Daggerboards wont stay down #114181
08/10/07 09:09 AM
08/10/07 09:09 AM
Bjärred, Sweden
Pontus_Lofgren Offline OP
Bjärred, Sweden
I have some problems with the daggerboards on my Stealth. The problem is that they won’t stay down, it is like the water is pressing them up. Does anyone have some suggestions of how this could be avoided?
Stealth F16 NED 535
Re: Daggerboards wont stay down [Re: Pontus_Lofgren] #114182
08/10/07 09:21 AM
08/10/07 09:21 AM
john p Offline
john p  Offline
Pontus
the problem is that they float up, there should be a pice of elastic that goes from the edge of the trampoline where the trapeze wires go in, to the shroud, that holds them down.
John Pierce
[email][email protected]
/email]
Re: Daggerboards wont stay down [Re: john p] #114183
08/10/07 11:15 AM
08/10/07 11:15 AM
Pontus
I had that problem. They would fall down in the windward hulland pop up in the leeward hull. I put a few pieces of thick sticky back felt at the bottom of the well (the kind that goes on the bottoms of furniture) and that solved the problem. I think the bungee to them would work also but that is yet another piece of line crowding up the tramp.
Re: Daggerboards wont stay down [Re: john p] #114184
08/10/07 04:34 PM
08/10/07 04:34 PM
Bjärred, Sweden
Bjärred, Sweden
John, do you have a photo of this? I don´t really understand how this is supposed to be.
Stealth F16 NED 535
Re: Daggerboards wont stay down [Re: Pontus_Lofgren] #114185
08/11/07 10:09 AM
08/11/07 10:09 AM
look at the boat and find one of the eyes on the side of the hull that when you have a line from the shroud, it goes over the slot for the dagger board. Put a bit of bungee or shockcord from this eye and then tie it around the shroud plate. The shock cord needs to be tight to gold the plate, but not too tight so you cannot streach it to let the plate out. The shockcord just lies on top of the top of the plate keeping it down.
Re: Daggerboards wont stay down [Re: scooby_simon] #114186
08/22/07 01:25 PM
08/22/07 01:25 PM
Bjärred, Sweden
Bjärred, Sweden
Thanks, but an image explains more than a thousand words
<img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Image anyone?
Stealth F16 NED 535
Re: Daggerboards wont stay down [Re: Pontus_Lofgren] #114187
08/22/07 01:46 PM
08/22/07 01:46 PM
here you go.
Looking at the image, the shockcord needs to be tighter and I have also re-rigged this around the next aft eye so it goes over the middle of the plate case, it is also rigged under all the other ropes:
0 registered members (), 2,935 guests, and 239 spiders.
