| Re: Removing foam from mast *gahh*
[Re: Rolf_Nilsen]
#113895 08/07/07 04:07 PM 08/07/07 04:07 PM |
Posts: 902 Norman,OK | Doesn't gasoline eat most foams... it is all expensive but try it out.
[Re: Rolf_Nilsen]
#113896 08/07/07 04:20 PM 08/07/07 04:20 PM |
Posts: 12,310 South Carolina | yup - acetone. I believe gasoline/petrol may do the same (but leave a bit of a smell). Regardless, that's going to be a gooey mess.
Jake Kohl | | | Re: Removing foam from mast *gahh*
#113897 08/07/07 04:34 PM 08/07/07 04:34 PM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker
Posts: 695 Ft. Pierce, Fl. USA | Dig some of the foam out and try different solvents in a can or cup before pouring a whole lot of anything down the inside of the mast. That foam may be a lot more chemical resistant than you think. Any way you slice it you are going to have a very time consuming caustic mess. You might want to try and remove as much of the foam as possible by mechanical means before resorting to chemicals.
Regards, Bob
[Re: Seeker]
#113898 08/07/07 04:35 PM 08/07/07 04:35 PM |
Posts: 12,310 South Carolina | Dig some of the foam out and try different solvents in a can or cup before pouring a whole lot of anything down the inside of the mast. That foam may be a lot more chemical resistant than you think. Any way you slice it you are going to have a very time consuming caustic mess.
Regards, Bob Good point...not to mention explosive...imagine napalm.
#113899 08/07/07 04:40 PM 08/07/07 04:40 PM |
Posts: 695 Ft. Pierce, Fl. USA | Do you know anyone who has a 4000psi Water pressure cleaner?...put the Zero degree tip on it and you probably could get more of it out than any other way...more than using chemicals which will leave a thick goo all over the sidewall that you will never get out, That goo will greatly increase the weight of the mast.
With the pressure cleaner you will eat right thru it and eventually blow it right out the other end...if it can strip the flesh right to the bone on a human it will annihilate the foam.
Regards, Bob
[Re: Seeker]
#113900 08/07/07 05:15 PM 08/07/07 05:15 PM |
Posts: 3,528 Looking for a Job, I got credi... | Rolf,
Is it DIY foam or is it Epoxy foam ?
If it's the expanding DIY foam, that can dry as hard as nails (but the pressure washer might do it)
If it's poly foam than swearing at it might remove it <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Epoxy foam could be a major PITA !
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Removing foam from mast *gahh*
[Re: Rolf_Nilsen]
#113904 08/08/07 09:40 AM 08/08/07 09:40 AM |
Posts: 851 US Western Continental Shelf | More brainstorming here:
1) Use a drilling rig that is used to drill a well.
2) I'm thinking of a sewer drain razor cleaner. I believe that there are some that are spring loaded and compliant to conform to the size of the drain pipe.
I wonder if turned slowly enough if it could conform to the varying diameter of an oval mast. I also wonder if the rivets will allow the tool to pass.
If this method was used, I would go very slowly while trying not to get snagged on rivets.
3) Apply a hot iron to a sample of the foam to see if it looses it's adhesion and shrinks. If so, perhaps an electric charge could be used at each end of the mast to send a current from one end to the other to heat the entire mast evenly.
A variable voltage generator as used by home made hot wire foam cutters would probably work well.
Then perhaps you could press the entire core out from the top to the bottom, while it is hot and in a state of surface melt.
I'm curious if you have an estimate of how much all that foam weighs.
GARY
Santa Monica Bay Mystere 6.0 "Whisk" <--- R.I.P. | | | Re: Removing foam from mast *gahh*
[Re: David Parker]
#113907 08/08/07 11:30 AM 08/08/07 11:30 AM |
Posts: 1,884 Detroit, MI | P.S. Don't confuse MEK with MEK peroxide catalyst used with epoxy resins. You mean "polyester resins". | | | Re: Removing foam from mast *gahh*
[Re: David Parker]
#113910 08/09/07 08:11 AM 08/09/07 08:11 AM |
Posts: 778 Houston | Try MEK, methyl ethyl ketone (butanone). It is less volitile and is very similar to acetone with respect to dissolving foams. Thanks for the info on MEK. I will try it. Less volitile is very important during August in Houston. | | | Re: Removing foam from mast *gahh*
[Re: carlbohannon]
#113911 08/09/07 06:11 PM 08/09/07 06:11 PM |
Joined: Jun 2004 Posts: 502 Port Noarlunga, SA, Australia Darryn
Posts: 502 Port Noarlunga, SA, Australia | If you scratch or gouge the inside of the mast with metal removal tools it may fail at those points.
I would try hammering sharpened plastic storm water pipes through the mast, repeatedly removing and punching out the foam core that will fill the pipe. After mechanically removing as much material as possible I would try high pressure water but I suspect the foam in the middle wont be removed by this method. In that case, with the mast vertical, sealed and with most of the foam already removed mechanically I would fill it with the cheapest solvent that has been proven to dissolve the foam, leave sit for 24 hours the drain it and blast it out with water.
This job will make a huge mess, especially the solvent aspect, I would consider leaving the foam if the performance impact is negligiable.
Interesting problem to solve using tooling available at home.
Darryn Mozzy 1782 | | |
16,262
guests, and 1,190
