acetone to clean hulls? #10994
09/25/02 01:47 PM
09/25/02 01:47 PM
Charleston SC
h17windbtch6333 Offline OP
Charleston SC
i have a buddy who says acetone will knock off that filmy stain build up on the hulls. True? i have tried soft scrub and greased lightin'. suggestions?
Re: acetone to clean hulls? [Re: h17windbtch6333] #10995
09/25/02 01:50 PM
09/25/02 01:50 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
acetone won't harm the gellcoat, paint and decals are another story.
F-18 Infusion
#626- SOLD it!
Re: acetone to clean hulls? [Re: h17windbtch6333] #10996
09/25/02 05:04 PM
09/25/02 05:04 PM
Gulf Coast
tami Offline
tami  Offline
Gulf Coast
Or use oxalic acid bleach. It's commercially available under the Star Brite label as "Hull Cleaner"
sea ya
tami
Re: acetone to clean hulls? [Re: h17windbtch6333] #10997
09/25/02 05:07 PM
09/25/02 05:07 PM
catman Offline
catman  Offline
Try using snobol toilet cleaner. Its cheap and simple to use. Just wipe it on and leave it alone for about 5 min. and rinse. Not sure what kind of film you have. My hulls are white and they get a orangeish color after a while. The snobol makes them look like new. My other boat was painted white imron and it worked fine without harming the paint. Be carful though, use gloves and don't breath the fumes.....acid. Oh yea, it works great on toilets!
Re: acetone to clean hulls? [Re: catman] #10998
09/25/02 05:57 PM
09/25/02 05:57 PM
Sandy Hook, NJ Fleet 250
jonr Offline
jonr  Offline
On-Off from West Marine works great, you will need to use gloves and wax your hulls as soon as you finish the cleaning.
Re: acetone to clean hulls? [Re: h17windbtch6333] #10999
09/25/02 07:02 PM
09/25/02 07:02 PM
Sailor Offline
Sailor  Offline
If you have already used soft scrub then not much else will hurt fiberglass. I have used just about everything out there with varying to little success UNTIL I got the nerve to try snobol toilet bowl cleaner. For $1.39 at wally world it has worked better than anything sold at West Marine, E&B, Wally World, etc. Wipe it on, let it sit for a little while then hose it off. Then you must put on a couple of good coats of wax or you will be doing this again. I use the Teflon wax and love it on my P19 which looks as white as an egg!
Is Snobol only for white hulls, [Re: Sailor] #11000
09/26/02 04:26 AM
09/26/02 04:26 AM
DHO Offline
DHO  Offline
Or can it be used on colored hulls also? Will it fade colored hulls?
Re: acetone to clean hulls? [Re: Sailor] #11001
09/26/02 07:41 AM
09/26/02 07:41 AM
Charleston SC
Charleston SC
i tried acetone last nite. it doesnt work. i am talking about the 'over the years' build up stain. i will try snobol tonite. and then a wax. thanks for the suggestions y'all.
Re: acetone to clean hulls? [Re: h17windbtch6333] #11002
09/26/02 08:04 AM
09/26/02 08:04 AM
Todd_Sails Offline
Todd_Sails  Offline
If you use toilet bowl cleaner on your sailboat hulls.............................................
....you might be a redneck!
Seriously, sounds like a good technique, I'll be trying it on my ancient N6.0na, but I will miss all those stains. Maybe ol Bill should have used it on that dress!
F-18 Infusion
#626- SOLD it!
Re: acetone to clean hulls? [Re: Todd_Sails] #11003
09/26/02 08:42 AM
09/26/02 08:42 AM
I use a mixture of water, about 10% clorox bleach, and some dish soap. just rub on and keep it wet with the solution for a few minutes and hose off....works like a champ on the tiny black specks.
