| Re: Max Downhaul?
[Re: Wouter]
#110345 07/01/07 07:23 AM 07/01/07 07:23 AM |
Posts: 2,921 Michigan |
Well each mainsail is different of course and you'll need to find out what works for you.
Everybody has to do that.
I figure that is the case... and why should I care what the travel is if it does its job. I can have it full or flat using the DH. I ordered a new Glaser main ( last week so I can compare in another 4 weeks or so. BTW, I went with Glaser because people recommended it and although I am sure Ashby and Landy make great sails, I decided to stay more "local" in case there is an issue. Also ordered new spin from Glaser.
| | | Re: Max Downhaul?
[Re: PTP]
#110346 07/04/07 10:30 PM 07/04/07 10:30 PM |
Posts: 1,479 Thailand | Max downhaul? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" /> The ronstan numbers are 2 cm each. Typically I start fully powered at about "3" and adjust as needed from there "5" being the usable max. or everything is happening within about 4 cm. range. Anything more is redundant... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
| | | Re: Max Downhaul?
[Re: Gilo]
#110348 07/05/07 06:00 AM 07/05/07 06:00 AM |
We must all consider one thing here.
The superwing masts are rather flexible and as such the tuning and control of the mast top is always a play between the mainsheet, downhaul and the initial bend of the mast. If you just pull on the downhaul when the mast is straight on the beach. Then you will not be able to get very far. When you do it on the water where there is ample mainsheet tension producing on initial bend then you can get it very far.
The more the mast is bend initially, the easier it is to put more downhaul on.
It is not usefull nor wise to ONLY pull hard on the downhaul when the boat is on the beach head into wind and with a slack mainsheet. The only thing you are doing there is trying to damage your sail.
Therefor you should always adjust BOTH the downhaul and mainsheet together. This may not have to mean at exactly the same time but right next to one another nevertheless. Always start with the mainsheet when increasing the downhaul and start with the downhaul when decreasing its tension. Of course this is not necessary for small changes; we are talking big changes here, like trying to get to the max.
Gilo, on the water the mast will bang less from side to side as the mainsheet will be "on" and keeping the mast bend through the tack. Simply put not everything can be similated on the beach and this is one of those things.
| | | Re: Max Downhaul?
[Re: Gilo]
#110349 07/05/07 06:06 AM 07/05/07 06:06 AM |
Posts: 2,584 +31NL | Does anyone have pictures of superwingmasts with a lot of DH on it? I have pulled the DH hard on the beach and the upper forth (above the spreaders) ot the mast really bends a lot to the side .... When you tack it causes the mast to make a strange flip (before the tack he is bend to the right for exemple, so after it is bend to the left.) On the moment you tack all that power onto the mast switches from left to right, is this normal?
Regards, Gill How much rotation did you have when doing this? I would imagine if you where sailing with max downhaul the amount of rotation would be very little, and this might also influence the amount of "bending"that you mentioned. | | | Re: Max Downhaul?
[Re: Rolf_Nilsen]
#110351 07/05/07 10:41 AM 07/05/07 10:41 AM |
Posts: 9,582 North-West Europe | are you sailing trough tacks with a tight leech? I think not..
You'll be suprised of how much tension is still on the leech even when the mainsheet has been sheeted out. Remember you are sheeting out to get twist in the sail to help accelleration after tacking, not to lower the leech tension to full slack. I had an "eye opening experience" when a former olympic Tornado sailor was testing how flat he could make our new mainsail. Mainsails are tough sails taking very high loads!
If have been more then once surprised about how some "money's" have been able to break stuff through shear stupidity. One reason why I always tell all newbies to take care and think through what they are doing. My personally ? Yeah there have been occasions were I could play the bohemian raphody on my mainsail control lines. Wouter
| | | Re: Max Downhaul?
