| Re: Hobie 20 Discontinued
[Re: C2 Mike]
#110541 06/29/07 06:17 AM 06/29/07 06:17 AM |
Posts: 12,310 South Carolina | This material must also be processed before it shelf hardens. Matt, what is "shelf hardening"? I agree that you can't justify maintaining production status of something you are selling just a dozen or so a year on. While the romanticists of the sport would want to believe that the manufacturers have some moral obligation to support the things we love, it's sometimes just not good business sense to do so. Also known as age hardening. Check out http://en.wikipedia.org/wiki/Age_hardening. It is particularly prevalent in areas where there are large changes in temperature. Age (or shelf) hardening of aluminum changes it's bending characteristics and makes the section more brittle. In a previous life I ran a company that curved and bent metals for all sorts of applications. One was aluminum bull bars for cars and trucks. A pack of ally tube that was open at one end and left outside for a month over summer was useless for bending even though it looked fine. The covered end would be fine but the end that was exposed to the weather would snap like a dry twig. Given time, the entire length would be the same even when it was covered. Tiger Mike p.s. yep - bored at work today! Wikipedia: From Wikipedia, the free encyclopedia (Redirected from Age hardening) Jump to: navigation, search
Precipitation hardening, also called age hardening or dispersion hardening, is a heat treatment technique used to strengthen malleable materials, especially non-ferrous alloys including most structural alloys of aluminium and titanium. It relies on changes in solid solubility with temperature to produce fine particles of an impurity phase, which impede the movement of dislocations, or defects in a crystal's lattice. Since dislocations are often the dominant carriers of plasticity (deformations of a material under stress), this serves to harden the material. The impurities, in fact, play the same role as matrix substances in composite materials. Just as the formation of ice in air can produce clouds, snow, or hail, depending upon the thermal history of a given portion of the atmosphere, precipitation in solids can produce many different sizes of particles, which have radically different properties. Unlike ordinary tempering, alloys must be kept at elevated temperature for hours to allow precipitation to take place. This time delay is called aging. Sounds like you guys need to store your raw aluminum extrusions indoors.
Jake Kohl | | | Re: Hobie 20 Discontinued/Open class
[Re: mmiller]
#110542 06/29/07 07:08 AM 06/29/07 07:08 AM |
Joined: Jan 2006 Posts: 195 Straight Outta Hell Boudicca
Posts: 195 Straight Outta Hell | Mr Schneider,
Mr Miller is correct in his assertion that Hobie should never have allowed the open class in the first place. The reason is obvious, if Mr Miller doesn't like to admit it: allowing the open class in allowed sailors to directly, empirically that is, compare different makes of boats. And it became obvious that certain boats were just...BETTER.
Once Pandora's Box was opened, it was a worse mistake to try to close it, though. What should have been done was to immediately produce comparable product. It was a long while before the H-20 came out, and it took Europe to produce the H-Tiger. What's done is done, though, and Hobie is not in the business of the Hobie Way of Life, they're in business to make money. The Hobie Way of Life ain't gonna feed Mr Miller and his family. Or keep the Alter clan in the manner to which they've become accustomed up there in the Great Northwest.
(BTW, Mr Miller, it would not have been that much trouble to oversize a sailplan to match the I-20, would it? It's common knowledge that all the wind in the US is taken up by Congress and the great suck of Texas, therefore the US tends to have lighter airs to sail in.)
As best I can tell, any interesting boats Hobie is producing is pretty much Hobie Europe. I've seen the ads in the French/Aussie/Euro multihull mags. Hobie's got boats over there I'd never even heard of, and I bet most of the US hasn't either. There's a pity.
This sig would be something witty, but the censors are against that.
[Re: mmiller]
#110544 06/29/07 07:43 AM 06/29/07 07:43 AM |
Posts: 195 Straight Outta Hell | Your Performance Cat list is incorrect.
