Tiller extension options #115581
08/26/07 08:02 AM
08/26/07 08:02 AM
central Maine
wannahobie Offline OP
central Maine
Hi All,
I have the new style rudders/tiller on my Wave, and have found that tiller-behind-the-sheet a little short. Occasionally I even use my feet to hold it.
What I would like to do is add a tiller extension, but the way the tiller bar must be raised up so high when raising rudders has me concerned about the hinge angle when raised. I don't want to break or stress anything.
I am also unsure of components to buy. I thought about just purchasing the Getaway parts, yoke, hinge, stick, etc, but that really adds up. Mounting is another question. Since the tiller is fairly high to begin with, should the yoke be mounted upside down, or on top but at a forward angle?
I don't think a extendable model like a hotstick is necessary, as I will not be trapping out. I think a cut-down stick will work.
Anybody have any thoughts?
Thanks <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Jim
Re: Tiller extension options [Re: wannahobie] #115582
08/26/07 10:55 AM
08/26/07 10:55 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
I am not sure how you feel about going with the cheap way out but an aluminuim paint stick works well and it makes it extendable if you need it. Also alot of the F16 guys use conduit.
Buy the connections and then just make the extension. You can even add a cool paint job.
Re: Tiller extension options [Re: gree2056] #115583
08/26/07 07:23 PM
08/26/07 07:23 PM
central Maine
central Maine
That is a good idea. I may end up going that route. Thanks for the suggestion.
Jim
Re: Tiller extension options [Re: wannahobie] #115584
08/26/07 07:37 PM
08/26/07 07:37 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Where are you located, I actually have two things that might help you.
I have a few extra of the connections that I would basically give to you for the cost of shipping, also I have an old aluminium extension that I managed to break, I had to buy a new one because it is now to short to allow me to go all over the boat. But for you it would work.
It still works fine and the broken end is covered by duct tape right now but you could add some kind of grip.
If you are interested in any of this just send me a PM on here.
Re: Tiller extension options [Re: wannahobie] #115585
09/03/07 07:07 AM
09/03/07 07:07 AM
RickWhite Offline
RickWhite  Offline
HI Jim,
Here is the part you need: http://store.catsailor.com/tek9.asp?pg=products&specific=jmnpkpmrc8
You cannot mount it under the tiller bar as it won't swing from side to side.
On top would also cause problems as you have pointed out. So, put it on top but angled slightly forward, enough that allows the tiller to lay on the deck without stressing the Yoke Assembly.
In doing so, howeever, you will not be able to drop the tiller off the back of the boat (which is good) as that would cause the same stress you are concerned about.
For the actual tiller, just go to a local hardware store and get an aluminum tube the size you want.
Good luck,
Rick
Rick White
www.onlinemarinestore.com
Re: Tiller extension options [Re: RickWhite] #115586
09/03/07 08:17 PM
09/03/07 08:17 PM
central Maine
central Maine
Thanks Rick. That part and the hinge, all I will need to find is a lightweight pole of some sort.
I am guessing that the lightest pole I can find would be best, to minimize any stress to the crossbar, particularly when dropped off the rear as you pointed out. That is why I will try to avoid an extendable. I found carbon fiber tubing, but that stuff is pricy!
I will post results once I do it.
Appreciate the tips!
Jim 2007 Hobie Wave
Re: Tiller extension options [Re: wannahobie] #115587
04/10/08 10:25 AM
04/10/08 10:25 AM
fort scott ks
rbrazz Offline
rbrazz  Offline
fort scott ks
I have the wings or whatever on my wave. I got a cheap $5.00 windshield cleaner that telescopes, cut it off and drilled a hole in the crossbar and mounted the thing. When i sit on the backrest i can extend the tiller. when i come on the tramp shorten it up. Cheap and effective.
rbrazz
Re: Tiller extension options [Re: rbrazz] #115588
04/10/08 05:02 PM
04/10/08 05:02 PM
I don't think you're s'posed to sit on that backrest. <img src="http://www.catsailor.com/forums/images/graemlins/ooo.gif" alt="" />
Re: Tiller extension options [Re: wannahobie] #115589
04/12/08 08:49 AM
04/12/08 08:49 AM
RickWhite Offline
RickWhite  Offline
For tiller extensions on old style tillers.., or even the new rudders, take a look at the following article. This was the system used on Shark Cats for many years and maybe still on many of them.
http://www.catsailor.com/waves/superwave_overall.html
Rick
Rick White
Re: Tiller extension options [Re: RickWhite] #115590
04/25/08 11:20 AM
04/25/08 11:20 AM
IndyWave Offline
IndyWave  Offline
I just made a (double) tiller extension out of PVC conduit using a "flexible elbow" in the middle, clamped to the middle of the tiller crossbar. The result is similar to the arrangement in Rick's link, but each side is independent.
