Spin Take down #116779
09/10/07 08:09 AM
09/10/07 08:09 AM
Chattanooga, TN
jody Offline OP
jody  Offline OP
Chattanooga, TN
The discussion of the takedown was brought up this weekend after I was noticing some wear around the lower patch. The spin has the patches on the starboard side of the sail. Some people felt that you should always snuff the sail when the line is on the inside of the sail (so on mine it would have to be on a starboard tack). Well this is not easy when you try to drop it rounding the mark as you are rounding it on port. Do you all think this is a thing to worry about or does the side of the take down is not a problem.
As for the wear Ed says he is noticing the same stuff on his spin also. We have taped up what we can as far as sharp edges and what not, but are still looking for the cause.
Jody Blade F16 724 Plays with Sharp Objects
Re: Spin Take down [Re: jody] #116780
09/10/07 09:52 AM
09/10/07 09:52 AM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
I've always run mine up the port side of the spin. Sometimes tiny friction burns can show up. Is it worse that that?
Re: Spin Take down [Re: tshan] #116781
09/10/07 11:15 AM
09/10/07 11:15 AM
Chattanooga, TN
jody Offline OP
jody  Offline OP
Chattanooga, TN
It is a little worse, Even found 2 small (maybe 1 cm) holes in the area. All our patches are on the starboard side so not sure if I could run it up the port side.
Re: Spin Take down [Re: jody] #116782
09/10/07 11:32 AM
09/10/07 11:32 AM
No matter what you do, you will get friction between the retrieval line and the cloth in the spi when you douse on "the wrong" side. Pulling the spi down only on "the right side" will minimize this, but limit your strategy and tactics.
We have found that stripping the cover off the part of the line running _inside_ the spi when dousing to be a good measure. Dont remove more than you absolutely have to, becouse handling the stripped line is a bother. If you decide to strip, err on the short side first so you dont take off more cover than you need to. If you find it difficult to handle the stripped part of the line, try using some tight fitting garden gloves with rubber palms.
When we discussed this issue one or two years ago, different spi cloths, lines and snuffers was also mentioned as a source of burn holes and marks on the spi.
Re: Spin Take down [Re: Rolf_Nilsen] #116783
09/10/07 11:50 AM
09/10/07 11:50 AM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
I'm using Dyneema now and I must say it seems better for the spin. It's quite an expensive line though. What you can do is use it for the part that retrieves the spin, then sew a normal line to it.
Gill
Falcon F16 - BEL666
Boats: TheBoatShop.be
Re: Spin Take down [Re: Gilo] #116784
09/10/07 12:28 PM
09/10/07 12:28 PM
Dyneema or swiftcord ?
Re: Spin Take down [Re: jody] #116785
09/10/07 05:35 PM
09/10/07 05:35 PM
I'll taper your spin halyard for you if you want. all you have to do is send it to me.
I'm going through sailing and sailing related stuff withdrawal <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Re: Spin Take down [Re: Wouter] #116786
09/11/07 02:02 AM
09/11/07 02:02 AM
Switzerland
alutz Offline
alutz  Offline
Switzerland
I changed my halyard to pure dyneema (6mm without core) and like it much better than the one I had before. no more holes from friction in the gennacker. the line was quite slippery at the beginning but after a while it is now easy to hold and very soft.
I pulled in a core at the place where the cleat holds the halyard. this way it is also easy to see that gennacker was fully hoisted.
Andi, Switzerland
Team OST
Re: Spin Take down [Re: alutz] #116787
09/11/07 04:27 AM
09/11/07 04:27 AM
To echo Andreas,
I'm using 4 mm plain dyneema for 4 years now and I'm still flying my 4 year old spinnaker. It is pretty much blown out by now, but the damage from the retrival line is minimal. I think I have about 15 small tape repaires in it. Mostly as a precaution as I also "repair" small marks to prevent them from ever growing into larger holes. I also found that the tape repair cuts down on new damage. The first few repairs you get quickly after that the tape itself seems to reinforce the problem spots.
Once a season I take my spi halyard off and wash it. This makes it clean and soft again and then reduced wear on the spi significantly. Other then that my spi halyard is out in the condition 6 months a year and will become hard with salt, sand and algae.
Re: Spin Take down [Re: jody] #116788
09/11/07 05:18 AM
09/11/07 05:18 AM
. . . still looking for the cause.
It seems that my problem is worse when I have a sloppy retrieval i.e. the sail does not enter the bag smoothly. What I try to do is; bring the sail down to the mouth of the bag with as little pressure as possible, then, with one fast pull, the whole thing goes in.
Re: Spin Take down [Re: fin.] #116789
09/11/07 06:35 AM
09/11/07 06:35 AM
In my experience it also helps to pull the retrieval line more or less tight before uncleating the top halyard.
Re: Spin Take down [Re: Wouter] #116790
09/13/07 11:18 AM
09/13/07 11:18 AM
Gilo Offline
Gilo  Offline
I'm also using pure Dyneema now (no outer core).
Very good for the spin, a little more difficult to hoist it, because it more slippery.
