| Tips needed for tacking in heavy wind... #116431 09/07/07 07:52 AM 09/07/07 07:52 AM |
Posts: 431 Netherlands | Hi all, let me tell you the reason I'm asking.
I don't have much cat experience yet but I just love 'em! My brother and I went out about a month ago in a Topcat K2 model (no boards). We were having great fun and even flipped the boat once just for the hell of it. Never noticed a tacking problem, although I tended to keep the weight forward during tacking as advised by the rental guy. So far, so good. So great actually, we were screaming! Well, no, we were cool, but the boat was screaming... Ahum.
Then we decided to go in so the ol' cumulonimbus' wouldn't catch us. When we got in it looked like the nasty stuff would stay much farther out to sea, so went out again. DUMB DUMB DUMB... In the end we were caught out in a gale and I really had to pull out all the stops just to stay upright. But I couldn't for the life of me get the boat tacked. It was hard enough to estimate where we were going, because I couldn't see more than 30-40ft ahead. I didn't dare to put very much tension on the main sheet (even if I could physically have managed to) to get a tight enough jib luff. I was praying the mast top would handle the savage beating it was getting. So we jibed instead, but that cost me a lot of height because of the dramatic speed increase and the time it took me to time the jibes so as not to trip on any waves. Thank heavens for boomless mains or I wouldn't have dared to jibe an unreefed main in gale force winds.
Can anyone give me some tips I should consider in situations such as this. Not being there is one I already considered...
Dennis | | | Re: Tips needed for tacking in heavy wind...
[Re: DennisMe]
#116432 09/07/07 08:20 AM 09/07/07 08:20 AM |
Posts: 12,310 South Carolina | For starters, if the main isn't sheeted tightly, you will definitely have difficulty tacking in any kind of wind. Under most circumstances, it is important to have the main sheeted firmly when tacking.
You should be able to tack in heavy air even if the boat will not carry all the way through. For starters, as you turn up into the wind and get nearly head to wind, the boat may stop - this is OK! As skipper, you need to keep the boat turned into the wind but watch the water flow over the rudders. As soon as the boat begins to sail backwards, reverse the rudders to back the boat onto the new tack. It will also help dramatically if you have the crew leave the jib sheeted on the wrong side for a second or two (backwinding the jib). This will cause the nose of the boat to swing around more easily on the new tack. Ease the mainsail as the boat goes through the wind, quickly get the jib to the correct side, and continue to bear away in your turn as the boat begins to move forward again.
Jake Kohl | | | Re: Tips needed for tacking in heavy wind...
[Re: DennisMe]
#116433 09/07/07 12:05 PM 09/07/07 12:05 PM |
Posts: 1,200 Vancouver, BC | Another tip is to move weight aft just as you approach head to wind. Delay on crew moving to the other hull until you're past head to wind. These two things can dramatically improve your tacking since they help reduce the waterline by lifting the leeward bow up or out of the water and they create a pivot point on the original windward hull near the transom. Finally, as you reach the head to wind point, ease off the mainsheet. This prevents the sail acting as a weather vane which is what can put you in irons.
[Re: Tornado]
#116434 09/07/07 01:25 PM 09/07/07 01:25 PM |
Posts: 12,310 South Carolina | but not too far back or you capsize backwards.
#116435 09/07/07 02:02 PM 09/07/07 02:02 PM |
Posts: 51 IL, WI, MI | but not too far back or you capsize backwards. This is how I tack.. and I am a newb trust me I learned how to right my boat very quickly.. lol
Hobie the only way to fly!
[Re: DennisMe]
#116439 09/09/07 05:34 PM 09/09/07 05:34 PM | Anonymous
| Anonymous
Unregistered | Be careful not to luff to much. As when you sheet in more you can quickly go into irons.
Good luck and welcome to the fun world of cats.
Doug | | |
632
guests, and 45
