| Re: Jib slot
[Re: blockp]
#115774 08/28/07 03:08 PM 08/28/07 03:08 PM |
Posts: 12,310 South Carolina | If your upper and lower tails (inside or outside - doesn't matter) are breaking at different times, then it's not necessarily the amount of out your sheeting is providing. This is more a function of how far forward or aft your sheeting point is. Envision that if you moved your sheeting point aft, it pulls more on the bottom of the jib leaving it flatter. It also would pull less on the top of the jib leaving it fuller. The opposite is true if you move your leads forward - the top gets flatter and the bottom fuller.
If your top inside tails are breaking before the leeward, you need to flatten the top and belly up the bottom a bit by moving the jib sheeting point forward.
Other things can affect this to such as the amount of tension applied to the jib. If you are not sheeting much and are leaving twist in the jib, you can also affect when the tails break.
With regard to inhaul, you are are trying to match the curve of the mainsail so the jib slot is the even from top to bottom. In/outhaul and tension will affect this. You need enough tension to be able to point well and the in/outhaul position to shape to the main properly.
There are basically two things to try and achieve here; getting the jib slot to be even from top to bottom with the main sail and to get the tails to break evenly. Three things will affect this; sheeting tension, jib in/outhaul, and fore and aft position.
Jake Kohl | | | Re: Jib slot
[Re: blockp]
#115775 08/28/07 03:31 PM 08/28/07 03:31 PM |
Posts: 330 | I agree with the previous post. As a general rule, the jib should be made to break evenly, and this is usually done by moving the jib car forward (to get the bottom telltale to luff first) or aft (to get the top to luff first).
In addition, if your boat is set up with inboard/outboard jib cars, these should be set proportionally to the main traveler. I.e., if you travel out the main 6" from center, you should travel out the jib car a few inches from it's inboard position.
The jib should also be made to match the mainsail. So if the top of the main is twisted (top telltales luffing) then the jib should be twisted (with the top telltales luffing).
I usually depower by travelling out, twisting (by moving the car back), or easing the jib before the main, that way I don't run the risk of closing off the slot. My general system for depowering from initially having both sails set for max power is: 1st both sailors trapped out, then downhaul until maxed, then travel out the jib slightly (or ease sheet if no jib traveler). Ease main traveler.
One last note, if the boat feels sluggish, it's usually a good idea to ease the jib slightly. An oversheeted or stalled jib is very slow.
sm | | |
2,369
guests, and 385
