Page 3 of 3 1 2 3
Re: T-Fittings & Leaks [Re: Tornado] #118845
10/18/07 02:52 PM
10/18/07 02:52 PM
If I could manage, I think a layer of glass on the inside and some lightweight filler would be my preferred method. Might be a bit tricky as you would have to do it in two operations, first do the glass, then glue the glass in position and add the filler. I would hate to add weight and glass to a carbon Tornado mast!
Sad to hear that your Marstrøm Tornado mast leaks due to what sounds like a poor solution. This is something the technical comitte of the ITA should adress.
Re: T-Fittings & Leaks [Re: Rolf_Nilsen] #118846
10/18/07 03:01 PM
10/18/07 03:01 PM
We sealed Paulw's mast with epoxy foam.
Re: T-Fittings & Leaks [Re: scooby_simon] #118847
10/18/07 03:20 PM
10/18/07 03:20 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I don't think any sort of foam can handle water pressures as the mast goes under. Even a full sealed mast may have to take a huge pressure if the boat pitch poles and goes nearly full turtle before the bouyancy brings it back up.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Page 3 of 3 1 2 3
0 registered members (), 21,384 guests, and 1,106 spiders.
49 minutes ago