Performance still produces the 5.0 (N500) the 5.7 (N570) and the 5.8 (N580)
Always one step ahead...
[Re: warbird]
#110545 06/29/07 07:44 AM 06/29/07 07:44 AM |
Posts: 117 Northern VA | Well, I agree with Mark that the Open class didn't help Hobie; it probably helped the local fleets with turnout and manpower, though, and banning it has definitely hurt the local fleets and divisions for the same reason. Somehow the idea of "let's get all the cats togther for a bigger event and have more fun" turned into an issue of "participation is declining; let's not have anything to do with other boats and that will save us." Well, my dates may be off, but seems like the 17, 18, and 20 have all been killed since we went Hobie-only. Too little, too late, and addressing the effects and not the cause. Probably shouldn't have even brought this up, because it's all been said many times before, but is cetainly is ironic at the least. Clearly we're on the path for Hobie-only to be Hobie 16-only, and a lot of us saw that coming. I'm betting that Hobie 16-only is not going to improve participation...
Last week I did an all-Hobie open class regatta with a 14, 2 16s, 3 18s, and a 20. It was surprisingly competitive (all sizes won at least one race on handicap), although clearly not as competitive as the 15 boat A-Cat fleet at the same event. Is this the future of HCA events? When is HCA going to encourage and promote a Getaway class? | | | Re: Hobie 20 Discontinued
[Re: Boudicca]
#110547 06/29/07 08:23 AM 06/29/07 08:23 AM |
Posts: 1,187 38.912, -95.37 | Well gee wizz, better add the Hobie 12/3.5 and H21 to the list of discontinued.
The thing is, and why we us (or at least me) inland/Midwest racers wanted to stick our heads in the sand and not see this coming is that Hobie sanctioned racing is the best available. Lakes aren't typically big enough for distance racing, it's all cans. This physical constraint also makes setting long enough weather legs impossible, and higher than national average wind speeds prevail on the plains from the Gulf to the Canadian border. I said earlier it seems there's a kite allergy, better stated, the time and effort in setup (when traveling to events) and short/er legs doesn't seem worth the "hassle", added to the fact we're talking about (as Stephen aptly put it) weekend warriors.
Other than Hobie sanctioned the choices are scarce. You say step out and try another boat. That may mean leaving it at a yacht club and racing the same few boats every Saturday, like was said, a couple guys trade off winning, and one finishes DFL every time...sound enticing? With the Hobie events that go on here at least there's enough boats that you can have a race within a race, in the typical 10 to 12 boat H20 start. That's what keeps OD racing fun for most.
We're spoiled with the speed of the 20, going back to the, comparitively speaking, weight sensitive 16 is not a pretty option. Us baby boomers' kids are racing now, have crewed on and are even buying 20's, that's why it hurts. Again, like Stephen said, we've raised these kids to think Hobie is the best boat. A boat with an overlapping jib is 'our niche'.
We can ride this out for five years or more. Suppose that's long enough to figure out viable alternatives. My fear is the racing will fragment and die in the interim.
[Re: _flatlander_]
#110548 06/29/07 08:34 AM 06/29/07 08:34 AM |
Posts: 1,459 Annapolis,MD | Well gee wizz, better add the Hobie 12/3.5 and H21 to the list of discontinued.
Both iterations of the Hobie-21, the SE and Sport Cruiser. Delve into the land of monos (the 33 is now being built by somebody else, anyone remember the Magic 25?) and there's a couple more. Power boats too... I'd actually love to pick up a new Hobie Power Skiff. Sorry... | | | Re: Hobie 20 Discontinued
[Re: mmiller]
#110549 06/29/07 08:59 AM 06/29/07 08:59 AM |
Posts: 1,459 Annapolis,MD | We actually sold the fox with aluminum masts after a VERY short attempt at using CompTips, so that wasn't it. I think the deal that killed it was here already. The I20 is sold in the USA with an over sized sail plan. The Fox was a Euro F20... we could have had an F20 fleet here in the US but for Performance making the I20 non-conforming.
