Tornado - has it been done before? #113084
07/30/07 03:49 PM
07/30/07 03:49 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
I just picked up 72 Tornado that has straight mast. I was wondering if anyone tried to change spreaders on the mast and pre-bend it to fit newer sails.
Later I want to add spinnaker and I’m not sure if straight mast and spinnaker go together.
What should be the tension for the diamond wires with straight mast?
Thanx for any help
Kris
I20
Re: Tornado - has it been done before? [Re: Krisu13] #113085
07/30/07 05:27 PM
07/30/07 05:27 PM
New Hampshire, USA
windswept Offline
windswept  Offline
New Hampshire, USA
I think if you go to the tornadocat group on yahoo and ask this question you will get many answers.
Tom Siders
A-Cat USA-79
Tornado US775
Re: Tornado - has it been done before? [Re: Krisu13] #113086
07/30/07 05:44 PM
07/30/07 05:44 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I've done thios with an early '80 SailCraft mast.
There is nothing different between the pre-bend and soft-rig mast extrusion. The spreaders are different...prebends allow swept-back arms. You will need to replace arms from a soft-rigged setup with those from a pre-bend.
You need something like 30-70mm between the aft edge of the mast track and a straight edge place across the diamonds at the spread arm tips.
You then crank on enough diamond tension to get the luff of the sail to closely follow the mast track. The actual numbers on a Loos guage will vary depending on your spreader arms and even your diamond hound positions (which have changed design & locations over the years).
You may also find the main halyard hook at mast head will fail when you go to put on loads of downhaul in a breeze. The old soft rig was not as highly loaded and the top hook is not strong enough for the new loading.
Mike.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Tornado - has it been done before? [Re: Tornado] #113087
07/31/07 01:25 PM
07/31/07 01:25 PM
Chicago, IL
Krisu13 Offline OP
Krisu13  Offline OP
Chicago, IL
Thanks for the info
Kris
I20
0 registered members (), 7,891 guests, and 281 spiders.
