| 2 questions ? #114277 08/11/07 01:47 AM 08/11/07 01:47 AM |
Joined: Apr 2007 Posts: 432 McCrae Y.C. Mornington Peninsu... Simon C OP
Posts: 432 McCrae Y.C. Mornington Peninsu... | Hi All,
I'm replacing my floppy orange conduit tiller. Apart from being too flexible, it was too short.
I'm 6'4" and I worked out that fully extended on trap with weight up front for working in a stiff breeze, I woud need 3m's. It does look somewhat long though. Is it too long?
2nd Question.... Anyone going to Sugarloaf tomorrow?
Simon Taipan AUS341
| | | Re: 2 questions ?
[Re: Simon C]
#114278 08/11/07 03:24 AM 08/11/07 03:24 AM |
Posts: 461 Victoria, Oztralia | Hi Simon
It sounds long but it may not be, try it and see how you go, I can't give a measurement for mine, but remember when I layed it straight, it would sit in the 'V' between the diamond wire and the mast, I think by probably 200-300mm.
My tillers were half aluminium and half grey conduit, if you fell off the boat or capsized and somehow bent the tiller over the side of the hull it wouldn't break, but it was stiffer than all conduit.
Heat the end of the conduit, slide in a piece of aluminium, and whack in a pop rivet or two.
Regards
Matt Harper
Homebuilt Taipan 4.9
| | | Re: 2 questions ?
[Re: mattaipan]
#114279 08/11/07 03:37 AM 08/11/07 03:37 AM |
Posts: 393 Camden NSW | My tiller was 3 meters, but I cut it down buy about 200-300mm and Im 5"11
And no Im not going to sugarloaf tomorrow, a bit far for me to go <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
William | | | Re: 2 questions ?
[Re: wildtoy]
#114280 08/11/07 04:10 AM 08/11/07 04:10 AM |
Posts: 432 McCrae Y.C. Mornington Peninsu... | Thanks Guys..
Both your comments point to about 2600 - 2800mm, so I'll start with 2800. I'm using 20mm Bunnings stuff as at the price, I can have a spare ready to go. It seems much better than conduit but if it's a bit fragile come capsize time I'll try your solution Matt.
I also put a longer mainsheet on today as the original was also too short. Could end up in a real mess with rope and tiller everywhere if I'm not careful <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Simon Taipan AUS341
| | | Re: 2 questions ?
[Re: Simon C]
#114281 08/11/07 10:26 AM 08/11/07 10:26 AM |
Posts: 205 Melb. Aust | Sugarloaf tomorrow - There with bells on.
I just checked the lake level - 49% <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
And weather is a few showers and a balmy 13 degrees. Hope there will be a bit of breeze as well. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Trevor
Mozzie 1828 ' ' Sugarloaf Sailing Club Melbourne
| | | Re: 2 questions ?
[Re: Trevor]
#114282 08/15/07 06:47 AM 08/15/07 06:47 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | 2.4m 16mm dia aluminium tube - cheap and light. Bends and straightens once (or twice if you are lucky) but doesn't snap when you go over the side with it.
Tim Shepperd Mosquito 1775 Karma Cat
| | | Re: 2 questions ?
[Re: dkd]
#114284 08/20/07 03:42 AM 08/20/07 03:42 AM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | simon, from many years of sailing 14 skiffs, which involves the constant replacement of broken tiller extensions! we found the most durable aluminium was 16mm with a thicker wall thickness rather than 20-22mm with thinner wall thickness. the 16mm would always be able to be rebent with a knee at the gybe mark!!!
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
| | | Re: 2 questions ?
[Re: Simon C]
#114285 08/21/07 07:34 AM 08/21/07 07:34 AM |
Joined: Jan 2006 Posts: 556 Somers, Westernport Bay, Victo... Peter_Foulsum
Posts: 556 Somers, Westernport Bay, Victo... | Simon,
I may be able to get some aircraft strength aluminuim alloy tube. My tiller extension is made from this stuff and you can bend it by applying some considerable loading and it just bounces straight back. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Let me know if you want me to follow up on this.
Peter
Mosquito 1814 Macka Mozzie
477
guests, and 50