Gill
Falcon F16 - BEL666
Re: Spin Take down [Re: Gilo] #116791
09/13/07 01:34 PM
09/13/07 01:34 PM
Why don't you leave the outer core on where you will be handling it during the hoist ?
Re: Spin Take down [Re: Wouter] #116792
09/16/07 08:19 PM
09/16/07 08:19 PM
I had trouble with every single set and takedown at a regatta this weekend, due completely because the halyard (with a cover on it) kept kinking up and jamming in the tramp gromets or clete. I had to stop pulling on the halyard, reach down and clear the kink, then pull the halyard up again. Same thing on the takedown, cost me a place a couple times, very frustrating.
If I just pull the core out of the coverd line, will the core work until I get the 6mm dyneema? Does the 6mm dyneema wear at the clete and does it hold in the clete without slipping? Anyone know how long the Blade Spin. halyard is? I'm guessing about 60-70 feet?
Re: Spin Take down [Re: Timbo] #116793
09/16/07 08:35 PM
09/16/07 08:35 PM
did you make sure you ran the halyard through multiple times to make sure the twists were out of it?
The same thing can happen with regular dyneema but not as easily. What kind of 6mm dyneema did you order?
The core of the line you are using (I think it may be the same as mine maybe? who knows) would work and if you do that you probably don't need to order any 6mm dyneema. I find that the core is or any dyneema is a little too slippery to pull on extcept for the last few feet when dousing (I have mine tapered at the snuffer end). The dyneema will wear quicker at the cleat than covered line.
Re: Spin Take down [Re: PTP] #116794
09/17/07 04:18 AM
09/17/07 04:18 AM
Wash the line and run out all the twists properly and then fit it to the boat. DO NOT "bundle" it together like any sailors would between these operations and fitting it to the boat. This reintroduces the twists again.
The only exception is to "bundle" it up with figure 8 loops and not normal loops. Then the line can be fitted to the mast straight from the bundle without introducing any twists.
Another good modification is to replace the turning block on the trampoline by a steel ring. The steel rings allows the kinks to pass while a microblock doesn't. The kinks are only created in the slack portion of the halyard line and never in the tensioned portion. Bungee-ing the slack portion on the tramp will therefor work to reduce kinks and /or pull then out when they do form.
Alot can be done to have the setup be largely kink free and/or kink acceptant.
6 mm line is too thick for the spi halyard. It will be heavy and needlessly thick. 4 mm is enough of the line allows your hands to have some grib. The dyneema core is very slippery and I refuse to "hand" it as a crew. Best is too just use the unmodified line as a halyard and only strip some of the mantle off of the last few feet.
Re: Spin Take down [Re: Wouter] #116795
09/17/07 04:38 AM
09/17/07 04:38 AM
Figure 8 loops? I think that also would introduce twist in the line, but two kinks running opposite each other so when you unfold the line it evens out.
If you want to store a line without twisting it, which cause all kind of trouble if you dont "unroll" the line, you should "fold" the line. In rock climbing 60 meter ropes are used, and to stop kinks from forming they are always folded when carried or stored.
If you look here, you get the idea, just scale the folds down to fit your length of line.
http://www.swcp.com/~nmmc/climbrocks/knots/butterfly_coil.GIF
Washing the line every fall when putting the boat in storage is a really good tip! Makes it last longer and it is nicer to handle afterwards.
Re: Spin Take down [Re: Rolf_Nilsen] #116796
09/17/07 04:43 AM
09/17/07 04:43 AM
taipanfc Offline
taipanfc  Offline
Figure 8 loops are the way to go.
Sail on yachts quite a bit and using figure 8 method means the pit guy doesn't get any big tangles when dropping jib/spinnaker. Because the time it does tangle, is when you really don't want it to happen.
Ropes will naturally want to kink and twist. Just need to be aware of methods to minimise this.
Line folding.. [Re: taipanfc] #116797
09/17/07 05:35 AM
09/17/07 05:35 AM
Like I said, if you make the figure 8 loops you are making two twists in opposite directions for each loop. When you uncoil the rope, the twists cancels out each other and you hopefully have a length of line without twists. Folding the line dont introduce twist at all into the line.
Both my crew and I used do do a lot of rock and mountain climbing. Getting twist into the lines while climbing is outright dangerous, so the climbing community have developed ways to avoid that. Always folding the rope is the best way to avoid twists, barring putting the line into a rope-bag. We consequently always fold lines on our boat, and lock up the folded lines by doing some turns around the hoop and a a self-locking hitch. Quick, easy and relatively idiot-proof. Try it, and compare handling with figure-8 coils. The true test is coiling and uncoiling twin trapeze lines. If you can do that without twists and snarls you have a good method.
While talking about coiling and twists. When storing the SS rigging, we dont coil the wires but roll them up. When rigging the mast/boat, we dont uncoil the wires, but unroll them. This is another variation on the same problem, how to avoid twist and kinks.
Re: Line folding.. [Re: Rolf_Nilsen] #116798
09/17/07 05:54 AM
09/17/07 05:54 AM
I certainly will !
Looks like a better alternative.
1 registered members (Damon Linkous), 2,490 guests, and 352 spiders.