See? Here we go again. The Fox's failure was Performance's fault for not conforming. A little bit of thought into the Fox rig and a US version of F-20 could have materialized with two manufacturers. The H-20 could have retired just like the 6.0 and Hobie would have a more modern boat as its replacement, and we wouldn't be having this conversation. The Tybee could be featuring both. Instead, it's Performance's fault for adjusting the product to the market place. Bad, bad, Performance. But - I want to say that I have the utmost respect for the Matt and the other Hobie dealers and techs that show up here. I hope they realize that what sounds like everybody on a hate fest aimed at them is really everybody frustrated and sad. We do love Hobie for what it has done for the sport. Those of us that have sailed and raced Hobies still have a soft spot in our hearts for the boats and the company. But the company and the community seem to be taking different paths. Yes, everybody here realizes that Hobie is doing really well as a company. We all realize that Hobie is answering a market call with the roto-molded boats they are selling, and that has been a great business decision for them. We understand that, we really do. And we're happy that the company is thriving. But it should be obvious now that the people in this community aren't as interested in those products for the most part. So when we hear statements that Hobie is a leader in the sport some just shake their heads. That's part of the frustration here as well. We're not currently interested in Kayaks. And they don't see Hobie as even desiring to focus on what this community is looking for anymore, which adds to the frustration. It may be just a matter of perception, but in so many matters, perception is reality. Anyway, I hope continued success for Hobie, Matt, and the dealers. I also look forward to the day when they decide to bring out an A-Cat, an F-16, a new 20', or an update to the Tiger. Out of that list, only the 20 is outside the company's concentration on the 12-18 foot market. | | | Re: Hobie 20 Discontinued
[Re: _flatlander_]
#110550 06/29/07 09:02 AM 06/29/07 09:02 AM |
Posts: 503 | Well gee wizz, better add the Hobie 12/3.5 and H21 to the list of discontinued.
We can ride this out for five years or more. Suppose that's long enough to figure out viable alternatives. My fear is the racing will fragment and die in the interim. Man, I love the spin boats, but Im with ya in that it is too much of a PITA to set up a spin boat for a one day local fleet race (guess Im lazy). Thats why I love the Wave, easy setup and sailing. After looking at the success of the Nintendo Wii, Im thinking Hobie may be on to something with pushing the Wave and Getaway. We need new sailors and a boat they will sail, and the bulk of them are not going to come from spin class boats, thats for sure. Heres my idea: every fleet in the US should also start a mirror Wave fleet. Build your Wave fleets with old and new sailors, and when your ready, COME TO THE WWF SUPER INTERCONTINENTAL WAVE CHAMPIONSHIPS, coming to Melbourne, Florida: World Wave Federation Intercontinental Wave Championships NOVEMBER 10th-11th, 2007 Hosted by Performance Sail and Sport with video coverage by Adventure Online TV at Pineda Park, Melbourne, Florida Lots of room for boats and a brand new community building. Lots of Wave sailing planned in between partying. Have a Wave, come! Dont have a Wave, come anyway, its going to be a big party! WWF Past Videos: http://link.brightcove.com/services/player/bcpid823619038?bclid=24526455&bctid=147010045http://link.brightcove.com/services/player/bcpid823619038?bclid=24526455&bctid=6165826http://link.brightcove.com/services/player/bcpid823619038?bclid=24526455&bctid=6141283The regatta champion will be the first name added to the new WWF Championship trophy, being custom designed by world famous artist Neitze-boy. The host WWF Club, The Space Coast Wave Crashers, has accepted a challenge by the South Florida Wave Crashers Union, led by Rick White. All other area Wave Crashers Associations are also welcome! More details to come! | | | Re: Hobie 20 Discontinued
[Re: bsquared]
#110551 06/29/07 09:14 AM 06/29/07 09:14 AM |
Posts: 3,528 Looking for a Job, I got credi... | Still looking for an answer to an ealier question; is there an active European or Australian turnout in a two-man 18-20 foot non-spin boat? Yes,In the UK I can think of 2. 1, Hurricane 5.9, however they are also sailed with a Spi and currently run their open meetings with both boats. 2, Dart 18. The Dart 18 is also sailed in mainland EU, Ithink there are a couple of Hurricane 5.9's around the rest of the EU too.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Hobie 20 Discontinued
[Re: mmiller]
#110552 06/29/07 09:40 AM 06/29/07 09:40 AM |
Posts: 263 SC | Matt please don't get me wrong I really do understand the decision. If I think about it from a strictly business perspective it makes complete sense. I just think it's a shame, Maybe shame on the US market, you have to sell boats or fold it up.
