Downhaul #114002
08/08/07 11:49 PM
08/08/07 11:49 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Currently on my solcat 18 I have a 4to1 downhaul that is the original system . i have been reading Rick Whites racing for the 90s in which it says that downhaul is one of the , if not the most important sail adjustment so I would like to upgrade.
Now I understand that I would need to get a gooseneck, and I assume that a hobie GN will fit my mast, it is currently fitted with a solid , immoveable, mount for the Boom.
All of that I can figure out. I think
The question I have has more to do with the attachment to the sail.
I have a Hobie sail with an eye just above the first batten, about 3" above the foot of the sail.
If I hook up an 8/1 system will this eye hold? or do I need to add a plate set to the foot of my sail?
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: Downhaul [Re: AzCat] #114003
08/09/07 06:30 AM
08/09/07 06:30 AM
Where is the downhaul attached now? The eye above the first batten sounds like a reef point to me.
Re: Downhaul [Re: PTP] #114004
08/09/07 08:16 AM
08/09/07 08:16 AM
France
pepin Offline
pepin  Offline
France
On a H16 the sail attaches to the top of the boom, the downhaul attaches to the botom of the boom and the boom slides up and down in the luff track with the sail.
Re: Downhaul [Re: AzCat] #114005
08/09/07 08:53 AM
08/09/07 08:53 AM
Graham, NC
WindyHillF20 Offline
Graham, NC
the hobie 18 uses an eye in the sail for downhaul. There is a 8-1 or 6-1 downhaul system available from Murray that works nicely. Requires a sail track below the boom to install it.
Re: Downhaul [Re: WindyHillF20] #114006
08/09/07 06:44 PM
08/09/07 06:44 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
so then what your saying is that the eye that's there will hold and not rip out when I yank on that 6 or 8 to 1 downhaul. It is set in there pretty good, and that is the only place to attach downhaul, I just dont want to rip the foot off the sail.
oh, and it is a hobie 18 sail.
Re: Downhaul [Re: AzCat] #114007
08/10/07 01:07 AM
08/10/07 01:07 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
If it rips have it sewn back up with strengthening. Won't cost much.really what you are doing is pulling the bolt rop. So check to see how well you think the sail and the grommet is engeneered together.
Re: Downhaul [Re: AzCat] #114008
08/10/07 09:51 AM
08/10/07 09:51 AM
Graham, NC
Graham, NC
If its an 18 sail then its designed for downhaul at that point. Has a batten below it.
Re: Downhaul [Re: WindyHillF20] #114009
08/10/07 10:49 AM
08/10/07 10:49 AM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Michael,
I think I saw a picture of your boat on a billboard on I95 in Florence SC, know anything about it? It was definitley a TheMightyHobie18 with a black and white spin, isnt that what you have?
Re: Downhaul [Re: dave mosley] #114010
08/10/07 12:00 PM
08/10/07 12:00 PM
Graham, NC
Graham, NC
Yep, I understand it is my boat. Don't know who took the pic or why it is there. I haven't seen it but friends have. I would like to get a photo of it soon.
Re: Downhaul [Re: WindyHillF20] #114011
08/10/07 09:44 PM
08/10/07 09:44 PM
John_C Offline
John_C  Offline
I don't think that increasing the downhaul tensioning ability for that sail is really necessary. The original Hobie 18 dacron main is pretty flat to begin with, and over-rotating the mast will do the rest. If I remember right Ken Marshack experimented with tensioned diamond wires/raked spreaders and downhauling a long time ago and abandoned it. I believe that the Cat Sailing 90's book is refering mostly to more modern cut sails that start with a lot of draft that you can remove as needed with the downhaul.
John
0 registered members (), 365 guests, and 57 spiders.
