What are these things? #117879
09/23/07 08:49 PM
09/23/07 08:49 PM
Cincinnati, Ohio
Tri_X_Troll Offline OP
Cincinnati, Ohio
First off, I appoligize for my ignorance.
There is a metal basket mounted on the front of my boat, and I have no idea what it is for. It's mounted to the front of the dolphin striker?
There is also a shock cord that runs from the dolphin strikcer to a pulley at the stern of the boat, what is this for?
Best illustrated in this picture taken from the stern looking forward.
Re: What are these things? [Re: Tri_X_Troll] #117880
09/23/07 09:44 PM
09/23/07 09:44 PM
L
lluistar Offline
lluistar  Offline
L
The shock cord holding the righting (blue and white) line is to retract it while not needed.
Re: What are these things? [Re: lluistar] #117881
09/24/07 12:47 AM
09/24/07 12:47 AM
the bracket is to hold a battery should you choose to mount a trolling motor to your cat. the blue line is a righting line for when you capsize.
Re: What are these things? [Re: Tri_X_Troll] #117882
09/24/07 02:19 AM
09/24/07 02:19 AM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
That is a holder for an icechest. An "Igloo Playmate" icebox to be exact.
GARY
Santa Monica Bay
Re: What are these things? [Re: hobiegary] #117883
09/24/07 10:20 AM
09/24/07 10:20 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Keep the righting line system and get rid of the rack. Your jib sheets will hang up on it.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: What are these things? [Re: hobie1616] #117884
09/24/07 11:52 AM
09/24/07 11:52 AM
California
mmiller Offline
mmiller  Offline
California
Gary got it right... the rack is the "Kool Cat" I think it was called. Fits a Playmate cooler
Hobie Cat Forums
Matt Miller
Hobie Cat Company
Re: What are these things? [Re: mmiller] #117885
09/24/07 01:24 PM
09/24/07 01:24 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
If the cooler rack causes the jib sheets to hang up, what the best way to carry a cooler?
Thanks,
Kent
Kent
1988 H16
Re: What are these things? [Re: KentHobie] #117886
09/24/07 02:17 PM
09/24/07 02:17 PM
hobie1616 Offline
hobie1616  Offline
Thanks,
Kent
You can use the rack if you run a bungee from the top of it to the forestay.
Re: What are these things? [Re: KentHobie] #117887
09/24/07 02:59 PM
09/24/07 02:59 PM
Lindale, Texas Inland freshwa...
Wallybear Offline
Wallybear  Offline
Kent, I have a rack for an ice chest that clamps onto the front crossbar near the mast step. It does not interfere with the jib even with the cooler in it. I actually thought the pic was a battery holder for a trolling motor as well. I saw a battery holder that looked very similar to it in a catalog somewhere with the trolling motor mounted under the front crossbar but I am sure Matt and Gary know what it is more so than myself.
Re: What are these things? [Re: Wallybear] #117888
09/24/07 04:22 PM
09/24/07 04:22 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
[I have a rack for an ice chest that clamps onto the front crossbar near the mast step. It does not interfere with the jib even with the cooler in it.]
Great. Any idea on where I can find one?
Thanks!
Kent
1988 H16
Re: What are these things? [Re: KentHobie] #117889
09/25/07 01:28 PM
09/25/07 01:28 PM
Wallybear Offline
Wallybear  Offline
Thanks!
Kent, The one I have came with the cat when I bought it. I have no idea where it originally came from. I checked the web and was unable to locate one. My rack looks very similar if not not exactly like the photo above except it has a clamping type bracket for the front crossbar. Makes it easy to yank off if you don't want it on the boat. I originally thought the one in the pic above might have been a battery box because of its mounting position. Hobie sells one for batteries in the catalog that mounts under the front crossbar. It is obvious that a battery would not stay in the one above without a bottom and sides. DUH!!
Re: What are these things? [Re: Wallybear] #117890
09/25/07 04:37 PM
09/25/07 04:37 PM
Atlanta, GA
KentHobie Offline
KentHobie  Offline
Atlanta, GA
Thanks, I've been looking for one for a while. I'll keep looking. May have to find another way to put a cooler on the boat.
Kent
1988 H16
0 registered members (), 430 guests, and 54 spiders.
