| FX-ONE Report!! #11540 10/10/02 03:22 PM 10/10/02 03:22 PM |
Posts: 744 | All,
Here is my report on the FX-1 from Hobie Cat. The impressions below come from my sailing the current production 17'-18' uni rig cats with daggerboards over the last 5 years. I tried very much to keep it straight to the point. This report is only my opinion and my views may not be shared by all readers. After just coming off an A class, I feel very comfortable with this report and the performance of the FX-1.
Bob Curry
Tacking:
The boat tacks and reacts very much like an A cat, just turn the tiller over and quickly get to the other side! I tried both leaving the sheet tension on and slightly easing it during the tacks. The boat responded better to a slight ease. In the 8-10kts of breeze, I found a slight roll tack best. This boat easily out-tacks the current uni rig production boats in the 17-18’ class.
Gybing:
Again, just like the A cat! A nice gentle arc produced the fastest speed out of the gybe.
Upwind:
The FX-One responded best to the traveler down about 2-4”with the outhaul slightly eased and the downhaul down just a bit (wrinkles out). My weight (168lbs) was right at the daggerboard and I was able to fly the trapeze easily. Every control line was sensibly located and easy to adjust. The boat reacts very well to puffs and accelerates better than the other current production lines. The mainsail could be a tad bit fuller up top for most US conditions.
Downwind:
Even though a bit heavier than the A class, this boat shares the same wide-groove characteristics of the wave piercing A cats. It accelerated smoothly and I was able to keep it in the groove for a long stretch without much attention. I was able to wildthing in puffs 10kts and greater.
How it looks…
This is the sexiest production boat I’ve ever seen! The wave piercing angled bows really shed the water and handle waves like a hot knife through butter. There is plenty of hull volume so it is not weight sensitive.
Overall Impression
This one is easy; it is a production version of the popular A class! Combined with a chute, this boat will really be a performer!! I could easily move it around on the beach with CatTrax which is a plus. Even though I spent about an hour and a half sailing, I can't wait to do it again and I'm very stoked this boat came along!!
| | | Re: FX-ONE Report!!
[Re: MauganN20]
#11542 10/10/02 06:36 PM 10/10/02 06:36 PM |
Posts: 744 | Talk to Brad ( www.sunjammers.com) in Panama City, Fl or Kirk at KeySailing in Pensacola, Fl. I think the FL guys will work with you. Brad is sailing in the Mega and you will probably have to wait to talk with him until the weekend. Bob
| | | Re: FX-ONE Report!!
[Re: nacra 269]
#11545 10/10/02 08:57 PM 10/10/02 08:57 PM |
Posts: 744 | Jim,
I'll try my best to answer your questions..
1. I am not involved with the Hobie Co. or the class.
I do thank the Co. for letting me sail their boat at their dealer meeting.
2. I'm too rough (sail them hard) on the boats I own and I've always needed a "bulletproof" platform.
3. I've sailed the 5.5 Uni and I17R (downwind w/o chute) for the comparison.
Thanks for your questions for clarification!
Bob
| | | Re: FX-ONE Report!!
[Re: ScaredyCat]
#11546 10/10/02 09:00 PM 10/10/02 09:00 PM |
Posts: 744 | Hey Mark!!
I think Sunjammers will have the boat. Since I was on a short leash (time constraint), I could not test the righting aspect. Time will tell what really works. The FX-1 rates 72.1 w/o chute so do the math!!
Bob
| | | Re: FX-ONE Report!!
[Re: Bob_Curry]
#11548 10/10/02 09:36 PM 10/10/02 09:36 PM | Anonymous
| Anonymous
Unregistered | Bob, is the FX 1 a spinaker boat? I thought it was but you did not mention that in your evaluation. Also, how much does it weigh? What is the class minimum wt. for skipper? Thanks. | | | Re: FX-ONE Report!!
[Re: ScaredyCat]
#11550 10/10/02 10:02 PM 10/10/02 10:02 PM |
Posts: 744 | I did feel the boat is much faster in the transitions (tacking/gybing) and acceleration from a dead stop like on a starting line. There is really no data to do a good comparison at this time. If Brad has one with the chute, I'd like to spend a day in PC sailing your I17R and the FX for data gathering.
Bob
| | | Re: FX-ONE Report!!
[Re: Bob_Curry]
#11551 10/11/02 09:21 AM 10/11/02 09:21 AM |
Joined: Aug 2001 Posts: 190 Long Island, NY Steven Bellavia
Posts: 190 Long Island, NY | Hi Bob,
I also posted this on the other thread where weight was being discussed.