Re: acetone to clean hulls? [Re: Jake] #11004
09/26/02 08:59 AM
09/26/02 08:59 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
If you have a real stubborn stain you can try MEK (methyl Ethyl Keytone). It is available at any hardware store. USE GOOD GLOVES!!! The stuff is toxic. I have used it on gelcoat numerous times. I've never tried it on paint.
Mike Hill
H20 #791
Mike Hill
N20 #1005
Re: acetone to clean hulls? [Re: h17windbtch6333] #11005
09/26/02 10:18 AM
09/26/02 10:18 AM
Fulshear, TX
SGalway Offline
SGalway  Offline
Fulshear, TX
I used FSR from West Marine. It worked fantastically and didn't take long. By the time I was done rubbing one hull, the other was ready to be rinsed. I didn't wax afterward. Low and behold, after Ruff Riders, all the stains were back. I guess I get to do it again now...
Shannon Galway
P19MX
Shannon Galway
Fulshear, TX
YoNav! Flying Phantom
www.yonav.net
Re: acetone to clean hulls? [Re: SGalway] #11006
09/26/02 01:03 PM
09/26/02 01:03 PM
Sailor Offline
Sailor  Offline
FSR works ok, but Snobol works much better. I've never seen anything work as good with the tannin stains.
Steve
P19+spi 969
Re: acetone to clean hulls? [Re: Sailor] #11007
09/26/02 01:59 PM
09/26/02 01:59 PM
Syracuse, NY Hobie Fleet 204
Tom Korz Offline
Tom Korz  Offline
There is another Ox-acid cleaner available @ most hardware stores called ZUD. It works great
Re: acetone to clean hulls? [Re: h17windbtch6333] #11008
09/26/02 07:05 PM
09/26/02 07:05 PM
brobru Offline
brobru  Offline
...I use a combo of things to do my annual hull cleaning at haul-out time on my Hobie 33
...one step is to treat the hull with Muriatic Acid from my pool chemicals.....costs about $2.00 to do 60+ feet of hull ( 33 ish * 2 sides)...
......anything organic will be dissolved,..and be gone on the rinse...
.....WEAR GLOVES, EYE PROTECTION and MASK!.......have runnng water hose available in case of getting some on skin,....stand UPWIND when treating hull (...fumes..)
...just be careful and you will be fine........or forget it if handleing the product makes you feel uneasy..
Bruce
St. Croix
Re: acetone to clean hulls? [Re: catman] #11009
09/27/02 10:10 PM
09/27/02 10:10 PM
Bridge City, Texas
pirate_tx Offline
pirate_tx  Offline
Bridge City, Texas
what does the snobowl do to decals???????
Re: acetone to clean hulls? [Re: pirate_tx] #11010
10/01/02 01:06 PM
10/01/02 01:06 PM
Sailor Offline
Sailor  Offline
It had no effect on the P19 decals on my boat.
Re: acetone to clean hulls? [Re: Sailor] #11011
10/01/02 01:11 PM
10/01/02 01:11 PM
Speaking of decals.. anyone have a good way of getting rid of them? The pinstripes on my h17 are pretty ... well... not so much stripes.. more like dotted lines, and I think it would look alot better if I just got rid of them.... my buddy recommended a pinstripe eraser for cars, but I don't know how the heat buildup from the rubber friction would fare with the gelcoat.
Re: acetone to clean hulls? [Re: MauganN20] #11012
10/01/02 10:17 PM
10/01/02 10:17 PM
Sailor Offline
Sailor  Offline
try a razor blade. Hold it carefully and get it as flat as possible and watch you don't cut your gel coat. It works really well and I have done it many times to remove decals from boats.
Steve
Re: acetone to clean hulls? [Re: Sailor] #11013
10/02/02 09:32 AM
10/02/02 09:32 AM
Tampa, FL
dave taylor Offline
dave taylor  Offline
Tampa, FL
a bit of zippo lighter fluid on a rag will remofe the glue without damaging anything else
0 registered members (), 3,236 guests, and 277 spiders.
