| Re: F18 Crew combined weights
[Re: Mappy]
#113925 08/08/07 02:57 PM 08/08/07 02:57 PM |
Posts: 3,116 Annapolis, MD | Hmm... You should sail the boat in those conditions.. No if's ands or buts... you will notice a big difference compared with your 6.0. Your pucker factor will vary.
The rig is not optimized for normal North American sailing seasons. (That is why Nacra introduced the first F18, with a taller stick in the NA market before dropping this idea with their F18 and Infusion lines to keep with Tiger in the USA market).
The appeal of the F18 class is multiple builders, good solid boats and lots of buoy class racing in a couple of regions in the USA and the ability to customize your sails for your mast and team weight..
The class would list performance in the 4 to 10 knot range well down the list of selling points. 12 knots and up... much different story.
Bottom Line.. you seem to weigh the BOAT more then CLASS RACING in your choices... Sail the boat in the conditions you normally see.
Your alternative would be a Nacra 20....
Always fun to search out and sail OPBs!
crac.sailregattas.com
[Re: Mappy]
#113926 08/10/07 04:45 AM 08/10/07 04:45 AM |
Posts: 9,582 North-West Europe | Interestingly enough, non-US areas are much less hung up on being featherweights when sailing the F18's. In fact F18's are raced hardest by crews in the range 150-165 kg (330 - 365 lbs), which are predominantly all male crews. But overall the fleet covers a very wide weight range, from 125 kg to 175 kg and most are doing pretty well. So I don't you have much to worry about.
Pretty much all current F18 designs carry weight well.
2,475
guests, and 285
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