I weighed my FX-One using fairly accurate scales:
Total Weight (Uni-Configuration, no jib, no spinnaker) = 313 lbs (About 11 lbs lighter than Texel is reporting)
Breakdown:
Basic Platform (Hulls, Crossbar, Trampoline) 198
Mast (With spreaders and main halyard) 44
Steering System (Rudders, pins, slave bar, tiller ext) 25
Mainsail (w/ battens, boom, mainsheet& block, cunningham) 21
Dagger Boards 20
Rigging (Sidestays, forestay, 1 trapeze set) 5
Total 313
Jib Kit (Jib, upper and lower furler, halyard, blocks & jib sheet) 8
Steve Bellavia
| | | Re: FX-ONE Report!!
[Re: Steven Bellavia]
#11552 10/11/02 10:24 AM 10/11/02 10:24 AM |
Posts: 9,582 North-West Europe | Sources : http://www.hobiecat.com/fx1.htmlhttp://www.hobiecat.com/pdf/fxone.pdfQuote 275 lbs = 125 kg's. for the FX-one without a spi With your post we may conclude that the (newer and lighter?) FX-one is a shy 40 lbs above quoted weight. I think that that was the main point of the thread. I held back on several posts as I am obviously involved with a direct competitor of the FX-one; but this time the urge was to great. With activities like this I wouldn't be surprised if the boats measured by ISAF and Texel were unintentionally heavier than expected. Flame me all you want too. Wouter
| | | Re: FX-ONE Report!!
[Re: Wouter]
#11553 10/11/02 10:56 AM 10/11/02 10:56 AM |
Posts: 190 Long Island, NY | Hi Wouter, Not to forgive or condone Hobie, but they all lie. I purchased a brand new Beneteau 23.5 foot racer-cruiser monohull that was advertised as 2300 lbs, and actually weighed 3300 lbs. But what's 1000 lbs amongst friends? I was told by the Hobie dealer that the weight (ca), as shown in your second URL (PDF file) is the "weight capacity", ie, the crew weight. Other borchures have shown 298 lbs as the weight of the boat, which would make my boat 15 lbs heavier than advertised. All-in-all, it's still 60 lbs lighter than the boat I just sold, and lighter than an I-17 or Hobie 17 and very close to a 5.5Uni with Carbon mast and foils. Looking at the breakdown, it's obvious (to me) that they need to spend a little more engineering time with that steering system (25 lbs - yikes!). Some immediate "remedies" could be to elimate the solid rudder pins and go to hollow stainless tube (about a .5 lb saved) and make the slave bar carbon tubing (another 1 lb maybe). Numerous lightening holes in the castings would help too. Also a carbon mast would go a long way to improving performance and knock another 15 lbs from the total. Carbon daggerboards should have been standard. (Another 10 lbs). But of course, a little late to do that now. But I'm very happy with the boat ![[Linked Image]](/forums/images/icons/smile.gif) Steve
| | | Re: FX-ONE Report!!
#11555 10/11/02 11:27 AM 10/11/02 11:27 AM |
Its good to hear you are happy with the boat.
And that is all that is important.
| | | Be Carefull Wouter...
[Re: Wouter]
#11556 10/11/02 12:51 PM 10/11/02 12:51 PM |
Joined: Jun 2001 Posts: 292 Long Island, NY Ed Norris
Posts: 292 Long Island, NY | ...If you continue to get all mushy and nice like this, we're going elsewhere for "strong criticism" :P
Sail Fast,
Ed Norris
| | | Thouche ! Ed.
[Re: Ed Norris]
#11557 10/11/02 03:10 PM 10/11/02 03:10 PM |
A little bit scary isn't it.
Fair winds to you too.
| | | Re: FX-ONE Report!!
[Re: Bob_Curry]
#11558 10/12/02 01:59 AM 10/12/02 01:59 AM | Anonymous
| Anonymous
Unregistered | I though you all might be interested in the actual FX-one class rules regarding crew weight and boat wieght. The boat weight includes spinnaker gear. That makes it sound like Steven's boat is spot on. I doubt the spinnaker gear weighs fourteen pounds, so he'll be a few pounds light. In my opinion that is perfect. You carry a little lead when the boat is new then after a few years and a few repairs you still have a minimum weight boat.
8. MINIMUM CREW WEIGHT
The Hobie FX-ONE shall have a minimum
combined crew weight of 72 kg (158.73 lbs.).
9. MINIMUM BOAT WEIGHTS
The minimum weight of a Hobie FX-ONE,
completely assembled with spinnaker and
running gear shall be 148.5 kg (327.39 lbs). See
Rule #19 of the General Rules. | | | Can you provide me with a link to the FX-one rules #11559 10/12/02 09:37 AM 10/12/02 09:37 AM |
Can you provide me with a link to the FX-one One-design calss rules ?
Then I will send these rules to the ISAF and Texel Committees and request a remeasuring of the boats or the demand that the class weights are used in the calculation of the rating numbers.
338
guests, and 56
