which mo betta? #110723
07/01/07 10:15 AM
07/01/07 10:15 AM
M
mitch Offline OP
mitch  Offline OP
M
for ocean sailing, waves chop wind etc. which mo seaworthy, the prindle 18-2 or the hobie 18? Any other relatively cheap 18 to 20 footers that can be easily single handed in ocean? #1 concern is bow buouncy and toughness, handleability for bigger water, thanks!
Re: which mo betta? [Re: mitch] #110724
07/01/07 10:20 AM
07/01/07 10:20 AM
you can find nacra 6.0s around these days relatively cheap. they are certainly ocean worthy (up to a point.. as is the case with any beach cat)
Re: which mo betta? [Re: PTP] #110725
07/01/07 10:23 AM
07/01/07 10:23 AM
M
mitch Offline OP
mitch  Offline OP
M
need to be able to singlehand more often than not, is a nacra 6 or 5.8 a bit powerful for such business?
Re: which mo betta? [Re: mitch] #110726
07/01/07 12:18 PM
07/01/07 12:18 PM
oops... read too fast. 6.0 too much to singlehand, esp in the ocean. sorry
Re: which mo betta? [Re: mitch] #110727
07/04/07 10:17 PM
07/04/07 10:17 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Both are great boats - A good friend of mine had a Prindle 18.2 at the same time I had my 18SX and I remember us both soloing the boats together in some reasonable wind.
Of the two you mention I'd lean towards the Hobie 18 for ocean sailing - a little more rocker, a little less power and greater tolerance of running up onto the beach at speed repeatedly (unavoidable in some ocean sailing locations). Both would work - the Prindle would have a slightly lower max wind for solo sailing than the Hobie 18, but would be faster on the occasions when you sail 2 up.
Neither boat can be solo righted in lighter wind without some kind of righting aid - such as a righting bag (either store bought or the heavy grade plastic trash bag). Righting solo in heavier wind may be possible with good technique and a well sealed mast - but I would not rely on this unless sailing with other boats who would be able to render assistance if required.
Hobie 18 used parts/sails etc may be a little more available as more boats were produced.
I would not recommend a modern 20' beach cat for solo sailing - these are typically too powerful in all but light wind for the solo sailor.
In the 18' category you may also consider the P18 classic. At 17' you have a couple more options - the Hobie 17 or Inter 17 (in a variety of flavors).
Be safe, have fun, sail fast.
Chris.