I used 3/4" conduit because it matches the crossbar diameter, and 1/2" seemed too flimsy. The "flexible elbow" is a single item, next to the rigid conduit elbows on the store shelf. I used two pairs of the plastic conduit hangers (side-by-side & back-to-back) for the clamp, and I put solid caps on the ends. I paid about $13.00 total for all the components, including nuts, bolts and star washers at Lowe's.
I made each side 4 feet long (sticks out 1 foot beyond the tiller arm) and put a ball-bungee on each side, to hold the un-used half snug to the crossbar (out of the way). The "flexible elbow" includes threaded couplings, so you can unscrew the poles for storage (or IWCA regattas, where extensions are prohibited).
With the short EZ-Lock tillers, I really felt restricted to the back corner of the boat. Now I can move up or hike out as much as I want.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115591
05/01/08 08:49 PM
05/01/08 08:49 PM
IndyWave Offline
IndyWave  Offline
Here's a photo of my scheme.
Note the ball-bungees to hold the poles up to the tiller crossbar; you can just slide each one to the middle when you're on that side, rather than disconnect it.
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115592
05/01/08 09:16 PM
05/01/08 09:16 PM
IndyWave Offline
IndyWave  Offline
Another Photo
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115593
05/01/08 09:18 PM
05/01/08 09:18 PM
IndyWave Offline
IndyWave  Offline
And another
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115594
05/02/08 05:18 AM
05/02/08 05:18 AM
Wow, that is a pretty hefty-looking tiller! Seems like overkill for such a little boat that has very neutral helm.
One comment:
An advantage of the new rudder system with the tillers higher and back farther is that the helmsperson can also get back farther (back UNDERNEATH the tiller) on a reach, and therefore go faster and keep the bows up. Your extension will effectively be a bar that prevents you from doing that.
Re: Tiller extension options [Re: Mary] #115595
05/02/08 07:56 AM
05/02/08 07:56 AM
IndyWave Offline
IndyWave  Offline
Actually, there's still plenty of room to get underneath it, and the extra foot sticking out to the side lets you hike out flatter once you're back there. The flexible elbow lets you swing it wherever you need: up, down, fore, aft. You can always just push it out of the way, if you don't need it.
But you're right about the "heft". I could have gone with the 1/2" conduit, but I liked the feel of the 3/4", since it matched the crossbar. The extra weight does tend to pull down on the tillers when they're raised, however.
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115596
05/02/08 10:44 AM
05/02/08 10:44 AM
Turks and Caicos Islands
rumsailsman Offline
rumsailsman  Offline
Very clever! I like the doubled C clips to attach to the tiller. I would have used hose clamps but your idea solves any rusting issues and the need for a rubber piece to keep the hose clamps from scratching the tiller paint. Is the flexible section in the middle just flexible conduit? uhh are you an electrician?? ;~}
You sailin' or bailin'?
Re: Tiller extension options [Re: rumsailsman] #115597
05/02/08 11:05 AM
05/02/08 11:05 AM
IndyWave Offline
IndyWave  Offline
Yes, it is flexible conduit, but it's a pre-made piece with the end fittings already attached. I'm not an electrician, just a part-time tinkerer. I went to Lowe's and started looking around at what they had, and how I could put things together.
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115598
05/13/08 08:17 AM
05/13/08 08:17 AM
RickWhite Offline
RickWhite  Offline
With the new rudder system, the tiller is behind the sheets and a conventional extension could have been used. The reason I had a tiller out each side was because on the older rudder system the tiller was ahead of the sheets.
Rick
Rick White
Re: Tiller extension options [Re: RickWhite] #115599
05/14/08 09:03 AM
05/14/08 09:03 AM
IndyWave Offline
IndyWave  Offline
I just wanted to see what I could come up with, that didn't require drilling holes, was cheap, and was a little different. I really like the way it turned out.
But I have to take it off for this weekend's Wave Midwest Championship, right?
What - Me Worry?
"Ish Kabibble"
Re: Tiller extension options [Re: IndyWave] #115600
05/14/08 09:26 AM
05/14/08 09:26 AM
Right. If us women don't get to use one, neither can you. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
0 registered members (), 501 guests, and 631 spiders.
