| Re: Removing Vinyl Stickers?
[Re: TurboCat]
#112068 07/19/07 02:41 PM 07/19/07 02:41 PM |
Posts: 1,203 uk | Hair dryer with plastic scraper then some sort of solvent to take off goo that is left[I use a UPVC window cleaning solvent, petrol would do]
[Re: PTP]
#112077 07/20/07 05:33 AM 07/20/07 05:33 AM |
Posts: 15 Clear Lake,Texas | I recently removed the old decals from my Nacra 5.2. After using a razor scraper to remove the decal, I was left with the old glue underneath. After several attempts with various glue removers I had no luck. I then tried OFF mosquito spray. It worked great!!! I just sprayed it on and immediately scraped the glue off with a razor scraper and wiped off with a paper towel. After the decals was removed, I washed the boat with soap and water. OFF mosquito spray also removes permanant ink marker(can you say Sharpie?).They don't call this stuff OFF for nothing! And just think, we spray this stuff on our bare skin. I wonder if it works on tatoo's? hum....
Trey
Nacra 5.2 "Silver Bullet" #333 TCDYC | | | Re: Removing Vinyl Stickers?
[Re: Chris9]
#112078 07/20/07 07:51 AM 07/20/07 07:51 AM |
Posts: 606 League City, TX | 3m makes an adhesive remover to get the go off after you have removed the stickers part and it works well. This stuff works better than goof off, acetone or other solvents I've used. If its a really old decal then be patient - this is going to take you some time as they tend to become very brittle and only come off a little at a time. | | | Re: Removing Vinyl Stickers?
[Re: TreyG]
#112079 07/20/07 08:14 AM 07/20/07 08:14 AM |
Posts: 778 Houston | I then tried OFF mosquito spray. It worked great!!! I just sprayed it on and immediately scraped the glue off with a razor scraper and wiped off with a paper towel. After the decals was removed, OFF mosquito spray also removes permanant ink marker(can you say Sharpie?).They don't call this stuff OFF for nothing! And just think, we spray this stuff on our bare skin. If you are using a version of OFF that removes glue be real careful around things like sunglasses and watches. In general the active ingredient in OFF, DET, is a powerful solvent that will dissolve, among other things, polyester (gelcoat, sails, your Speedo, etc). Generally there is not enough of it to do any real damage but when you use high concentrations and add things to slow the evaporation you can start doing some damage. I don't have enough proof to start a lawsuit but I destroyed a pair of sunglasses and 2 watches started leaking after I switched to Sports OFF. No problems since I switched back to SkinTastic. | | | Re: Removing Vinyl Stickers?
[Re: carlbohannon]
#112080 07/20/07 10:11 AM 07/20/07 10:11 AM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | DEET--also causes seizures, so be careful <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
[Re: ejpoulsen]
#112081 07/20/07 12:50 PM 07/20/07 12:50 PM |
Posts: 1,203 uk | I tried using Nitromorse paint stripper once - not clever. Whole section of the hull went jelly-like.
[Re: PTP]
#112082 07/20/07 01:28 PM 07/20/07 01:28 PM |
Posts: 105 Bloomington, IN | I recently had to remove some relatively fresh sticker glue. Goo Gone did very little to it and I didn't have any acetone on hand, so I tried something called "Color Restore". It's a cleaner/wax/polishing compound combination that is made for brightening up oxidized gelcoat. Made quick work of removing the glue.
Jeff Tiger 849
[Re: ejpoulsen]
#112083 07/21/07 06:26 AM 07/21/07 06:26 AM |
Posts: 12,310 South Carolina | DET and DEET are different animals...(but often confused)
Jake Kohl | | | Re: Removing Vinyl Stickers?
[Re: ejpoulsen]
#112084 07/22/07 10:04 AM 07/22/07 10:04 AM |
Posts: 805 Gainesville, FL 32607 USA | DEET mosquito repellent has been used safely for 60 years, sparing millions of users from mosquito bites and mosquito-borne diseases (rare in the USA but not elsewhere). If you have a 12 month old child that weighs 20 pounds, do not put a whole, large bottle of pure DEET on him or her: that is how it causes seizures and/or death (unfortunately this has actually happened a few times). I was a USDA scientist at the lab where DEET was discovered in 1954. So far as know, problems have not been documented with reasonable use. Yes, DEET (more than the ethyl alcohol that it is generally dissolved in) happily dissolves glue, paint and many plastics. [What is DET????]
1 registered members (vasil),
453
guests, and 46
