| Ratchet Block?? #117161 09/13/07 08:15 PM 09/13/07 08:15 PM |
Posts: 902 Norman,OK | I have a Harken 6:1 ratchet block system that I use on my 5.2.
Last time I was out the ratchet was not working. It made it very difficult to sail!
After looking at it I figured out it still works if the lower block is leaning forward. and yes I have checked the switch and it is set the correct way.
So why would this be happening, is the block broke or am I stupid?
| | | Re: Ratchet Block??
[Re: gree2056]
#117162 09/13/07 09:42 PM 09/13/07 09:42 PM |
Posts: 2,921 Michigan | Probably a bit of sand in it. Spray the hell out of it with a jet of water with the line off of it with the block able to spin freely. spray a huge amount of generic silicone lubricant into it. Tap it, knock it around (percussive maintenance). I rescued a single rachematic this way (saved 60$).
| | | Re: Ratchet Block??
[Re: warbird]
#117164 09/13/07 11:46 PM 09/13/07 11:46 PM |
Posts: 902 Norman,OK | I guess what I want to know is there something that normally fails in the Harken blocks, like I said the ratchet mechanism engages when you lean the blocks forward. WOuld that signal something?
| | | Re: Ratchet Block??
[Re: Dan_Delave]
#117166 09/14/07 01:09 AM 09/14/07 01:09 AM |
Posts: 902 Norman,OK | That is kinda what I was afraid of, can it be fixed or just have to buy new?
| | | Re: Ratchet Block??
[Re: Rolf_Nilsen]
#117169 09/14/07 07:40 AM 09/14/07 07:40 AM |
Posts: 902 Norman,OK | The blocks are pretty old and came with the boat so I do not see me getting them replaced. But I will try, maybe someone at Harken knows how to fix it.
| | | Re: Ratchet Block??
[Re: Rolf_Nilsen]
#117171 09/14/07 01:09 PM 09/14/07 01:09 PM |
Posts: 902 Norman,OK | First off I would just like to thank who ever at Harken emailed me back. I sent the email and within the hour I had recieved an answer.
Sadly the blocks are rivited together and the problem can't be fixed but there was an offer to help me on a new set so I will just see how it goes, but so far I am very impressed with the customer service.
| | | Re: Ratchet Block??
[Re: gree2056]
#117172 09/14/07 01:20 PM 09/14/07 01:20 PM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | Harken has a great customer service program, they stand behind their products and have lead the way in bringing new technology to the forefront. Great products, backed by great service, more companies should have a program like this.
Tom Siders A-Cat USA-79 Tornado US775
| | | Re: Ratchet Block??
[Re: gree2056]
#117174 09/14/07 01:29 PM 09/14/07 01:29 PM |
Posts: 3,293 Long Beach, California | Tiny company doing big things. Great attitude, incomparable technical understanding and remarkable customer service. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
| | | Re: Ratchet Block??
[Re: John Williams]
#117175 09/14/07 01:46 PM 09/14/07 01:46 PM |
Posts: 3,969 | gree2056 - Have you tried the cleaning route? Cleaning and working the sheave back and forth will typically resolve issues if you have sand, etc. stuck in there.
Whether you get this one fixed or buy a new one, be very careful if you decide to lube a block, traveler, cam cleat, etc. Most lubes will attract dirt, salt, etc. which causes things to bind. Best bet is McLube, as it works as a dry lubricant and tends to not collect garbage. Of course, routine cleaning (rinsing at a minimum) should be considered normal maintenance.
Hope this helps.
Mike | | | Re: Ratchet Block??
[Re: brucat]
#117176 09/14/07 05:42 PM 09/14/07 05:42 PM |
Posts: 902 Norman,OK | Yeah I tried cleaning all last night. It didn't affect anything and the guy said that the model I have usually has the same problem mine did. So they have offered to cut me a deal on the new one.
I just want to say that there are very few companies out there that have good customer service and the few that do stand out. So if anyone from Harken is reading this, way to go!~
403
guests, and 37
