| Rudder #115243 08/21/07 12:00 PM 08/21/07 12:00 PM |
Posts: 1,152 tampa, fl | I have brand new 3rd generation rudders on my n20. They make an incredible amount of humming noise. I tried a seach but couldn't come up with a solution. I saw at some point in the past here, a remedy for rudder hum, but can't find it now. Can anyone help me out?
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Rudder
[Re: ksurfer2]
#115244 08/21/07 12:22 PM 08/21/07 12:22 PM |
Posts: 2,921 Michigan | Have a professional fair them. did that with the rudders on my HT and doing it with the rudders on my blade (though they don't hum). well worth the money IMO. I figure it will get me the extra 1/10 of a knot to push me onto the gold podium <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
| | | Re: Rudder
[Re: PTP]
#115245 08/21/07 03:03 PM 08/21/07 03:03 PM |
Posts: 186 Chattanooga, TN | is there someone you recommend for the fairing?
Jody
Blade F16 724
Plays with Sharp Objects
| | | Re: Rudder
[Re: jody]
#115248 08/21/07 03:22 PM 08/21/07 03:22 PM |
Posts: 2,921 Michigan | | | | Re: Rudder
[Re: warbird]
#115249 08/21/07 03:28 PM 08/21/07 03:28 PM |
Posts: 1,152 tampa, fl | I have checked the rudder alignment and they are spot on. Set identically to the way the old rudders were. Old rudders...no hum, new rudders....hum like h***! I did find this in my search: http://www.ahpc.com.au/pdf/Noisy%20Foils.pdf
[Re: PTP]
#115251 08/21/07 04:46 PM 08/21/07 04:46 PM |
Posts: 3,293 Long Beach, California | I can wholeheartedly second the recommendation to send your foils to Jim Bowman at Recreational Composites. Send the rudders in the castings and get the teflon lining, too. Jim is a craftsman and takes great pride in his work.
| | | Re: Rudder
[Re: ksurfer2]
#115252 08/21/07 05:44 PM 08/21/07 05:44 PM | Anonymous
| Anonymous
Unregistered | I have checked the rudder alignment and they are spot on. Set identically to the way the old rudders were. Old rudders...no hum, new rudders....hum like h***! I did find this in my search: http://www.ahpc.com.au/pdf/Noisy%20Foils.pdf What about the trailing edge, did you malke a small about 1/8" flat spot. Most people use a pair of scissors. Doug | | | Re: Rudder
[Re: DanWard]
#115254 08/21/07 07:46 PM 08/21/07 07:46 PM |
Posts: 1,884 Detroit, MI | Vortex shedding: ![[Linked Image]](http://www.math.mcmaster.ca/~bprotas/Gallery/re150_uncontrolled.gif) Even though that's a cylinder, the principle is the same. Whether it causes the foil to hum depends on the natural frequency of the foil and the frequency of the vorticies. If one is a multiple of the other, the foil resonates = hum. By making your trailing edge asymmetric, you change the frequency of the vorticies, hopefully to one that is not a multiple of the foil's natural frequency. Here's another cool image of votex shedding caused by wind flowing past an island. These are called "Von Karmann Vortices": ![[Linked Image]](http://marine.rutgers.edu/dmcs/ms451/2004/NotesWilkin/LectureNotesWilkin2004_files/image090.gif) | | | Re: Rudder
[Re: John Williams]
#115257 08/21/07 10:56 PM 08/21/07 10:56 PM |
Posts: 2,921 Michigan | I can wholeheartedly second the recommendation to send your foils to Jim Bowman at Recreational Composites. Send the rudders in the castings and get the teflon lining, too. Jim is a craftsman and takes great pride in his work. Very good guy. Faired the HT rudders and actually made some carbon rudders for the HT. What is the teflon lining? I may ask him. He has my boards and rudders right now. | | | Re: Rudder
[Re: warbird]
#115259 08/22/07 06:24 AM 08/22/07 06:24 AM |
Posts: 1,884 Detroit, MI | I have brand new 3rd generation rudders on my n20. Hobie should be ashamed of themselves. Warbird, since when does Hobie make NACRA 20 rudders? BTW, Hobie EPO2 rudders don't hum. | | | Re: Rudder
[Re: mbounds]
#115260 08/22/07 06:36 AM 08/22/07 06:36 AM |
Posts: 206 Yardley PA | Whether it causes the foil to hum depends on the natural frequency of the foil and the frequency of the vorticies. If one is a multiple of the other, the foil resonates = hum.
That's the part I was missing. Thanks Matt | | | Re: Rudder
[Re: Keith]
#115262 08/22/07 09:59 AM 08/22/07 09:59 AM |
Posts: 12,310 South Carolina | I gotta tell ya, after building my own rudders (for my 1 meter R/C boat, this is not easy. Still though, I do finish mine with a clear coated carbon finish and they don't hum. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jake Kohl | | |
225
guests, and 61
