H17 tramp installation question #11453
10/07/02 10:07 PM
10/07/02 10:07 PM
PSAILOR Offline OP
PSAILOR  Offline OP
I am about to install a 2-piece bias cut tramp on my H17 and was wondering if anyone had any experiance with the lacing. I am thinking lace the center tight, then tie it tho the corners of the beams. Any thoughts would be apprecated.
Thanks
Re: H17 tramp installation question [Re: PSAILOR] #11454
10/10/02 09:59 AM
10/10/02 09:59 AM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
I have laced several 2 piece tramps--you can't start at one side and work your way to the other. The small lacing strip moves to the side you start with and gets off center. I found that if you use 2 ropes and start from the outside and work your way in, you get a better look. That way, the lacing strip doesn't drift and you can tighten the outer edge of the tramp first instead of tightening the middle and having the outer edge bind.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
0 registered members (), 293 guests, and 33 spiders.
