Page 4 of 4 1 2 3 4
Should show picture now [Re: Wouter] #11368
10/11/02 03:19 PM
10/11/02 03:19 PM
Kirt the picture was larger than 100.000 bytes ; it was 98 Kb
but ofcourse 1 kb = 1024 bytes and not 1000 bytes.
Click attachment on the left and guess how much this board weights.
Bite Me
Corrections [Re: RobLyman] #11369
10/11/02 08:55 PM
10/11/02 08:55 PM
Orange Park, FL
RobLyman Offline
RobLyman  Offline
Orange Park, FL
-mainsail w/ battens is 32 lbs.
-each hull weighs 209 lbs.
-main beam 73 lbs
-rear beam 67 lbs
front beam 27.5 lbs
-mast assembly (including spreaders, halyards, shrouds and other fittings) 122 lbs
daggerboards 25 lbs
rudder assembly 35 lbs
tramps 47 lbs
The boat is about 925 lbs w/ sails.
Re: Scales Don't Lie... [Re: Kirt] #11370
10/12/02 09:37 AM
10/12/02 09:37 AM
brobru Offline
brobru  Offline
Kirt,
If you do not mind, weight your items,...especially your daggarboards...
I follow the T 4.9 UNI site and study the tips that are there,.....I know that the particulars are T 4.9 specific but the priciples can be general to Uni rig catamarans,....
....for example,...certian Aussie Uni-sailors rig their mainsheet systems 'upside-down'...this season I am turning my mainsheet system ' upside down',...cleat at the top,......from a physics point of view,.....it SHOULD work better for your initial thrust is on the item ( the boom) you want to move,...
...and the initial relase is on the same item ( the boom),...
....face it,..that crossbar is never going to move,...well,..hopefully (..if it does,.then you are in real trouble..)
Bruce
St. Croix
I-17normal
Texel # 115
( a Hobie 16 is Texel # 116,..see how the I 17 normal can clean up in a 'open class'!)
Weights [Re: brobru] #11371
10/12/02 09:53 AM
10/12/02 09:53 AM
T4.9 daggerboards = just over 2 kg's / peice ;something like 2,1 kg's (about 4,5 lbs / peice)
Rudders about 1 kg / peice = about 2,25 lbs
Stocks about 400 grams = 0,4 kg = about 0,9 lbs.
I calculated crossbar at 750 grams = 0,750 kg = about 1,65 lbs
Complete rudder setup inc. crossbar = 3,5 to 3,75 kg's = about 8 lbs.
Kirt if you start measuring anyway can you also measure mast tip weight of a fully rigged mast exclusing halyards and the side/fore stay ? I already knows phill measurement but I need to have three sample to calculate the average it is impotant in our F16 evaluation proces. Thanks.
Mast tip wieght is defined at the weight felt at the hoist height of your mainsail (Just below the Hook) when the mast is perfectly horinzontal and supported on the very edge of its its base.
Re: Weights [Re: Wouter] #11372
10/12/02 04:22 PM
10/12/02 04:22 PM
brobru Offline
brobru  Offline
WOuter,
Thanks,......5 pound daggarboard huh............see, right there ( pair d-board T 4.9 vs pair of D-board I-17) is a 30 pound delta,........or almost 9% of the I-17 total weight..
thanks again,
Bruce
ps,..my mistake Texel H-16 # is 117
Page 4 of 4 1 2 3 4
0 registered members (), 2,742 guests, and 394 spiders.
