| Adventure Trip on Lake Amistad, Tx #115787 08/28/07 10:41 PM 08/28/07 10:41 PM |
Posts: 70 | Like the title says, Im headed to Lake Amistad on the Texas/Mexico border. The lake is huge and remote...just the way I like it. The plan is to load stuff on the boat and camp out for 7 days. I have racks to carry stuff(do a search for camper/cuiser on this forum. its really old but its in here somewhere.
I wanted to do this trip 15yrs ago with the family but at that time the lake was down 40ft. Several hurricanes later, it finally filled up a couple of years ago. I went down there last fall on a canoe trip and had a blast. The lake is beautiful and in rugged desert country.
Ive replaced the tramp, rigging and reglassed the keels. Im about to put ports in as the boat will be in the water for 7 days. I always manage to get some water in through the vents.
Fishing at this lake is at its prime. I will be towing two kayaks. Ive towed one with no problem but not sure how to do it with two. The plan is to fish in the morning and sail in the heat of the day. Find a suitable camp by 3pm or so and fish out the rest of the day. If the weather is good, we will sleep on the boat. If lightning is a possibility, we will be off the boat. 150 miles of sailing is quite possible during the week.
A good friend of mine is going and he has 0 sailing experience but that is ok. My biggest fear is sticking a hull and dumping everything. With all of the camping suff, it makes the boat very stable if not slow. I just cant get in a hurry.
Most of the lake is flooded canyons so the sides are steep and the wind can be tricky. For the most part, there are no gentle sloping banks at all. When you do get to shore, it is amazing at the lack of anything flat over the size of a coffee table. Think chunk rock and lots of it. Like the stuff they line dams with. The tallest tree is 4ft mesquite and they have those thorns too. Fire ants do well in this country and bite as willing as the bass.
I do have some questions about anchoring the boat during the day. Normally I just slide it up on the bank and into the wind. If the wind is blowing hard, Ill just drop the main. Because of the lack of suitable beach, dropping the main is possible, but getting it back up while the boat is in 40ft of water might not be easy. What is the best way to anchor the boat at night so it doesnt drift around? Do I need to tie off to the bank and an anchor? Is there a preferable point to tie the anchor off ie the bow? Finally, what kind/weight of anchor is best in these conditions?
Any other thoughts/suggestions would be appreciated. | | | Re: Adventure Trip on Lake Amistad, Tx
[Re: tx246]
#115788 08/29/07 05:14 AM 08/29/07 05:14 AM |
Joined: Apr 2005 Posts: 53 The Netherlands, Europe flying_dutchman
Posts: 53 The Netherlands, Europe | Took my Hobie 16 to Croatia some years ago where she had to stay on the water for several weeks. Coast is rather rocky. They use kind of moorings to anchor: concrete blocks with a line and a buoy. Rather difficult to set and lower both sails on the water by the way. Take enough spares with you as you are going to drop some items for sure. in spite of the mostly moderate winds and waves the H16 was always moving when attached to this mooring. I made a kind of divider with a line between both bows and the dolphin striker which made some improvement. Next to that I blocked the mast against rotating otherwise it might be continuously hitting the end nocks on the base! Also I applied as much tension as possible on the shrouds to minimize the movements of the mast. My experience with anchoring are only for The Netherlands as the sea near Croatia is far too deep (200 - 300 ft). Weight of the anchor doesn't make to much difference. Far more important: it should have a firm grip in the bottom (preferably to be checked by sight!) for which ± 6-8 feet of chain are vital. The length of the line has to be 4-6x the depth of the water. Al together quite some stuff to take with you on a Hobie. Another advice: attach a line with a small buoy to the other side of the anchor. This way it is not only marked but it might be handy when your anchor got stuck somehow. In general: anchoring remains tricky because you can not check the grip of the anchor. The moment you pull the line the Hobie will move forward anyway so you are never sure!!! Be critical and on your guard especially when sudden weather changes might occur (as on the Croatian coast: heavy winds out of various – fast changing – directions) Have a nice trip !!!
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
2,455
guests, and 294
