Hole in Comptip #114967
08/16/07 06:47 PM
08/16/07 06:47 PM
Indiana
swaompfox1 Offline OP
Indiana
I pitchpoled my boat this year and it turtled. Since then I have had water in my Comptip. I tried all angles and all positions to find a place where it leaked for the water to drain out with no luck. I finally drilled a small hole at the top for the water to drain. I ended up with about a gallon when it was done draining. Now I need to plug the hole. I thought about using a screw with a flat rubber washer or maybe just putting a rivet in. Any suggestions?
Re: Hole in Comptip [Re: swaompfox1] #114968
08/16/07 08:38 PM
08/16/07 08:38 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Regardless of what you plug the hole with, shouldn’t you determine how the water got in the mast and repair that?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hole in Comptip [Re: hobie1616] #114969
08/16/07 08:41 PM
08/16/07 08:41 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
No, never, if you can't see the hole it isn't there...
Re: Hole in Comptip [Re: hobie1616] #114970
08/16/07 09:29 PM
08/16/07 09:29 PM
Indiana
Indiana
I did have a hole in the main part of the mast at one of the rivets which I sealed with silicone. The Comptip I figure got water in it from the pressure when the boat was turtled.
Re: Hole in Comptip [Re: swaompfox1] #114971
08/20/07 08:55 PM
08/20/07 08:55 PM
How long were you turtled for?
Re: Hole in Comptip [Re: Karl_Brogger] #114972
08/25/07 11:26 AM
08/25/07 11:26 AM
California
mmiller Offline
mmiller  Offline
California
Leaks in masts during a turtle may be hard to find. The underwater pressure may overcome a loose seal. That seal may re-seat under normal air pressure. The glass fibers on on the seams of the older CompTips can also seep water in over time. We seal there with resin these days. These seams also can suck in humid air which then condensates inside the tip.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 626 guests, and 508 spiders.
