| Re: Mast Stand Needed
[Re: ripcurl869]
#117819 09/21/07 01:38 PM 09/21/07 01:38 PM |
Posts: 168 San Diego | I'm not sure why you need two mast stands but I would imagine you could go to a local trailer shop or machine shop and have them weld a piece of steel tubing to a plate with some side supports and then drill four holes in it and buy a couple u bolts relatively cheap. | | | Re: Mast Stand Needed
[Re: brucat]
#117822 09/21/07 10:14 PM 09/21/07 10:14 PM | Anonymous
| Anonymous
Unregistered | It's probably worth adding that the raising process is easiest (in my experience) when performed with a little bit of speed. Trying to lift the mast overhead gradually is pretty tough, but if you're inexperienced and not sure of the dynamics it is kind of instinctive to take it slowly, even though this actually makes it harder than it needs to be. This may be what creates the perceived need for the security of a winch. That said, I'm fortunate to usually have someone around to help with the initial lift from the back and to secure the forestay. | | | Re: Mast Stand Needed
[Re: ripcurl869]
#117824 09/22/07 05:44 PM 09/22/07 05:44 PM |
Posts: 29 syracuae | put winch on regular mast holder and make a block to hold back end (top) of mast high enough so angle is good. your shrouds should keep side to side play to minimum then just connect stays. that said i always did lift with rope to cleat as mentioned earlier on my 16, not really sure about a playcat though.
Cheech U-204
574
guests, and 30
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
