Is a roll tack effective on a boardless cat? G-Cat #119999
10/10/07 09:29 AM
10/10/07 09:29 AM
Lake Murray SC
FasterDamnit Offline OP
Lake Murray SC
Looks like I have missed a lot in the way of tactics and boat handling advances over the last 15+ years. Is a roll tack beneficial on a boardless cat? God knows it can use all the help it can get.
E-Scow
24' ULDB
Re: Is a roll tack effective on a boardless cat? G-Cat [Re: FasterDamnit] #120000
10/10/07 09:51 AM
10/10/07 09:51 AM
Yes.
It's probably more effective because it's boardless.
Re: Is a roll tack effective on a boardless cat? G [Re: FasterDamnit] #120001
10/10/07 09:53 AM
10/10/07 09:53 AM
On a g-cat!? Absolutely! The G-cat design is an interesting one and it goes very fast in a straight line. However, it does not tack particularly well because it has so much long, narrow, and deep hull in the water. The more hull you can get out of the water during a tack, the much better you are. Get all your weight back as far as possible and stay on the old windward side as long as possible when tacking.
Re: Is a roll tack effective on a boardless cat? G-Cat [Re: FasterDamnit] #120002
10/10/07 09:57 AM
10/10/07 09:57 AM
Raleigh/ Wrightsville Beach NC
MarkW_F18 Offline
MarkW_F18  Offline
It is even more effective with a boardless cat, since you don't have boards to help pivot the boat through the turn. I've never been on a G-Cat, but it is an essential tactic with a H16. I normally will start my turn while still out on trap. Pulling in on the trap wire with the weight on the back corner, really helps tack quicker. Of course, this is in moderate to light winds.
Mark Williams
F18 H16
http://emsa-sailing.org
Re: Is a roll tack effective on a boardless cat? G [Re: MarkW_F18] #120003
10/10/07 10:29 AM
10/10/07 10:29 AM
Lake Murray SC
Lake Murray SC
Thanks guys!
Just found some good stuff thru Google, too. looks like we need to practice...
E-Scow
24' ULDB
1 registered members (JesperS), 308 guests, and 37 spiders.