My only experience with the fox was at spring fever years ago. At that time the comptip seemed to be the complaint. I haven't seen one race since. I own a n-20, just makes sense for my weight and I do understand the sailplan difference. I think that might catch up with us as well if things move moreto the formula. I wouldn't mind a wave but not as my primary race boat.
I don't want to "shoot the messinger",sorry if it seemed that way. Unfortunately you have become the one with all the answers for some depressing news. Sorry.
Always borrow money from a pessimist. He won't expect it back.
[Re: bsquared]
#110553 06/29/07 10:52 AM 06/29/07 10:52 AM |
Posts: 9,582 North-West Europe | Still looking for an answer to an ealier question; is there an active European or Australian turnout in a two-man 18-20 foot non-spin boat?
I can think only of the Dart 18 catamaran, but I'm sure that that is not what you have in mind. Other then that, no. Everybody has gone to spinnakers, A-cat is no 2 person boat and the only non spi 2-up boat that isn't totally dead, besides the Dart 18's, are the Hobie 16's. Wouter
| | | I never understood this particular problem ...
[Re: _flatlander_]
#110555 06/29/07 01:01 PM 06/29/07 01:01 PM |
Posts: 9,582 North-West Europe | This physical constraint also makes setting long enough weather legs impossible, and higher than national average wind speeds prevail on the plains from the Gulf to the Canadian border. I said earlier it seems there's a kite allergy, better stated, the time and effort in setup (when traveling to events) and short/er legs doesn't seem worth the "hassle", added to the fact we're talking about (as Stephen aptly put it) weekend warriors.
I never understood this particular problem and I think many people see problems were none are to be found. Take for example the setup up time of a Hobie wave. How much faster is that then say uni-rigging a F16 or F18/Tiger ? Even with the latter two ONLY having the mainsail fitted, which will be faster and more enjoyable. The Wave or the uni-rigged F16/F18 ? How much more work it is to sloop rig (no spi) either boat compared to the H20 or TheMightyHobie18 ? I have my lazy days as well and often I sail my own boat with just the mainsail. I have even done that several times with 2 or 3 persons on board. The boat takes it in its stride, powers along nicely although at a somewhat slower speed (but not much slower). Why can't these midwest guys just pick a modern boat, one with a trusted future, and just agree among themselfves how it will be raced at this or that event. Then with respect to lakes. A normal race course is about 1 mile long and roughly 1/2 mile wide. All of the spi crews can work that big sail inside that box, several of us even singlehanded. So how small are your lakes, anyway ? I figure most aren't THAT small. High winds then, what are we talking about here ? sustained 20 knots and higher regulary ? If not then these lake sailors are not getting more then us Aussies and Dutchies. With the latter getting confused seas thrown into the mix as well. If they are all pulling spis in that (even when singlehanding) then why not not these lake sailors ? I strongly believe some of these lakes sailors we are referring to are just looking for reasons to not have to see the obvious. If a lake is large enough, the winds low enough and the crews willing enough to handle Hobie 18's and Hobie 20's then why should there be any reason to not sail a Nacra-20, F18/Tiger or a F16 without the spi and spi gear ? If that is still too much (I wouldn't know why) then just sail those boats without a jib. Several of us are doing that regulary in the F16 class and therefor so can you guys. I'm sure it can be done with the F18/Tigers as well. And if ever you get to the coast or a big lake with a weekend regatta then you can throw everything on get busy ! Can't do that with a Wave for example. Remember you can always easily downgrade a fully fitted boat, but not easily upgrade a resort boat. Just whatever you do pick a boat that has a future in Europe as all other are likely to vanish over the next couple of years. Wouter
| | | Re: One more time
[Re: Wouter]
#110556 06/29/07 02:37 PM 06/29/07 02:37 PM |
Posts: 393 Syracuse,N.Y | Hobie Cat Company-For profit business Hobie Class Association- Volunteer owners group NOT the same thing...
