| Re: Speed, capsize, and marriage
[Re: jwrobie]
#11863 10/20/02 04:40 PM 10/20/02 04:40 PM |
Posts: 3,114 BANNED | hey jw, fortunately for us, puffs are easy to notice on the nice calm lakes that we are accustomed to around NC, so it shouldn't be to difficult to see the puffs coming.
My girlfriend is also very nervous when she's sailing with me on the H17. She wont get on the wings, and she also gets nervous when the bows start digging in, yet like your wife, she's never been on the boat when its howling fast.
She told me yesterday "you need to break more stuff on your boat then replace it before I'm comfortable on it." Made me feel SOOO much better.
| | | Re: Beam reach dangers
[Re: michael C]
#11866 10/20/02 06:39 PM 10/20/02 06:39 PM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie OP
Posts: 215 Durham, North Carolina | Ah, this is helpful. When you say the weight should be "all the way back" I assume you mean aft, not back over the windward hull, right? On a Prindle 16, it's pretty easy to bury the stern, so I will adjust accordingly.
How do you anticipate puffs?
As for wind speeds - at what wind speeds should I start to worry about capsize? We start feeling nervous when the wind gets above 10 mph, and much more nervous when it gets above 15 mph, but we've only been out maybe 10 times so far, and we started out with a dramatic capsize in a surprise thunderstorm. I'm trying to get factual data to use in calming our emotions ;->
Jonathan | | | Re: Speed, capsize, and marriage
[Re: jwrobie]
#11868 10/20/02 09:26 PM 10/20/02 09:26 PM |
Posts: 277 Baton Rouge, LA | First Rule With Wimmen: No Yelling.
During your outings leave sweet treat on shore and go out by yourself for an hour or so to learn more. While you're out there build some confidence and skill by trying to get one hull out of the water a little. Don't cleat the mainsheet while you're learning to fly. Just hold it in position in your hand in case you need to let it got to depower in a hurry. Once you can keep a hull up try it with honeybunches.
Explain in a confident and friendly tone what will happen and what she needs to do before you fly. She needs to be on the windward side but not too far forward. Let her hang onto something for security: the tramp lacing, a shroud, a tramp strap, not your leg. Watch the bows so you don't dig. Then take it up out of the water ONLY A LITTLE HEIGHT (a foot or two) FOR A LITTLE WAYS and hold it there for a while. Put it back down, come up into the wind and smile. Repeat as needed until the screaming turns into a soft moan. Then go in for the day.
If you do happen to capsize just smile after you're both in the water, tell her to stay with the boat, and don't exude a sense of panic or urgency. Both of you should be able to hang on and right the sucker and have a laugh about it, later and for decades thereafter.
Get a little wilder each outing but don't rush her (the wife). Sadly, some wives are not made for being on a cat but that should become apparent if it's your case or not. If this is the case you can always simply take it easy while she's aboard and don't do anything too funky.
My best advice: After twenty-five years she will trust you and will go with you on just about anything that floats. To this day my wife simply ducks her head down when she becomes frightened and I usually tell her when it's OK to look up again. You have to build trust.
Good Luck | | | Puff the dragon
[Re: MauganN20]
#11869 10/20/02 11:56 PM 10/20/02 11:56 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | How to see a puff:
Find a high point overlooking your favorite body of water (eg Jordan lake?) observe the colors and textures of the water. In calm, windless condition, the surface will be glassy. As the wind picks up, tiny wavelets form a texture on the surface of the water. The more texture water has, the deeper blue it appears. So from your observation post you'll see lighter and darker areas of water--the darker areas have more texture to the surface, caused by more breeze in that spot. As the breeze increases further, waves begin to form. Waves have more texture than wavelets, so areas of waves look a shade darker still.
At any given time, a lake will have a baseline wind condition creating a baseline texture to the surface and a baseline color. Simply put, a puff is visible where the water looks a bit darker than the baseline because there's more texture in that spot.
After a little observation, you'll have that "ah-ha" moment.
When you're sailing, it's helpful to know which direction puffs are coming from. Look to windward to see'em coming. Actually, puffs descend from the sky and, on hitting the water, fan out in a, well, fan-shaped pattern. But the general flow is with the main wind direction. (Note that all bets are off sailing under big, black clouds, where the wind can suddenly change 180 degrees right before your sails.)
Bit long-winded, but hope it helps.
By the way, most of us start getting excited rather than nervous as the wind picks up to 10-15 mph. But it takes building up to. Like driving, you don't head out on the autobahn the first time. Consider capsizing intentionally with your wife in a "controlled" situation to help get more comfortable.
[Re: h17windbtch6333]
#11872 10/21/02 10:28 AM 10/21/02 10:28 AM |
Posts: 85 | I wholeheartedly agree with windbtch here. many newcomers just need to learn that capsizing is not the end of the world. I learned this while breaking in numerous crew in collegiate dinghy sailing. It got to the point where if someone was fidgety or hesitant or otherwise uptight, I'd intentionally capsize the boat.
It gets a little dicey when you start doing this with "significant others", but I still swear by it. do a few shallow-water capsize and recovery drills as described above, and then head out on the water for some fun. if she still looks like she's waiting for the world to end, stuff a bow and go over. recover, catch your breath, laugh it off, and continue. if a couple of those don't cure her, sell the boat. she's just not going to come around and it's not worth the marital strain.
(I know, I know... we're all trying hard to "grow the sport", but the fact is that this particular breed of boat just isn't for everyone.) | | | Re: Speed, capsize, and marriage
[Re: jwrobie]
#11874 10/22/02 11:49 AM 10/22/02 11:49 AM |
Posts: 251 beaufort, sc | let her steer whenever you can get her to, start with downwind and let her gain some confidence. you control the main .my teaching technique: hand her the tiller and say "please steer toward that landmark" while you go forward and "adjust something." if she needs help ask her to keep watching the landmark and move the tiller back and forth gently till she "gets" it. the more she feels in control the more fun she will have. my friend tena was flying the hull with me on the wire the last time we went out- awesome! this woman said she didnt like sailing when we met.
marsh hawk
[Re: mrw1]
#11877 10/23/02 10:22 AM 10/23/02 10:22 AM |
Posts: 171 Tampa, FL | getting way off subject, but... i was living in arizona at the time flying a schweitzer 2-33. it is a very low performance plane with very little penetration. perfect for learning. we towed up to 900 feet and i got into a wave. we were up at 7000 feet in about 3 minutes. the screaming and crying from the back seat was horrible. i had to bank it at about 65 degrees to get down (even more screaming). the spoilers were not effective that day. i have never flown the planes you are interested in, but the schleicher looks similar to a schweitzer 1-26. the l/d on these planes look pretty low. if you want to just fly then buy one of these. i would rent for a while so you can try a few different planes. if you have a low budget, try a 1-35 (single) or a blanik L13 (two place). both are metal and pretty low cost. glass ships are great. make sure you get a ship that has spoilers. flaps are nice, but they are much harder to use and can stall the plane if reduced too quickly (usually on landing). i have seen 4 glider crashes (no injuries), and 3 of them were flaps only ships. if you want more info about the ships i have flown and my experiences, e-mail me directly at david.taylor@mech-solutions.com | | |
2,475
guests, and 285
