| Speed runs with Hobie 16 #116269 09/05/07 12:48 PM 09/05/07 12:48 PM |
Joined: Jul 2001 Posts: 256 North Europe, Sweden, Uppsala Hakan Frojdh OP
Posts: 256 North Europe, Sweden, Uppsala | I tried some serious speed runs with my Hobie 16 last weekend and managed to reach 22.4 knots (25.7 mph) in flat water and winds around 20 knots. I tooks us 10 speed runs with double trapeze (150 kg, 330 lbs) and standing as far back as possible. Weather rudder lifted clear, lots of downhaul and traveller all the way out on the jib and 0.7 meters out on the main. We sailed the boat deeper and deeper on the reach, double trapezing with weather hull just touching the water. I was a bit nervous about doing a pitchpole in that speed, but what the heck! We had a couple of near misses where the hull dug in, the boat stopped a bit, dumped the main and we ended up in a pile at the main beam. My crew hit the corner casting quite hard but he felt ok until I landed on him, then it was PAIN! To get some REAL data out of this I used a software called gpsActionreplay to get statistics from the gps tracks. Best 500 meter run was 20.5 knots Best 250 meter run was 21.3 knots Best 100 meter run was 24 knots (probably some glitch) Check the link below for the html that the software generated. http://www.webbo.dyndns.org/hobbe/speed_test//hakan | | | Re: Speed runs with Hobie 16
[Re: scooby_simon]
#116271 09/05/07 04:11 PM 09/05/07 04:11 PM |
Posts: 902 Norman,OK | Those speeds I can believe, if you are holding them for the long of a run it factors out the gps error.
Cool data!
[Re: gree2056]
#116272 09/05/07 07:35 PM 09/05/07 07:35 PM |
Posts: 182 Coopersburg, PA | Wow, I dont think I would want to think about pitching at that speed (24 kts). Keep the data coming Hakan, seems like very cool software, now all you need are a bunch of cameras mounted all over the place, (masthead, bridle, stern, boom, helmet cams) video from that speed would be very cool.
~vinny~
[Re: Hakan Frojdh]
#116273 09/06/07 03:39 PM 09/06/07 03:39 PM |
Posts: 1,200 Vancouver, BC | Hakan,
Did you filter out any GPS anomalies from the data set prior to calculating the runs? The Action Reply website discusses how to do this.
I'm suspicous of your posted speeds. All it would take is one data point 30+ knot glitch (which occur frequently with GPS) to skew the averaging computation heavily.
Best I've managed to capture so far on my Tornado is just under 22 kts.
[Re: Tornado]
#116274 09/06/07 04:03 PM 09/06/07 04:03 PM |
Posts: 2,584 +31NL | If you want to have the most accurate GPS speed measurement get one of these: Navi/Amaryllo GPS. In addition to the classic way of calculating speed they make use of the Doppler effect to get the most accurate result (0.1 accuracy). (This is what the speed windsurfers will use from 2008 onwards). | | | Re: Speed runs with Hobie 16
[Re: Tony_F18]
#116275 09/06/07 04:23 PM 09/06/07 04:23 PM |
Posts: 256 North Europe, Sweden, Uppsala | The sampling time between each tracklogg is 10 sek, and when checking the data in Oziexplorer it was rather clean. I had the gps mounted on the lifewest, not on the arm, to keep it steady. Sheeting with an arm mounted gps is a good way to get speed glitches. The 250 meter and 500 meter runs feels reliable but the 100 meters are too short based on the tracklogg sampling rate. The gps said that the highest recorded speed was 22.4, but I think it's safer to refer to the best 250 meter run at 21.3 knots.
The highest speed I recorded with the A-class is 20.5 knots using the spi in high winds and flat water trapezing with chickenline as far back as the hull stretches, and that's the gps instantanious speed! If I analyze that tracklogg from the A-class run using the software I get the following data: Best 250 meters run, 19.9 knots Best 500 meters run, 19.2 knots
The Hobie 16 rocks!!!!! It has higher top speed than my A-class, which was something else than an A-class since I was using a spi on it.
[Re: Hakan Frojdh]
#116276 09/06/07 04:26 PM 09/06/07 04:26 PM |
Posts: 12,310 South Carolina | yeah, but your A was probably sailing almost straight downwind! Try that with the 16.
Jake Kohl | | | Re: Speed runs with Hobie 16
#116277 09/06/07 04:36 PM 09/06/07 04:36 PM |
Posts: 256 North Europe, Sweden, Uppsala | With a 16 m2 spi on the A-class I sail 30 deg from straight downwind course even though I'm hanging flat out on the trapeze (in high winds and flat water). The Hobie 16 wouldn't have a chance.... The image above is a tracklogg from an upwind/downwind leg with the A-class using spi, wind is from south. Check the angles between the gybes! /hakan | | | Re: Speed runs with Hobie 16
[Re: warbird]
#116280 09/07/07 03:57 AM 09/07/07 03:57 AM |
Posts: 9,582 North-West Europe | Why don't we create an informal speed rule here and give people a chance to work on outright speed and post results?
Simply, take the average speed over 500 meters from a GPS track log with at least a sampling rate of onces every 10 seconds (or faster). Calculate the average speed by deviding the distance covered by the time taken. DO NOT calculate average speed by summing all the individual speed averages and then deviding it by the number of samples. The latter can be much less accurate. The track itself and the series of data points must be presented as proof. Also two runs most be made on opposite tack were the slower one of the two is presented. This to take out surface currents. Everybody with a simple GPS logger can do this. 500 meter will take a shy 50 seconds to cover at 20 knots. This is sufficiently long to take out riding off waves or other effects. Wouter
[Re: claus]
#116281 09/07/07 04:01 AM 09/07/07 04:01 AM |
Over the years I have done some beam reaching drag racing against the H16's while sailing a Hobie Tiger and a Formula 16 myself; often in big wind. Each time the boats stayed very close to one another and it always was an inmense effort just to pass the Hobie 16's. When I sailed a Hobie 16 myself I found the exact same thing. Basically, the Hobie 16 is a fast reacher and it always has been.
I'm not surprised it hits 20 knots in such conditions.
[Re: ncik]
#116284 09/20/07 03:59 AM 09/20/07 03:59 AM |
Joined: Jul 2006 Posts: 1,147 Bay of Islands, NZ warbird
Posts: 1,147 Bay of Islands, NZ | Are you gonna change the name? Don't like it??? I thought I might call it "Death Slash Devil Slit Killer Kill kill kill!" : ) | | | Re: Speed runs with Hobie 16
[Re: warbird]
#116285 09/20/07 04:23 AM 09/20/07 04:23 AM | Anonymous
| Anonymous
Unregistered | How did you pull that off? Didn't close till Sunday! Had my eye on it as well :-).
Brings back memories. Certainly a fast boat. | | | Re: Speed runs with Hobie 16
[Re: warbird]
#116287 11/08/07 01:02 AM 11/08/07 01:02 AM | Anonymous
| Anonymous
Unregistered | Warbird, I see this is back on the market. What's the story?
You didn't buy that Tornado did you?!
Mark.
1,084
guests, and 50
