safety line for solo cat sailors #113638
08/06/07 05:26 AM
08/06/07 05:26 AM
Brisbane Queensland- Australia
Q
Qb2 Offline OP
Qb2  Offline OP
Q
Does anyone have a well tested setup for a safety line pack system to prevent solo sailors being separated too far from their cat if you go overboard and can't hold onto the mainsheet?
Re: safety line for solo cat sailors [Re: Qb2] #113639
08/06/07 11:16 AM
08/06/07 11:16 AM
http://www.catsailor.com/forums/sho...;amp;page=0&fpart=1&vc=1
Check my post, post number four. Ive been using it ever since. I run the mainsheet through this quick release shackle.
The bottom part of the shackle the part that does not open is attached to my harness. The top part, parts that opens is where my mainsheet runs through.
Ive been using it for around seven months now with good success. I do not get tangled up and the mainsheet is always right there were I need it. In my initial post, I say I would have to release it for every tack and gybe, well in actually that is not the case. Once I am shackled in, I do not release it and everything works just fine.
BIG NOTE
This shackle has been designed for use on human gear. This is not one of those quick release shackles that Harken or Ronstan builds.
Re: safety line for solo cat sailors [Re: Robi] #113640
08/06/07 11:31 AM
08/06/07 11:31 AM
I have several of those quick release shackles sitting in my garage from sailing monos long distances. I think I might try that. Robi- where/how do you attach it to your harness? Do you get tangled up in the sheet?
Seems like it might do a good job of helping in extra line control also. I loop the mainsheet over the trap handle to keep the excess line out of the water.
Re: safety line for solo cat sailors [Re: PTP] #113641
08/06/07 11:46 AM
08/06/07 11:46 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Where are the shackles shown in the photo available
Thanks
Re: safety line for solo cat sailors [Re: Hullflyer1] #113642
08/06/07 11:51 AM
08/06/07 11:51 AM
Pat, I attached the shackle to the right hip strap, just to the right of the hook when you have the harness on. No I have not been tangled up in anything yet.
Hullflyer - the attached photo is the quick release shackle I am talking about.
Re: safety line for solo cat sailors [Re: Robi] #113643
08/06/07 11:55 AM
08/06/07 11:55 AM
Robi,
what is the difference between this shackle and the ones Ronstan and Harken made? They look identical to me, except for the leash you have put on the release pin.
Re: safety line for solo cat sailors [Re: Rolf_Nilsen] #113644
08/06/07 11:59 AM
08/06/07 11:59 AM
Robi,
To be honest I have no clue. The one thing I noticed in the package of this shackle was it clearly stated "for personal use only" I guess this shackle is not designed to be used on anything else other than personal gear. IE like mountain climbing gear.
These shackles are used in the US Coast Guard by the rescue swimmers as a quick release from the helicopters rescue hoist.
I believe the harken and ronstan shackles are not designed to be use on personal equipment, but instead on sailing hardware.
Re: safety line for solo cat sailors [Re: Robi] #113645
08/06/07 12:06 PM
08/06/07 12:06 PM
Or perhaps not on a yacht, or perhaps just a liability notice? <img src="http://www.catsailor.com/forums/images/graemlins/crazy.gif" alt="" />
Anyway, neat system. Something to ponder for solo sailing. Have you tried releasing it under load? I know some kitesurfers have used similar shackles and been unable to release under load. The loads are quite large when you are being towed behind your boat. Your boots _will_ be sucked off if you fall off at speed. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: safety line for solo cat sailors [Re: Rolf_Nilsen] #113646
08/06/07 12:12 PM
08/06/07 12:12 PM
No I have not had to release it under a load. I have not been a situation where I have had to release it yet.
Also considering that rescue swimmers with all their gear on can weigh upwards of 220+ lbs and they have used it successfully I do not see how I can run into problems.
Re: safety line for solo cat sailors [Re: Robi] #113647
08/06/07 12:18 PM
08/06/07 12:18 PM
I use whichard. It does release under a load.
http://www.apsltd.com/Tree/d270000/e267100.asp
Re: safety line for solo cat sailors [Re: Robi] #113648
08/06/07 01:00 PM
08/06/07 01:00 PM
test it;
A) hang yourself from tree
B) pull pin
Re: safety line for solo cat sailors [Re: Jake] #113649
08/06/07 03:44 PM
08/06/07 03:44 PM
Jake,
That may demonstrate its usability, but I doubt you will have the "motivation" when just hanging from a tree. Put yourself behind the boat being dragged underwater (backwards), and I will venture a guess you'll have more "motivation" to pull that release. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: safety line for solo cat sailors [Re: Jake] #113650
08/06/07 05:21 PM
08/06/07 05:21 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
test it;
B) pull pin
How high?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: safety line for solo cat sailors [Re: hobie1616] #113651
08/06/07 05:47 PM
08/06/07 05:47 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
If you actually do it make sure that you hang high enough up so that when you drop you remove yourself from the gene pool...
Re: safety line for solo cat sailors [Re: gree2056] #113652
08/06/07 07:01 PM
08/06/07 07:01 PM
hobie1616 Offline
hobie1616  Offline
Gosh, not even a <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> or a <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />.
Re: safety line for solo cat sailors [Re: hobie1616] #113653
08/06/07 07:26 PM
08/06/07 07:26 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I meant to add one!
Re: safety line for solo cat sailors [Re: gree2056] #113654
08/06/07 10:52 PM
08/06/07 10:52 PM
WEST. MICH. USA
DVL Offline
DVL  Offline
WEST. MICH. USA
You guys are funny <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: safety line for solo cat sailors [Re: Jake] #113655
08/07/07 01:52 AM
08/07/07 01:52 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
Now what am I supposed to do?
B) pull pin
F18
Team Seacats
Re: safety line for solo cat sailors [Re: hobiegary] #113656
08/07/07 04:32 AM
08/07/07 04:32 AM
Q
Qb2 Offline OP
Qb2  Offline OP
Q
What a great idea, hadn't thought of using that type of shackle. I will get one and adapt it to my harness.
Re: safety line for solo cat sailors [Re: Rolf_Nilsen] #113657
08/07/07 01:11 PM
08/07/07 01:11 PM
CA
Glenn_Brown Offline
Glenn_Brown  Offline
CA
I've found that when you use Ronstan Shackles with small diameter Prussik knots on chicken lines, the shackle will open fine under load, *BUT* the small diameter line can catch on the fat tip of the open shackle, so you will not be free even though the shackle is open!
The problem is that the shackle arm is skinny compared to the tip. The pictured shackle does not seem to have this weight-saving (and safety sacrificing) "skinny arm" feature.
--Glenn
0 registered members (), 436 guests, and 52 spiders.