At no time(both when the company ran the class or when it switched to the private group) did either allow open boats.
Open boats in the Northeast USA started when some Hobie owners did not want to cut their mast and install a comptip. This was happening in Rochester and Buffalo, the two largest regattas in Div 16 at the time. Then as long as they were running a seperate start for non class legal boats they invited other cats to increase their numbers. Well, it didn't work out, both events started to lose boats in time and not grow as anticipated. In Syracuse we had some old salts who pleaded to not allow the open boats as it would fragment the class and we would see a loss of numbers instead of a gain. There were a number of reasons why this may have been the case. One of the ones that I saw was there were to many starts at a regatta. If you were in 16C fleet you might have to wait an hour for your start and then have a 30min. race. This turned off a lot of people who stopped showing up. I truly can't think of anyone over the last 15 years that switched to a differant brand boat and continued to race in this area. So the idea that sailors are seeing better boats when the events opened up(non sactioned) doesn't have a lot of merit. Having to many differant boats and fleet levels (Hobie company & HCA issue) along with adding two more open starts at the regatta's caused it to be no fun for the newbies. The consolidation of boats may turn out to be a good thing. Remember, there were open boats for 15 years. It didn't raise the numbers. We(Fleet 204)stuck with the Hobie only format. We were the largets Cat race in the country last year and are consistantly in the top 5 year after year. It's hard to argue with results.
By the way I am for the F18's sailing at the HCA events and breaking out manufactures at the F18 Nationals to crown brand champions along with the overall. I think the Hobie 16 and the F18's along with the A cat will have continued success and the others will come and go.
Pat Bisesi
Fleet 204
| | | Re: One more time
[Re: pbisesi]
#110557 06/29/07 03:27 PM 06/29/07 03:27 PM |
Posts: 1,187 38.912, -95.37 | Wouter I agree it is more of a perception than reality. I look at the time to set up the 20 as double that of the 16. There are varying degrees of busting your boat down that we don't need to hash out here (please?). Adding a spin to rig time varies from 5 to 30 minutes (depending on who you ask).
At last years Mid-Americas I witnessed (for the first time) Tigers "flying" downwind and thought "Damn...why aren't we ALL doing that?!?"
If the ladies, daughters and sons can handle the front end of a 20, they can also handle a spin...again perception. A Tiger with a self-tacking jib only and no spi would be like a step back to riding along on the 16. HF18SN (tiger no spi) 63.65, still faster than a 20. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Pat I like your idea of allowing MM F18's starting with Tigers. That leaves a lot of choice for product to put on the race course.
| | | Re: One more time
[Re: WindyHillF20]
#110560 06/29/07 04:32 PM 06/29/07 04:32 PM |
Posts: 11 | if by selling Getaways Hobie is getting back to the masses than they are doing the very right thing. cat sailing is not only about racing...as a matter of fact mybe 15% are racing...the rest are out there to have fun and enjoy themselfs in a reasonable price
Hobie Cat Dealer
Havazellet Hasharon
ISRAEL
1 registered members (Cholley12),
210
guests, and 61