[Re: Rolf_Nilsen]
#110353 07/05/07 11:27 AM 07/05/07 11:27 AM | Anonymous
| Anonymous
Unregistered | Guys:
I have a computip on Hobie 17. Don't know how that compares to your wingmast? But what I have noticed on both it and the aluminum mast on the Mystere 4.3, is that if I have to much downhaul in light air the battens sometimes will stay inverted on the main and I have to bang it in the draft to get them to go over. Maybe I should be easing a little downhaul as I go thru tack? Any suggestions?
Doug | | | Re: Max Downhaul?
[Re: Rolf_Nilsen]
#110354 07/05/07 11:30 AM 07/05/07 11:30 AM |
Posts: 9,582 North-West Europe | I'm not going around chasing wraiths. I stick to what I said earlier. The downhaul and mainsheet are a combo and should be handled as such. On the water the effect that Gilo witnessed in his on the beach testing should be significant less because of the way the sail and leech remain tensioned while sailing.
| | | Re: Max Downhaul?
[Re: Gilo]
#110357 07/05/07 04:48 PM 07/05/07 04:48 PM |
Posts: 67 Netherlands | Hello Gill, Here are 2 pictures of an Ashby mainsail on a 2005 Blade. One with downhaul off and the other one downhaul (and mainsheet) full on. This range looks pretty good to me. Geert | | | Re: Max Downhaul?
[Re: geert]
#110358 07/05/07 05:28 PM 07/05/07 05:28 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | Great photos from Geert. I also have an Ashby main (although smaller); one thing I've noticed in the photos and on my own sail is that you can really flatten the sail. Glenn told me this is so that once you're up to speed you can flatten further and further to absolutely minimize drag and raise your top speed up wind.
| | | Re: Max Downhaul?
[Re: ejpoulsen]
#110359 07/06/07 02:20 PM 07/06/07 02:20 PM |
I need such a sail !
| | | Re: Max Downhaul?
[Re: Rolf_Nilsen]
#110360 07/06/07 06:08 PM 07/06/07 06:08 PM | Anonymous
| Anonymous
Unregistered | Doug,
I have not noticed the same thing with alu masts, quite the opposite actually. Without downhaul we might have to pull the boom over to windward forcefully to make the battens pop over. Sometimes when going downwind in light conditions we have cranked on the downhaul to make the battens pop over instead of yanking on the boom.
Rolf: May have to do with the fact I DON'T have a boom. Mystere 4.3 is a boomless rig. DOug
| | | Re: Max Downhaul?
[Re: Gilo]
#110362 07/07/07 05:13 AM 07/07/07 05:13 AM |
Okay,
Well good luck !
And remember each sail is different, you being one of the first Landenberger sails for the alu F16 mast. So you just have to look at how you sail shapes up will sailing and adjust it with small steps each time over a couple of weeks (multiple sailing trips).
One thing i found helpful (but I still need to do alot of tuning !) is to have streams fitted to the leech at :
-1- 0.5 mtr below the top -2- halve way on the leech -3- halveway between -1- and -2- -4- Halveway between foot and -2-
With these you can fine-tune the prebend and diamond wire tension.
You should be able to get all streamers to flow and flick behind the sail at about the same time. Then the whole leech is trimmed well. On my own sail I still have trouble getting the top and middle to stream at the same time.
Prebend (rake + diamond wire tension) is a starting point from where you use the downhaul and mainsheet to further tune you mainsail. It is not unreasonable to expect different prebend settings for different conditions. At first just try to find a good average. When you really start racing then find different settings for light winds, strong winds, medium winds and solo sailing. Often the first two can more or less be combined into one setting.
Good luck !
I still have to take out a week of stuff to get my rig right. And I don't know when I'll do that before the World Cup. I may just not have a chance.
| | | Re: Max Downhaul?
[Re: scooby_simon]
#110364 07/09/07 02:08 PM 07/09/07 02:08 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | With a bit of luck, I'll have some time theis weekend to take some pictures of varying amounts of DH and manisheet tension. Sorry, totally fogot to do this. Looking at the results of the ECPR did you forget it was a race aswell <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> MP*MULTIHULLS | | |
2,423
guests, and 262
