006 http://www.ahpc.com.au/pdf/AHPC%20Price%20List%20Taipan.pdf I know a friend who bought a Taipan in the low 300s sail number who didn't pay anywhere near that kind of price new for a stock Taipan. So I don't think the last quoted price of a Taipan is a good indicator.
It is the last known official pricing. Economic developments has increased pricing on alot of products over the last few years. Maybe the Taipan pricing was raised as a result of this as well. Maybe more so then the single digit production. Afterall, all the tooling, moulds and stock have long been payed for, so single digit production may not raise cost too much. For us Europeans the standard Taipan 4.9 with spinnaker was always 16.000 Euro's = 25.450 Aud at todays unfavourable exchange rate (less AUD per Euro). Shipping to EU was never really expensive for AHPC as these boats would just share a ride with the Capricorn or A-cat containers going over regulary. But anyway, this is a passed station. The Viper F16 quote will be the one to watch. Wouter
[Re: taipanfc]
#109872 06/20/07 05:37 AM 06/20/07 05:37 AM |
Posts: 461 Victoria, Oztralia | The Taipan moulds have gone over to Asia for production over there. So yes they still make them, I think some were due to be back here later in the year.
Although I haven't heard any prices being talked about, the price of the Taipan is supposed to be somewhat cheaper, with the asian built hulls.
Matt Harper
Homebuilt Taipan 4.9
[Re: chris11726]
#109873 06/20/07 05:42 AM 06/20/07 05:42 AM | Anonymous
| Anonymous
Unregistered | Hi Chris,
what Australian brand and manafacturer of A class are you quoting the price of? It certainly doesn't sound like the price for a Ashby Gelteck Flyer 2 that I have heard. I thought it was more like $30,000. It is allways important to know what you are comparing. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" /> | | | Re: Production Blade F16 Prices
[Re: mattaipan]
#109874 06/20/07 07:18 AM 06/20/07 07:18 AM |
And I heard from the managing director himself that the Viper F16 will be cheaper then the Taipan. Both are made in Thailand.
So I guess the rumour cirquit is a full tilt now. Best is to just wait for the dust to settle and go on the prices payed for the first batch of actually delivered boats.
Personally, I want to see the Thai build these boats down to 102 and 107 kg weight before I believe it. Cost reductions are never free; you have to pay for it somewhere !
[Re: ]
#109875 06/20/07 07:24 AM 06/20/07 07:24 AM |
Posts: 9,582 North-West Europe | I think the A-cat refered to is the AHPC flyer : http://www.ahpc.com.au/pdf/AHPC%20Price%20List%20A-Class.pdfHowever, I don't think this boat is produced anymore. Boyer quit and AHPC is said to act as a dealor network for The Tool A-cat by Wayne Mercer, these are not produced by AHPC themselfs. Geltek does the successor, the flyer 2 and I haven't heard anything about somebody else producing this AHPC Flyer. In my book this design is discontinued and the price quote is of april 2005 which is two years old. Didn't carbon prices rise significantly since then ? Wouter
1 registered members (FredL),
2,799
guests, and 283
